Recent Activity
Activity stream for all registered members at PriusChat.
  1. rjparker replied to the thread Regret ordering..
    Lots of people want the Rav4 Prime for its size, the 18.1 kWh plugin capability and a very strong 302 hp. Granted, the first couple of...
    Jun 5, 2024 at 3:12 PM
  2. KitsuneVoss replied to the thread 2009 Prius - Warnings and will not engage..
    I have put everything together and hopefully everything is okay. If anyone is willing to take a look? [IMG] [IMG] I cannot remember...
    Jun 5, 2024 at 3:10 PM
  3. htcmember liked Danno5060's post in the thread Can we do a software update after EGR cleaning job with TechStream.
    You should read the CALID out of the ECU and compare it to @rjparker list above. If it's current, there's no need to update, and the...
    Jun 5, 2024 at 3:09 PM
  4. Tombukt2 replied to the thread Can we do a software update after EGR cleaning job with TechStream.
    Yeah the steps are posted all around I mean it doesn't really do a whole lot I would say yeah you definitely want to make sure you're 12...
    Jun 5, 2024 at 3:05 PM
  5. Tombukt2 replied to the thread fix or replace?.
    At 150K a generation 2 is barely barely broke in well unless it's just been beat to death by real asshats and then generally all they've...
    Jun 5, 2024 at 3:02 PM
  6. Tombukt2 replied to the thread " PROBLEM " + constant beep after merging onto highway -- brake actuator?.
    The constant beep that never ends that I always get is on the back of the CM monitor there's a speaker and it's beeping telling you or...
    Jun 5, 2024 at 3:01 PM
  7. Tombukt2 replied to the thread " PROBLEM " + constant beep after merging onto highway -- brake actuator?.
    No you lay the back seat down You will need to move the side pieces in the trunk that the seat belt recoils into and what have you then...
    Jun 5, 2024 at 3:00 PM
  8. Mendel Leisk replied to the thread LOUD Banging/Rattling at Start Up!!!.
    This is a very interesting thread, early harbinger of the head gasket issue?
    Jun 5, 2024 at 2:59 PM
  9. Tombukt2 replied to the thread P0401 code after cleaning.
    All I can tell you is I took mine apart and I was looking for the little ramp business and all this stuff that's supposed to break not...
    Jun 5, 2024 at 2:56 PM
  10. Mendel Leisk liked fuzzy1's post in the thread Tires and the Prius.
    ... and if the odometer is off, it must be in the other direction, reading low instead of high. Also by design, forced by class action...
    Jun 5, 2024 at 2:55 PM
  11. Mendel Leisk replied to the thread Regret ordering..
    Kinda lost, regarding R4P and PP. Spell it out? N'mind, think I know.
    Jun 5, 2024 at 2:35 PM
  12. Trollbait replied to the thread Incognito EVs.
    Nice, but how much does that add to costs vs a balanced pair that Electrify America uses? A car isn't going to pull the full rate for...
    Jun 5, 2024 at 2:30 PM
Loading...
