Recent Activity
Activity stream for all registered members at PriusChat.
  1. bwilson4web replied to the thread Tesla stock.
    I'll have to fall back on my pensions and Social Security. But the foolish fund managers will have to explain how their vote to force...
    Jun 11, 2024 at 2:53 PM
  2. KMO replied to the thread Toyota Japan prius accessories and mods.
    I believe that's come up before and we concluded that it's unfortunately shaped for right-hand-drive cars - won't fit LHD.
    Jun 11, 2024 at 2:51 PM
  3. rjparker replied to the thread IS IT A HEADGASKET?.
    Kind of wish the clean egr and misfire guys would back off and save unnecessary work and parts replacement. Many times that money would...
    Jun 11, 2024 at 2:50 PM
  4. Mr.Vanvandenburg replied to the thread Whirring Noise when put in Reverse Gear.
    I listened more today and the signal is there when brake is released going forward and in reverse. Very quiet and steady sound, not that...
    Jun 11, 2024 at 2:41 PM
  5. jeff652 liked dolj's post in the thread Hybrid Battery Reconditioning 2009 Prius.
    Generally, when they get to 1.2 V below the other that's the end of the road for that module. They need to be similar in capacities....
  6. rjparker replied to the thread Project Lithium Soother Test.
    Sorry but you are out of your depth.
    Jun 11, 2024 at 2:39 PM
  7. Zeromus replied to the thread Toyota Japan prius accessories and mods.
    Ok but I really want number 712. A small box that fits behind the screen, that I can put tissues in? that's, honestly, genius. should be...
    Jun 11, 2024 at 2:34 PM
  8. Trollbait replied to the thread Gen 6 Prius engine will be a “game changer,” achieve a 53% thermal efficiency.
    This ICE may be part of their hydrogen car push. The claims being made for Toyota may require hydrogen injection to reach with gasoline....
    Jun 11, 2024 at 2:31 PM
  9. Paul Gregory replied to the thread Installing a panel meter.
    The problem is that I have no a meter with a wide enough range. It would have to handle milliamps right up to full load.
    Jun 11, 2024 at 2:20 PM
  10. Paul Gregory replied to the thread Installing a panel meter.
    I think you're correct, my idea wouldn't work.
    Jun 11, 2024 at 2:18 PM
  11. Paul Gregory replied to the thread Installing a panel meter.
    I haven't seen the kind of parasitic drain I saw before, I guess I'm guarding against it happening again.
    Jun 11, 2024 at 2:17 PM
  12. bisco liked C Wagner's post in the thread Cleaned corrosion from buss bars now getting P3000 code.
    Reply to myself: I removed the battery and took off all the bus bars that were various shades of awful green. I cleaned the corrosion...
    Jun 11, 2024 at 2:13 PM
  13. bisco replied to the thread codes: P0A80,0A9E, P0AC2,P0AC8.
    that is most often the case with refurbished batteries unfortunately
    Jun 11, 2024 at 2:11 PM
  14. bisco liked Anthonyhea25's post in the thread codes: P0A80,0A9E, P0AC2,P0AC8.
    Got the Autel AP200 and it’s awesome! Especially for 60$.. it’s P3004 detail code 800.
    Jun 11, 2024 at 2:09 PM
  15. bisco liked Anthonyhea25's post in the thread codes: P0A80,0A9E, P0AC2,P0AC8.
    Well… just when I thought everything was good, I got the check hybrid system message again. I am now showing code P0A80 subcode 123....
    Jun 11, 2024 at 2:07 PM
Loading...
