Recent Activity
Activity stream for all registered members at PriusChat.
donzoh1 replied to the thread 2008 Instrument Panel OTS.
I will definitely check into the rebuilt unit you mentioned.
May 16, 2024 at 12:57 AM -
donzoh1 liked bisco's post in the thread 2008 Instrument Panel OTS.
try pulling the fuse that runs the combo meter to see if that is causing the excess draw. if not, you'll have to go through all the...
May 16, 2024 at 12:54 AM -
Cadenza replied to the thread No spare tire?.
Late to the game... Can the collective please confirm that the spare wheel from G2 fits G3. I've just gone mad and got a '15 Plug-in....
May 16, 2024 at 12:44 AM -
soft_r liked Xov’ze's post in the thread GruppeM Ram Air System for Toyota 60 Prius 2.0 HYBRID.
couldn’t we accomplish this with like? A strip of duct tape? What exactly does swapping out the airbox do? Does it get better airflow...
May 16, 2024 at 12:32 AM -
agrigento replied to the thread Noise coming from engine compartment.
Thanks for your replies so far! I also want to think it's water pump related. Oil is not low. Here's the link for the audio file just in...
May 16, 2024 at 12:28 AM -
TMR-JWAP replied to the thread Are these counterfeit OEM Iridium spark plugs?.
A quick gap adjustment and it'll be good to go.
May 16, 2024 at 12:15 AM -
Carall attached a file to the thread Are these counterfeit OEM Iridium spark plugs?.
Is this an example of Chinese "Denso" spark plugs? I returned from an 8 hour trip and about a mile from home the engine started misfire....
May 15, 2024 at 11:53 PM -
xliderider liked Brian1954's post in the thread High Coolant Temp Warning Flash Then Off.
^ I agree with the post above. You should monitor the engine coolant temperature by purchasing an OBD2 bluetooth adapter and use an...
May 15, 2024 at 11:48 PM -
xliderider liked Xterra72's post in the thread High Coolant Temp Warning Flash Then Off.
That’s exactly what happened to me. Next time it happens, check your engine coolant reservoir. I had signs of coolant spill. I...
Cc103acs liked ChapmanF's post in the thread 12v Portable Jump Recommendation.
The underhood jump point is only metal on one side. It's backed by a piece of plastic on the other side. The cable clamps that come...
May 15, 2024 at 11:44 PM -
mr_guy_mann replied to the thread Reviving 08.
Your posts are a bit ... odd. The code scan shows C1259 and C1310 - these set when the hybrid control (or HV battery?) system has...
May 15, 2024 at 11:40 PM -
dbstoo attached a file to the thread Tesla Autopilot recall probed by safety regulator following new crashes.
[ATTACH] I'm not worried about the doom and gloom. I have no interest in Tesla other than getting them to do all their data gathering...
May 15, 2024 at 11:35 PM -
Carall replied to the thread 2011 Prius Battery Reconditioning? - Sitting for 4 years.
This depends on the condition of the battery. For the past few years I have always discharged below 84 volts and have also tried...
May 15, 2024 at 11:25 PM -
hill replied to the thread Spotting thread! Did you see any special cars on the road today?.
PBY Catalina was a much better looking sea plane ... but treading shark infested waters ... the grumman would do just fine.
May 15, 2024 at 11:21 PM
