Recent Activity
Activity stream for all registered members at PriusChat.
bisco liked Beanz's post in the thread Check Hybrid System: Dead 12V battery, low fuel.
Thank you for the replies. I had to go out of town for a long weekend for a graduation and ended up having to rent a car. I plan to...
Jun 5, 2024 at 2:06 PM -
bisco replied to the thread Two questions....
i've never seen a laster prius, it that an aftermarket mod company?
Jun 5, 2024 at 2:04 PM -
Seymour1 replied to the thread P0401 code after cleaning.
Jun 5, 2024 at 2:03 PM -
sylvaing replied to the thread Incognito EVs.
That's for V2 Superchargers. Doesn't apply to V3. Side note, V2 Superchargers will not be opened to other EVs, just V3 and V4.
Jun 5, 2024 at 2:02 PM -
bisco replied to the thread " PROBLEM " + constant beep after merging onto highway -- brake actuator?.
p3004-131-need-help-2009.210673 3004131.pdf 2007-prius-188k-no-start-p3004-131.159337
Jun 5, 2024 at 2:00 PM -
bisco liked Starship_Enterprius's post in the thread What Would You Like To Tell Toyota?.
More flexible battery charging programming. Like.. Let the battery start charging to preferred level like 50 or 60% as soon as plugged,...
Jun 5, 2024 at 1:53 PM -
rjparker replied to the thread ABS error blink codes..
Check Hybrid System | PriusChat
Starship_Enterprius replied to the thread What Would You Like To Tell Toyota?.
Jun 5, 2024 at 1:46 PM -
pascalvin replied to the thread FITCAMX dashcam.
Yea, my OEM one did not have vent openings the fitcamx housing does
bisco replied to the thread Toyota prius gen4 plug in 2016-2022 heat exchanger bypass?.
watch watch watch
Jun 5, 2024 at 1:45 PM -
JohnPrius3005 liked Mr. F's post in the thread Does 'PA080 Replace Hybrid Battery Pack' always indicate a replacement necessary?.
P0A80 is triggered only when the voltage difference between two modules grows larger than a set threshold on two separate trips....
Jun 5, 2024 at 1:41 PM -
Seymour1 replied to the thread LOUD Banging/Rattling at Start Up!!!.
Jun 5, 2024 at 1:40 PM -
Danno5060 replied to the thread Can we do a software update after EGR cleaning job with TechStream.
While I've not programmed a car's computer, I've got 20+ years of experience programming industrial controllers. There's always the...
