| Audio and Electronics This is a discussion on Need a Wiring Harness for a JBL system....and a radio question. within the Audio and Electronics forums, part of the Toyota Prius Forums category; Well, my dash is apart, bought a radio and now I'm urgently trying to find a brick and mortar retailer ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Well, my dash is apart, bought a radio and now I'm urgently trying to find a brick and mortar retailer that carries a wiring harness for a JBL 04' Prius. I've searched the web and this forum and the likely candidate seems to be one manufactured by Bazooka for their self powered subwoofers. http://www.bazooka.com/product_feature.asp?id=298&pg=2 I just wanted to know if anyone has had any experience with this harness or knows of any other one that would work with a JBL. I'm in a bit of a rush as of my dash being torn asunder and would prefer a solution asap. I'm curious about dealers too, would they have a compatible one in stock? I picked up this dash player very cheaply at Wal-Mart last night, $80. http://walmart.scosche-cars.com/products/?...oductID=4744710 http://www.vr-3.com/vr3_cdplayers.php I had just bought a JVC kd-g820 minutes earlier but what attracted me to this model was not only a usb front port but also a SD slot and a front line in jack. Has anyone heard of this company and will it be an incredibly substandard product compared to the JVC....? http://www.crutchfield.com/S-8veasw6Nt7E/c...257KDG820&wm=su Many thanks! |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(falcinator @ Apr 23 2006, 07:13 AM) [snapback]243932[/snapback]</div> Quote:
![]() Attached is a picture of using the harness for a purpose other than what it was originally intended. I've cut into all twelve of the speaker leads so I can tap the signal out of the JBL amp to drive another amp with line level inputs (lower JBL connector), then tapped back into the harness (upper JBL connector) so the output of the other amps can drive the speakers using the factory wiring (except for the rear doors, since there are new crossovers mounted inside).
__________________ 2009 Toyota Camry Hybrid Black (hers) JBL Audio, Bluetooth, Moonroof, Alloy Wheels, Pink Fuzzy Dice on rearview mirror 2005 Driftwood Pearl Pkg #6 (mine) Katzkin Leather Interior Diamond Audio D661s Component Speakers JL Audio 8W3 Subwoofer JL Audio CleanSweep CL441dsp MTX Thunder 564 Amp 4x100 watts MTX Thunder 421D Amp 1x300 watts OEM Sirius Tuner 2004 Super White Pkg #9 (hers) - sold | |
| Plug and play trailer wiring harness (almost) | priussoris | Prius Technical Discussion | 5 | 03-27-2008 12:16 PM |
| Fog light wiring harness | dgooden8 | Prius Modifications | 8 | 08-25-2007 09:13 AM |
| Wiring Harness for '07 non-jbl? | Sillyboy | Audio and Electronics | 3 | 03-14-2007 01:51 AM |
| Question on Stock Radio Harness? | akrca4 | Audio and Electronics | 0 | 03-07-2006 11:12 PM |
| Concerns in having Toyota add 12v wiring harness | PsyPrius | Prius Modifications | 1 | 02-14-2006 03:53 PM |
