Recent Activity
Activity stream for all registered members at PriusChat.
Gokhan replied to the thread Gen 6 Prius engine will be a “game changer,” achieve a 53% thermal efficiency.
Of course the 1980s cars had catalytic converters. It still increases the NOₓ a lot. I don't know how lean is that Lexus. New Honda...
Jun 14, 2024 at 1:09 AM -
Gokhan liked austingreen's post in the thread Gen 6 Prius engine will be a “game changer,” achieve a 53% thermal efficiency.
Toyota has had a turbulent jet ignition (tji) engine in a super gt lexus since 2018. TJI works on an old idea from the cvcc using a pre...
Jun 14, 2024 at 1:05 AM -
Clancy Bond replied to the thread ABS VSC and (!) lights and brake warning alarm.
Tried to see if there was anything that I was missing on the app for another 30 min but the only freeze frame data I could pull was for...
Jun 14, 2024 at 12:59 AM -
GcinFl liked stuyguy's post in the thread Delivered with one key FOB.
Received a service campaign alert tonight in the Toyota app that my second key is available. No letter yet
Jun 14, 2024 at 12:54 AM -
Wonder liked Andyprius # 1's post in the thread Using PIP As A Generator.
There are several advantages 1. Length of cable, 110V would be shortened. Because 2 I would be driving the front of the car in, as the...
Jun 14, 2024 at 12:48 AM -
ronlewis replied to the thread serpentine belt on 2001 prius.
This is a very simple job. Yeah, easier to remove the front wheel, but you don't have to. Just one bolt to unloosed the tensioner...
Jun 14, 2024 at 12:47 AM -
Wonder liked usbseawolf2000's post in the thread Using PIP As A Generator.
The idea of having a dedicated generator is nice. On the flip side, you'll have to maintain it as well. Oil and filter changes? Spark...
austingreen replied to the thread Gen 6 Prius engine will be a “game changer,” achieve a 53% thermal efficiency.
Jun 14, 2024 at 12:43 AM -
Isaac Zachary liked Trollbait's post in the thread Gen 6 Prius engine will be a “game changer,” achieve a 53% thermal efficiency.
What does the manual say? I've used their E15 in the Camry, but Toyota says to stay below E20. The components of a car that can use E10...
Jun 14, 2024 at 12:42 AM -
AzusaPrius attached a file to the thread HV fan preset overriding.
Besides Hybrid Assistant and the Dr. Prius app there is this device, though it is very pricey at $300 so not sure many people would buy...
Jun 14, 2024 at 12:32 AM
Wonder liked Rebound's post in the thread Using PIP As A Generator.
Wow, only $149? Can you please write up a little review? Does it fit well in the Prius? Does it work with all of your appliances? Has it...
Jun 14, 2024 at 12:28 AM -
Wonder replied to the thread My year with the Volt. Costs and Comparisons.
I guess it was only 7 pages. Maybe it was 114 replies.
Jun 14, 2024 at 12:21 AM -
Clancy Bond attached a file to the thread ABS VSC and (!) lights and brake warning alarm.
On the dtc C1241 the only detailed freeze DTC I got was “512” not sure what this means yet or if I did the scan wrong on the app but let...
Jun 14, 2024 at 12:20 AM
StarCaller replied to the thread Water Pump.
That's what I thought, too / I changed the waterpump & the thermostat last weekend & it was NOT as quick & easy like in the youtube...
Jun 14, 2024 at 12:19 AM -
Volt driver, I'm wondering how the longevity of you vehicle went now that its 10+ years later? I guess I could continue down the 114...
Jun 14, 2024 at 12:18 AM
