| Audio and Electronics This is a discussion on VAIS SLI Installation Notes within the Audio and Electronics forums, part of the Toyota Prius Forums category; Here are some notes from my experience installing and using a recently-purchased VAIS SoundLinQ SLI adapter in a 2006 Prius ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Here are some notes from my experience installing and using a recently-purchased VAIS SoundLinQ SLI adapter in a 2006 Prius with navigation system. I've used the SLI with several iPods: a 4GB iPod Nano, a 40GB iPod Photo and a 4GB iPod mini. I've installed SLI units in my blue Prius and in a friend's 2006 silver Prius. The SLI is set up as a CD MP3 player, per the instructions. What always works:
I've struggled to move the "sometimes" features into "always" features. I've limited the iPods to fewer than 10 playlists and limited each playlist to fewer than 100 songs. I've added songs to the auto-generated "On-the-go" playlists to eliminate empty playlists (this is a pain in the rear to remember after every iPod sync). These steps result in what I think of as a squeaky-clean iPod. I've changed the baud rate on the VAIS unit and reset the iPod. The only technique that seems to work is to reset the SLI using its DIP switches (both switches up, start car, wait for beeps, turn car off, left switch down, right switch up, wait 10 seconds, start car, connect squeaky-clean iPod, select CD MP3 audio source). I believe, though, that an empty playlist in the iPod (such as that nasty "On-the-go" playlist) can make the SLI intermittent once again, and the steps in the previous paragraph will not effect a reliable cure. You gottta do an SLI reset. Things I've learned that aren't documented in the manual: - Activating the "Scan" button tells the Prius computer to leave the Audio screen on: it won't time out and jump back to the "Info" screen. - The SLI appears to keep a pointer to the current playlist and file track in its memory. If I sync the iPod and change the order of songs in the playlist, the SLI resumes play at the same file index point (the 14th song, for instance), even if the track has changed since the last session. And if I reset the iPod, the SLI still resumes play at the last index point, so it's not dependent on iPod memory. I'd appreciate corrections or additions to what I've found. I'm not an iPod scientist and I suspect that some of my conclusions could be bad guesses. -- Pete |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I think you pretty much nailed it. I'm having the same issues with mine. When I can see my playlists I can only see the first 47. I have a 60GB iPod that's almost full, I hate playlists but created one per artist just for the SLI and now it doesn't even see past #47 I have over 200! I'm seriously thinking about just sending it back and getting my money back.. I was hopeing for so much more for as much as they're charging for this thing. ![]() |
| | #3 | ||
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(petej @ Jul 10 2006, 09:31 PM) [snapback]284186[/snapback]</div> Quote:
Thanks Bob <div class='quotetop'>QUOTE(mabrown @ Jul 10 2006, 09:52 PM) [snapback]284193[/snapback]</div> Quote:
http://www.vaistech.com/forums/index.php They are normally very responsive and should be able to help you find an answer. Bob | ||
| my other Mobile Suit is a ... Join Date: Feb 2005
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(petej @ Jul 10 2006, 06:31 PM) [snapback]284186[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(BobR @ Jul 11 2006, 07:25 PM) [snapback]284740[/snapback]</div> Quote:
[attachmentid=4123] If you click the Folder List button, this is what you see (you can use the up and down arrows to scroll to more folders if you got 'em): [attachmentid=4125] If you click the File button, here's what you see: [attachmentid=4127] And now if you click the Detail button, this appears: [attachmentid=4128] That is, if it's all working OK. Often the Folder List button does not appear at the top level. When it appears, you can navigate to the more detailed levels. --Pete | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | From reading a post from VAIS tech support, I just realized something that was not obvious to me: the Prius software prevents the Folder button from working while the car is in motion. Duh. So my secret theories about baud rate mismatches, empty playlists and other glitches are baloney. The VAIS unit is constrained in similar ways to some of the Phone and Nav functions. From re-reading the VAIS documentation, it seems that there's a way to set Artist as the primary display element. I'll have to experiment with this... |
| VAIS AIC-100i Installation Guide | Tideland Prius | Knowledge Base Articles Discussion | 0 | 09-04-2007 02:46 AM |
| Sirius VAIS installation | mjay | Audio and Electronics | 1 | 03-10-2007 08:19 PM |
| VAIS plus satellite installation issues | alanmushnick | Audio and Electronics | 1 | 10-18-2006 12:55 PM |
| VAIS installation in a 2006 is done. | DocVijay | Audio and Electronics | 17 | 01-22-2006 10:01 PM |
| 1-Year Anniversary (almost) notes | efusco | Prius Main Forum | 6 | 10-04-2004 08:23 AM |
