Audio and Electronics This is a discussion on Key warning light on dash within the Audio and Electronics forums, part of the Toyota Prius Forums category; This is an intermittent problem. I get in the Prius with the Smart Key in my pocket. Start up the ...
Old 03-10-2006, 11:13 PM   #1
thundermustard
This is an intermittent problem. I get in the Prius with the Smart Key in my pocket. Start up the engine and drive away. The key warning light on the dash comes on and stays on for some time. The light with the key picture and an exclamation mark through it. Anybody else have this happen. There is no beeping warning like you get if you drive away with the key out of the car.
thundermustard is offline
Old 03-10-2006, 11:27 PM   #2
kdmorse
I saw this happen the first few days I owned the car, when I kept the key+fob in the left pocket of a big floppy coat. If I sat just right, it would flop to the left of the seat, down, and slightly behind the drivers seat, in which case the car didn't register they fob as being in the car. If I pulled the coat pocket back up, the saw the fob again and was happy. Since then, I've kept it in my right pants pocket, and haven't see the problem since.
Just a possibility to consider, exactly where in the car is the key when this tends to happen to you?
-Ken
2006 Black
Package #7
Dark Grey Interior
Headlight Flasher EV Mod
kdmorse is offline
Old 03-10-2006, 11:55 PM   #3
Salsawonder
Salsawonder's Avatar
Same here. If the purse is in the back or sometimes the cells are in the way. It is just telling you it is having a hard time reading the fob. Repositioning will solve your light.
Salsawonder is offline
Old 03-11-2006, 10:57 AM   #4
darwin100
Yes same thing...if I put my purse in back it sometimes pops on..the first time it happened I paniced but...now...I just readjust the purse....
darwin100 is offline
Old 03-11-2006, 07:35 PM   #5
thundermustard
[snapback]223474[/snapback]
Neither is the case. It is in my front pants pocket as always. Guess I will have to run by Toyota sometime to see about it.
Old 03-11-2006, 10:04 PM   #6
DocToss
Have had my 06 for 2 months now, and just noticed the key light come on tonight. It happened after I was sitting in the car for 20 min waiting for my wife with the engine running. After she got in the light came on. I stopped and restarted and it went away. Then after opening the rear door it came on again for a short while. Let me know what toyota says.
DocToss is offline
Old 03-12-2006, 09:43 AM   #7
thundermustard
[snapback]223701[/snapback]
Problems like this are murder to get fixed because they are intermittent. Plus, it isn't a big enough problem to warrant a visit just for this. So, you might have to let me know.
Old 03-13-2006, 04:59 PM   #8
tmorrowus
You might try replacing the battery in the transponder just in case it's bad.
tmorrowus is offline
Old 03-14-2006, 12:34 PM   #9
hycamguy07
hycamguy07's Avatar
[snapback]224395[/snapback]
Ok now my stupid question, when the cars off and locked up there is a red flashing light that looks like a key...? is that like a anti theft warning light?
hycamguy07 is offline
Old 09-08-2008, 12:49 PM   #10
Alpinest
Send a message via Yahoo to Alpinest
Default Re: Key warning light on dash
I am having the same problem. When the car is off and the keys are nowhere near the car the key warning light flashes and continues to flash untill the car is started again at which time, when the car is on the key in car light stops illuminating. No problems with locking the car even when the light is flashing. When the key is actually in the car the car won't lock and the key in car light is steady instead of flashing. Any ideas?
Alpinest is offline
Automatic head light leveling system warning light mmirman Prius and Hybrid News 5 08-14-2007 08:23 AM
What's this Warning Light? Tatania Care, Maintenance and Troubleshooting 4 05-03-2007 06:41 AM
Dash warning light thomascox Prius Main Forum 3 12-20-2006 03:37 AM
SKS warning light sometimes comes on ohgreys Care, Maintenance and Troubleshooting 5 08-18-2006 07:31 AM
WARNING!! Isopropyl Alcohol caused dash discoloration hybrid4earth Care, Maintenance and Troubleshooting 6 03-17-2005 12:45 PM
