Recent Activity
Activity stream for all registered members at PriusChat.
Halo9809 attached a file to the thread LED Headlight Conversion.
Hey, I came across this thread when deciding to upgrade my headlight assemblies and want to make sure I have the correct part for a plug...
Jun 13, 2024 at 11:27 PM -
Xeico liked ChapmanF's post in the thread Project Lithium Soother Test.
Thanks for doing that. Do I have this summary about right? What it does Transforms 14 input voltages (VIN1 through VIN14) to 14...
Jun 13, 2024 at 11:23 PM -
Prius RT attached a file to the thread P3020 after battery work- Mod 10 service plug disconnect?.
Drove 15 miles and battery charge is near 90%. Of course still have red triangle. I'll reset it tomorrow to see if it comes back again...
Jun 13, 2024 at 11:13 PM -
AlaskaPrius2004 liked mr_guy_mann's post in the thread P3030 code after cell replacement and battery reconditioning.
You have an intermittent open circuit on one of the voltage sense circuits from the HV battery to the ecu. Could be a broken terminal at...
Jun 13, 2024 at 11:00 PM -
AlaskaPrius2004 liked dolj's post in the thread P3030 code after cell replacement and battery reconditioning.
... or the No. 2 frame wire harness has corrosion wicking along the wire. It's also possible there is a break in one of the sensing...
AFAIK, the harness is available from the dealer for a reasonable price. If you don't have a local wrecking yard, then ebay would be my...
Jun 13, 2024 at 10:59 PM -
abubin posted a new thread.
HV fan preset overriding
I read a few thread on the analytics and control of the HV fan. However, I just need something simple. Let the fan run at max (level 6)...
Forum: Gen 3 Prius Technical Discussion
Jun 13, 2024 at 10:46 PM -
Wonder replied to the thread Water Pump.
I read almost this whole thread this morning, (my memory is hazy but I think I got the basics) along with some other research and came...
Jun 13, 2024 at 10:40 PM -
Merkey liked ETC(SS)'s post in the thread Just need to vent....
Oh I don't! When you don't have to pay for R&D and you can employ 1890's US Labour practices it REALLY cuts down on the cost to...
Jun 13, 2024 at 10:31 PM -
Wonder replied to the thread 2010 Water Pump Drive Belt.
Ok thank you.
Jun 13, 2024 at 10:22 PM -
Merkey replied to the thread Spotting thread! Did you see any special cars on the road today?.
Spotted the Charger EV (2 door version) with manufacture plates. Not far from the Stellantis offices in Auburn Hills, MI.
Jun 13, 2024 at 10:20 PM -
Prius RT liked bisco's post in the thread P3020 after battery work- Mod 10 service plug disconnect?.
you need a new battery
Jun 13, 2024 at 10:18 PM
