P3190, p3193, car sitting for long time
Discussion in 'Gen 2 Prius Main Forum' started by andrew shanahan, Mar 20, 2024.
  1. andrew shanahan
    andrew shanahan Junior Member
    Hello all, looking for a clue. Where do I start troubleshooting gen2 2006 Prius
    Tl;Dr. Getting p3190 and p3193 codes. Car doesn't seem to want to run in maintenance run diag mode. Unless I am not actually getting it in that mode.
    The car ran fine before it was neglected/sat unused, except for bad modules in traction battery.
    Background: hv traction battery was pulled and car sat for well over a year, maybe two the way time goes.
    I replaced the traction battery and 12v battery. The car started up and ran poorly for a few seconds then shut off. It won't seem to run for more than a few seconds at a time. I added a few gallons of fresh gas, as that was in the tank is likely very stale; shows about 4 bars on fuel gauge.
    Where should I start troubleshooting? I suspect that the engine is not running long enough to keep the traction battery charged. I do have another Prius (daily driver) that I can swap the traction batteries back and forth to keep charged, but that is a huge pain.
    Any advice on what to troubleshoot first would be much appreciated. I suspect bad fuel, varnish, etc. in fuel system....where do I start?
  2. Tombukt2
    8,199
    1,424
    2 years is probably not enough to cause varnishing in the fuel tank yet but it won't be long That's engine will not start and pour running or something aren't those codes that.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,254
    1,359
    NJ-USA
    Clean the throttle body and (carefully) clean MAF sensor elements then try once to start.
    Stale gas can cause problems for the injectors and sometimes the intake valves. Any idea if the fuel pump works?
    If it's still a problem you could (again carefully) feed some kind of "fuel" into the air inlet track and see if the ICE can actually run (I use an automotive propane enrichment tool, others use something flammable like carb or brake clean).
    The car will normally spin the engine at 1000 RPM for up to 10 seconds when it wants to start. You would have to feed fuel during - after that to see if the engine continues running.
    Brian1954 likes this.
  4. andrew shanahan
    Not sure if fuel is getting to engine. I disconnected a line (I think it is the fuel line at back right side of engine) and connected hose to drain into gas can When I put into ready mode, no fuel is pumped into a waiting gas can. I also removed the rear seat to gain access to the fuel sending unit. I can not hear the pump running when put into ready mode.
    Is there a way to make this pump turn on and pump fuel out of the tank?
    #4 andrew shanahan, Mar 20, 2024
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,107
    5,816
    Columbia, SC
    Second on that TB and MAF clean job. If it still acts stupid after that, remove the air cleaner cover and spray starter fluid in it while it tries to start. If it runs, keep spraying as needed to keep it going until it smooths out a bit. Shouldn't take long for the kinks to work out, but after a couple tears being idle, that HV battery probably has some issues. Good to hear you have a backup!
  6. andrew shanahan
    I cleaned the TB using seafoam and swapped out the MAF with one from my other Prius. Put into ready mode without starting ICE and cleared codes using torque app and odb2. Started ICE, which ran poorly and then quit...red triangle and set code p3190.
    How do I test the fuel pump?
  7. andrew shanahan
    Last update for the evening:
    1. TB and MAF cleaned or swapped with no improvement.
    2. Started fluid used when trying to start car...seemed to improve rmp smoothness, but ultimately could not keep the engine running. It stopped again after a few seconds with red triangle, p3190 set and p3193 pending.
    I think I need to test the fuel pump next? How do I do that?
    I will also need to swap the traction battery with the one in my wife's Prius so that it can be charged...I am probably close to it being drained pretty low.
    All will have to wait until Friday. Thanks for your help so far
    #7 andrew shanahan, Mar 20, 2024
  8. mr_guy_mann
    3,254
    1,359
    NJ-USA
    Get a copy of the factory service manual for details on performing diagnostic tests.
    The fuel pump won't be powered up unless the ECM is trying to start-run the ICE.
    An "easy" way to check things is to use a capable scantool that has bidirectional tests. Then you command the ECM to turn the pump on and can test for power at the tank. (Techstream or ThinkDiag are two capable scantools)
    Or use the wiring diagrams to figure out what wires at the tank need 12V power and ground to energize the pump.
    The usual pump test is to connect a pressure gauge to the system to see what the pump produces. Some parts stores will rent a gauge set.
    Might want to search the forums here for a DIY "grid charger" that would let you recharge the HV battery with swapping stuff to another car.
  9. andrew shanahan
    hello all, and thanks again for your help. It has taken a while to get back to this project.
    I checked the fuel pump according to the service manual. I have about .8 Ohm across terminals 3 and 7 on the pump connector. But when I connect 12v power to these terminals, I cannot hear the pump running. How loud is the pump? Should I be able to hear it running?
    edit: I have not checked the ECU or relay terminals yet.
  10. mr_guy_mann
    3,254
    1,359
    NJ-USA
    If you are at the fuel tank connector, then you should hear it - it's a "quiet" hum but audible.
  11. andrew shanahan
    Ok, I tried to jump the fuel pump again, at the connector as before, just as your pic.
    Either the hum is below the threshold my 55 year old ears can hear, or it is snot working. The pump coil ohms out good per the tech manual and I get sparks on my cobbled test lead, suggesting that it should work and is drawing current.
    Is there another way to test that the pump is actually running and pushing fuel through the lines? I do not have a techstream device
  12. mr_guy_mann
    3,254
    1,359
    NJ-USA
    Well, I would disconnect a fuel line, plug a pressure gauge into it then power up the pump. But you need a gauge set and adapters (people say that some of the auto parts stores will rent one).
    Or aim the fuel line into a container and see if the pump puts out anything when powered - this requires 2 people and potential fire hazards.
    If the car had been sitting long enough, the pump certainly could have "locked up". On a US spec Gen2, that means the complete fuel tank assembly needs replacement.
