Recent Activity
Activity stream for all registered members at PriusChat.
  1. bisco liked Leadfoot J. McCoalroller's post in the thread 2013 prius c no codes but reduced mpg's.
    ...possibly eco mode, not ev mode?
    May 31, 2024 at 7:31 PM
  2. bisco replied to the thread 2013 prius c no codes but reduced mpg's.
    you should be able to tell if the engine is running by sound?
    May 31, 2024 at 7:30 PM
  3. bisco replied to the thread 2013 prius c no codes but reduced mpg's.
    that sounds like a software issue. are you calculating mpg at the pump, or watching the screen?
    May 31, 2024 at 7:28 PM
  4. flybuzz liked bisco's post in the thread squeaking sound when push against it.
    sounds like a suspension squeak, which doesn't need attention unless it is bothering you
    May 31, 2024 at 7:25 PM
  5. Rock_Star replied to the thread NOT Normal P Lock Malfunction - ONLY Happens Over 80 Degrees. Never When Cooler.
    I found the wire you were talking about. I pulled about 6 inches of wire out of the plastic protection shroud but I saw no damage. I...
    May 31, 2024 at 6:56 PM
  6. Seymour1 replied to the thread P0A80 Code- but is it really the hybrid battery.
    I spent 2 weeks reconditioning my traction battery. The triangle light was on and "Check Hybrid system" message was on. I cycled...
    May 31, 2024 at 6:54 PM
  7. kutcht1 replied to the thread Burning 3.9qts every 1000 miles.
    Well, enjoy your new car!
    May 31, 2024 at 6:48 PM
  8. kutcht1 liked Fatmatt86's post in the thread Burning 3.9qts every 1000 miles.
    Well, this will be last Prius update and a final close to this 6 year old thread. Final resting odometer reading on my Prius is 337,713....
    IMG_9811.jpeg IMG_9802.jpeg IMG_9801.jpeg IMG_9799.jpeg IMG_9800.jpeg IMG_9797.jpeg IMG_9796.jpeg May 31, 2024 at 6:45 PM
  9. kutcht1 replied to the thread Error Code P0A08 (and others?) - Safe to drive?.
    Question for the original poster or anyone else who has had the P0A08 code. Did you also get a high pitched alarm tone? TomK
    May 31, 2024 at 6:43 PM
  10. mountaineer liked JH26036's post in the thread Flat tires on 19 inch rims.
    You literally can just move down to 17s and go 215/55/17 which is a very generic tire size...came on Camrys for many many years.
    May 31, 2024 at 6:42 PM
  11. kutcht1 replied to the thread P0A08 error code.
    May 31, 2024 at 6:41 PM
  12. R_W replied to the thread Coil Bolt?.
    @Tombukt2: Thanks for the suggestion. I'll look into those. Right now, considering that I didn't know there was an oil leak, my focus...
    May 31, 2024 at 6:33 PM
Loading...
