Recent Activity
Activity stream for all registered members at PriusChat.
ETC(SS) replied to the thread Installing a panel meter.
Good Luck!
Jun 12, 2024 at 8:37 AM -
TheLastMojojomo liked mudder's post in the thread Project Lithium Soother Test.
Here's my open source lithium conversion solution for the G1 Honda Insight. Note that that 'LiBCM' PCB I designed actually has all the...
Jun 12, 2024 at 8:14 AM -
The point is to prevent post after speculative post regarding the product's alleged capabilities. The goal then is to show the exact...
Jun 12, 2024 at 8:13 AM -
TheLastMojojomo liked TMR-JWAP's post in the thread Project Lithium Soother Test.
Looking for my popcorn..... This is like the most perfect example ever seen of two individuals, each from complete opposite ends of the...
Thanks for the clarification. I manually re-read your post#87 and see that you have an "@Xeico" at the very beginning. Looks like the...
Jun 12, 2024 at 8:12 AM -
Please remind me again what my "own gains" are in releasing an open source companion BMS that works with 3rd party lithium modules...
That's great to hear! You keep stating this as if it supports your (unstated) argument that NexCell modules are safe. The primary...
rjparker attached a file to the thread IS IT A HEADGASKET?.
Depends on the rebuilder and his inspection after a teardown. I think the typical shop or diy rebuild is a risk. Many have bought from...
Jun 12, 2024 at 7:59 AM -
KH111 replied to the thread Warming up Prime in Cold weather..
The simplest solution is usually the right answer. Just found out the engine will start in Park, start button depressed (ready , HV...
Jun 12, 2024 at 7:56 AM -
Paul Gregory replied to the thread Installing a panel meter.
I feel I've already explained this issue in exhaustive detail. I am loathe to reiterate everything again. I imagined I could install a...
Jun 12, 2024 at 7:43 AM -
TheLastMojojomo replied to the thread Project Lithium Soother Test.
So have I... at least 95%+ of packs that are on the road anyways. Never say never... your regenerative brake current is constantly be...
Jun 12, 2024 at 7:40 AM -
HacksawMark replied to the thread Rear Trim Cracking.
Unless there is some sort of contact damage, I can envision the trim cracking if the the hatch is repeatedly slammed shut. Like you, I...
Jun 12, 2024 at 7:21 AM -
Grit liked ASRDogman's post in the thread Project Lithium Soother Test.
My engine runs on water man!!!! My new battery runs on water man! It's smoooooothhhhhhh....:rolleyes::whistle::barefoot:
Jun 12, 2024 at 7:20 AM -
AzWxGuy liked jdenenberg's post on AzWxGuy's profile.
My first car was a 1963 TR4, Bought it new when my father objected to a Spitfire as a roller skate.
Jun 12, 2024 at 7:09 AM
