| Audio and Electronics This is a discussion on 2006 Prius and Bluetooth Battery & Signal meter within the Audio and Electronics forums, part of the Toyota Prius Forums category; Hi everyone, I currently have a Nokia 6256i on Verizon. I have it paired with my Prius and it works ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi everyone, I currently have a Nokia 6256i on Verizon. I have it paired with my Prius and it works (for the most part); I was able to push over my address book with it (one contact at a time). As far as the phone itself is concerned, I HATE IT. It is completely counter-intuitive and I always have a weaker signal (regardless of how many bars show) than other Verizon phones, not too mention an insane amount of dropped calls. And I know it's because of the phone because I was using an older (less fancy) phone before this in the very same area with no problems (it just didnt have BT) In addition to all this, it does NOT show anything on the Bluetooth Battery/Signal meter on the Prius' screen. Keeping all the above-mentioned facts under consideration, I am getting myself another Verizon phone. I don't need anything exceedingly fancy and I don't really require that it be able to push over the address book (although it would be nice) since mine is already in the Prius. All I need is a phone that will work efficiently with the Prius and ALSO SHOW the battery and signal status ON THE PRIUS. Since Verizon is notorious for disabling many BT features on their phones, I realize I will most likely not be able to get a phone that can do both: update the BT Status bars on the Prius Screen AND be able to push over the Contacts. Also, I do not want to get a Motorolla Razor...Too many people I know have it. So to all those who are currently using Verizon phones...if yours can do what I am looking to do above, PLEASE let me know! Thanks! |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | In my 2006 I have tried the RAZR and the E815. Both show the BT/Signal/Battery bars just fine. Those are the only phones I have direct experience with. Neither can transfer the phonebook in stock form. I have Alltel firmware on my RAZR, so I can do it one at a time, just like your Nokia. I have used it once, I generally find it eaiser to type them in on the MFD. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have a Blackberry and it works great! After the initial paring which was very easy, it has worked flawlessly! The only thing I haven't been able to figure out is how to download my Address Book to the Prius. I probably haven't spent enough time reading the "How To"! |
| | #5 | |||
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(pabhouse @ May 10 2006, 08:47 AM) [snapback]252688[/snapback]</div> Quote:
I have always liked the VX9800...maybe I will go with that... quick question about that while I'm at it. You have it on Verizon I presume...can you browse the web on it (when it opens up on that horizontal screen), and if you can, does that ONLY cost you airtime minutes? I don't really have a data plan in place but end up with tons of extra airtime minutes every month. Thank you! <div class='quotetop'>QUOTE(ttabbal @ May 10 2006, 12:55 PM) [snapback]252854[/snapback]</div> Quote:
Also, yeah, that one contact at a time does seem to get a bit tiring...How did you get Alltel firmware on it though? Does that affect how you use the phone on Verizon at all? Just curious... <div class='quotetop'>QUOTE(YBLee @ May 10 2006, 04:29 PM) [snapback]253044[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | For installing the Alltel firmware there is a wiki linked at howardforums.com in the Motorola section of the Verizon forum. It's a bit involved, but everything seems to work fine. The big difference is that I don't have the stock Verizon menu, it's the Motorola menu now. As a result, the phone is much faster and has all the capabilities of the other RAZR phones from other carriers. If the situation hasn't improved with Verizon crippling phones when my contract is up, I may have to reconsider them. They have the best network, but the phones are starting to become "least common denominator" with all of them having the same menus and features. |
| Member Join Date: Nov 2005 Location: Oceanside, CA
My Car: 2005 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I work for Verizon and I get to see all the internal reports of customer service and what we are doing right/wrong. If you are looking for the phone with the best signal and longest battery life, the Motorola E815 is the best one we currently offer, if you do not require a PDA/Smartphone. I have helped a couple of people pair their phones with their cars, including a VX8100 to a Prius, a Motorola Razr V3c to a BMW X5, and my Prius to the E815. Of all of them, the Prius to the E815 gives the best signal strength and battery life. Not to sound like a salesman, but that phone is now available for $50 after the rebates. I bought it, at the employee price, when it was $150 and I still feel it was well worth the money. Now if I could just get my concession phone switched over to an E815 or the upcoming Motorola Q.....
__________________ ------------------- Enjoy, Randal - Two fish are in a tank. One says to the other, "You drive, I'll fire the cannon." |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quick update... I ended up getting the LG VX9800 (called the "V" by VZW). I love the phone so far! The signal strength is great (compared to the 6256i, even though this one doesn't have an external antenna!). Also, it shows both the battery and the signal strength on the Prius MFD. I didn't really test to see if it will push over my contacts because I already have them on my Prius from the 6256i. The only thing the VX9800 has going against it is its size, since it is quite thick, even for a candy-bar phone. BUT I really don't need a small phone; the VX9800 fits fine in my pockets. So all in all, I am happy with my purchase... thank you to all those who helped! |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(AzizaVFR @ May 13 2006, 03:06 AM) [snapback]254650[/snapback]</div> Quote:
| Battery Meter Reading | BellaHMB | Prius Main Forum | 2 | 07-17-2007 11:29 AM |
| Bluetooth RAZR Cingular display battery meter and clid | hadman | Prius Main Forum | 0 | 06-07-2007 08:34 PM |
| What's the 4-bar +/- battery symbol above the Hybrid battery meter on the MSD? | seakykr | Prius Technical Discussion | 6 | 10-20-2006 03:39 PM |
| Bluetooth and 2006 Prius | OldProf | Prius Main Forum | 17 | 02-17-2006 09:45 AM |
| Battery on the MFD Battery Meter | JShorr | Care, Maintenance and Troubleshooting | 11 | 01-05-2005 03:52 PM |
