Recent Activity
Activity stream for all registered members at PriusChat.
  1. Tombukt2 replied to the thread Netting attachment won't stay in wall.
    Then that means you can probably order those pieces from amiyama or Toyoda and possibly other sources once we see the back of the little...
    Jun 5, 2024 at 10:55 PM
  2. rjparker replied to the thread Blown Head gasket rebuild....@297k.
    Toyota’s revised head gasket for these engines is almost solid black.
    Jun 5, 2024 at 10:54 PM
  3. Ainsley liked ETC(SS)'s post in the thread fix or replace?.
    Yes. You're not throwing good money after bad but you might be throwing it in the wrong place. Three thoughts: 1. If you have the...
    Jun 5, 2024 at 10:47 PM
  4. Ainsley liked Tombukt2's post in the thread fix or replace?.
    Put a die-hard AGM battery in the 12 volt Toyota doesn't make batteries so buying them at the dealer doesn't really make sense they're...
  5. JohnPrius3005 replied to the thread HV Battery code P3000-389.
    You can build yourself a "grid" charger to charge the HV bat. For less than $100. Using this "might" buy you the time you want. Then you...
    Jun 5, 2024 at 10:26 PM
  6. Grit replied to the thread can I use this battery? LiFePO4 Battery as the 12V battery.
    Does the bms have low temp cut off?
    Jun 5, 2024 at 10:24 PM
  7. 16 yrs & counting replied to the thread Netting attachment won't stay in wall.
    I just dug into my old paperwork on this car and the "cargo net" came with package 7 on the 04 Prius.
    Jun 5, 2024 at 10:12 PM
  8. htcmember liked Tombukt2's post in the thread Can we do a software update after EGR cleaning job with TechStream.
    Yeah the steps are posted all around I mean it doesn't really do a whole lot I would say yeah you definitely want to make sure you're 12...
    Jun 5, 2024 at 9:30 PM
  9. htcmember liked Danno5060's post in the thread Can we do a software update after EGR cleaning job with TechStream.
    While I've not programmed a car's computer, I've got 20+ years of experience programming industrial controllers. There's always the...
    Jun 5, 2024 at 9:29 PM
  10. 16 yrs & counting replied to the thread Netting attachment won't stay in wall.
    Interesting! It's encouraging to hear that there might be an explanation. Maybe I'll try popping it off tomorrow to see what's under...
    Jun 5, 2024 at 9:28 PM
Loading...
