| Audio and Electronics This is a discussion on Where can I get more DC Power within the Audio and Electronics forums, part of the Toyota Prius Forums category; I have an 05 Prius. I want to be able to power my Laptop by the car. But the cigarette ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have an 05 Prius. I want to be able to power my Laptop by the car. But the cigarette lighter will not give me enough power. So I want to add a higher capacity power outlet. Does anyone have any suggestions as to where to draw the power from. The battery in the right rear corner is the obvious choice but if there was a good spot in the front half of the car it would save a lot of work. Since I know someone will ask, the computer is a Dell E1705. The power supply is rated at 90 Watts. I am using a DC -> AC converter rated at 200W. This works fine in the cigarette lighters in my other 4 cars but not the prius. The cigarette lighter outlet on the Prius is labeled as capable of 100W(or was it 120) so it should be fine as it is. But it doesn't. When I plug the computer in, it gets pulses of power lasting about 3 seconds before cutting out. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The Dell may be able to run straight off 12V. I had a dead battery pack for mine, and after pulling the cells out of it simply wired a 12V plug and a wire into the right contacts ... I clip that rig in where the Li-ion pack ordinarily goes and the lappie runs fine off 12V. The battery's nominal voltage is 11.1 or so, but the power regulation inside the lap deals with 14V fine and in fact winds up drawing *less* current as a result. . If you need a beefier connection for your inverter, though, http://techno-fandom.org/~hobbit/pix/prius-ferrups.jpg http://www.priups.com/misc/intro.html http://hiwaay.net/~bzwilson/prius/priups.html . _H* |
| Senior Member Join Date: Mar 2006 Location: Cambria, CA, USA
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Chances are there are heavy losses in all that power conversion, which causes higher than expected current draw. You're converting 12vdc to 120vac, then back to low-voltage dc (maybe even 12v!) The 90w power supply is perhaps 75% efficient. Assuming 90w is the output spec for it, then it needs well over 150w of input to produce its rated 90w for the computer. The inverter is probably 50-75% efficient, so to produce 150w it needs well over 300w. The two conversions are costing big time. As hobbit suggested, it's far more efficient to get rid of all the conversions and feed 12v directly to the computer. (Assuming that's what the computer needs, of course.) |
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Have you considered buying a cigarette-lighter adapter for the computer? These devices usually use DC-DC converters, which can be more efficient than what you're currently trying. Sure, it'll cost some money, but it beats trying to run wires under carpets all through the car. If you do connect to the 12v battery, be sure to include a proper fuse. |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(hobbit @ May 24 2006, 07:10 PM) [snapback]260673[/snapback]</div> Quote:
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'll just have to chalk that up to the efficiency of the Mac's design vs. the Dell. That oughta start a little skirmish... |
| Junior Member Join Date: Mar 2006 Location: Croatia
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(acroporas @ May 25 2006, 03:55 AM) [snapback]260668[/snapback]</div> Quote:
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(vlenac @ May 28 2006, 11:45 AM) [snapback]262076[/snapback]</div> Quote:
| No Power & Bad Tow | lisamarie05 | Prius Technical Discussion | 20 | 06-08-2007 11:09 PM |
| Power Outlets | casinada | Knowledge Base Articles Discussion | 8 | 05-11-2007 10:24 PM |
| Power tie-in | benlenz | Prius Modifications | 1 | 03-02-2007 10:21 AM |
| Power of Nightmares | dragonfly | Fred's House of Pancakes | 66 | 11-03-2006 01:52 PM |
| Net power = Engine power + Battery Power ? | theorist | Prius Technical Discussion | 11 | 05-29-2006 08:15 PM |
