Audio and Electronics This is a discussion on GREAT NEWS! itunes7 can burn CDtext! easy song titles! within the Audio and Electronics forums, part of the Toyota Prius Forums category; apple introduced itunes7 today and one of the undocumented features is a new checkbox in the advanced/burning section of the ...
Old 09-12-2006, 02:40 PM   #1
konakahuna
konakahuna's Avatar
apple introduced itunes7 today and one of the undocumented features is a new checkbox in the advanced/burning section of the application preferences that enables cdtext!
now you can burn discs from itunes with titles that the prius can read
WOOHOO!
it's a free download.
d
konakahuna is offline
Old 09-12-2006, 02:45 PM   #2
eagle33199
Platinum Member
Definately good to know... although i think i'll still keep myself CD-less and stick with the iPod.
On the positive side, yesterday i figured out how to stream iTunes from my house to my work computer, which means i don't have to drag my iPod out of the car every day to take it into work with me.
eagle33199 is offline
Old 09-12-2006, 02:58 PM   #3
isnoface
Really? Tell us how to get in on this streaming goodness.
isnoface is offline
Old 09-12-2006, 03:22 PM   #4
eagle33199
Platinum Member
Disclaimer
Follow these directions at your own risk. the author is not responsible for any harm you may do to yourself or your computer by attempting them. Read all instructions before beginning. if you do not have the knowledge or experience with computers in order to safely perform all procedures, it is recomended you don't attempt them. following these instructions could cause you to make your computer more open to malicious software and individuals.
Do the following at home:
0. Your windows account at home must have a password set for this to work. So create a password if you don't already have one. Plus, every list should start with 0. :-p
1. download an SSH server (http://sourceforge.net/projects/sshwindows) and install. To set up, go to the command prompt and browse to the directory where it installed (usually C:\program files\openssh\) and then the bin directory (so with the default settings you would type "cd "C:\Program Files\OpenSSH\bin""). From there, type in "mkgroup -l >> ../etc/'group" and "mkgroup -l >> ../etc/passwd" (those are lower case L's). Right click on My Computer and go to manage. In the screen that pops up, expand out the bottom choice (Services and Application) and select the services option. On the right side of the window, scroll down to OpenSSH and select it, then select start to start the service (I believe it'll automatically start up with windows after this).
2. Do you have any firewalls installed? If so, you'll have to open two ports for the firewall - port 22 and port 3689. for specifics on this, I'd refer you to the firewall's producer (although I could figure it out for ya in like 5 min or less if I was sitting there)
3. are you using a router between the cable modem and your computer? If so, you'll have to do port forwarding for the above listed ports. While routers do differ, generally you can go access the settings from http://192.168.0.1 (or 192.168.1.1, etc depending on the brand, check your ip address on your computer and go with whatever that is replacing the last number with a 1) and from there find the port forwarding options. Note - you'll have to reserve an address for your computer or have your computer set a static IP in order to ensure it's always forwarding to the IP your computer is on.
4. Download a free DNS service. These can be found at dyndns.org or no-ip.com. Sign up, download their application and run it in the background, with whatever URL you want (mine's eagle33199.servebeer.com). That way you'll have a static address always pointing to your dynamic IP.
5. Enable file sharing in iTunes (and leave iTunes running). Go to edit->preferences, the sharing tab, and select the "share my music" option.
At work now:
6. install iTunes (duh).
7. install the SSH tunnel program, http://www.delight.ch/delight.ch/index.php?s=48 (click on "Herunterladen" to download). After installing, run it. Go to tunnel->add and put in the following information:
-SSH Host: whatever you picked as your URL
-SSH Port: 22
-Local Port: 3689
-Remote Host: 127.0.0.1
-Remote Port: 3689
-Username: your windows username
-Password: your windows logon password
-SSH Key File: Leave this blank
-Forward: Local to Remote
-Auto connect: on if you want it to connect when the program is started
-Compression: on
-Do Keep-Alive-Ping: off, unless you experience problems with it dropping
-SSH1/SSH2: SSH2
Hit test, it should say its fine, and then hit save. Double click the icon there with whatever name you gave it, and a padlock will appear on it when it connects. minimize it to the tray.
8. download http://ileech.sourceforge.net/index.php?co...sProxy-Download and install. This program tells iTunes to look at the tunel for shared music. Run it and click add host. Put in the following info:
-IP address: 127.0.0.1
-Port: 3689
-Host Label: Whatever you want it called
-Service Text: Leave blank
-Service Type: _daap._tcp.(iTunesHost)
Once set up, minimize it to the tray.
9. if your work computer has a firewall, you'll need to open port 3689.
10. Enjoy your music!
Given the disclaimer above, do at your own risk. Opening the ports in any firewall you may use, or forwarding them from your router will make you more vunerable than you were before, however, at the time of this post, i am not aware of any malicious code that will exploit this. always use secure passwords (No, your dogs name concatonated with your son's birthday doesn't count. get something completely random, like 4&fl!d9).
Also, while streaming music from your home computer to your work computer for personal use is perfectly legal (assuming you purchased the music to begin with), giving others the username/password and sharing the connection wouldn't be legal (as it goes beyond personal use).
Old 09-14-2006, 05:20 PM   #5
4chi
4chi's Avatar
Send a message via AIM to 4chi
<div class='quotetop'>QUOTE(konakahuna @ Sep 12 2006, 02:40 PM) [snapback]318478[/snapback]</div>
WOOHOO!
d
Kona, exactly which checkbox should I check? Is it the Mp3 Cd option or is it the Data CD option, or is it neither?
I burned one yesterday to try it out and it will give me song name but not artist.
And also, say i Burned 6 albums onto one MP3 disc, can I make folders for each album? I'm a bit confused on all of this.
4chi is offline
Old 09-14-2006, 11:45 PM   #6
konakahuna
konakahuna's Avatar
<div class='quotetop'>QUOTE(4chi @ Sep 14 2006, 05:20 PM) [snapback]319729[/snapback]</div>
okay....
from itunes preferences, choose ADVANCED > BURNING > "INCLUDE CD TEXT"
that should have it!
Old 09-15-2006, 11:17 AM   #7
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
I installed it last night, but decided to switch back. I really preferred the interphase of itunes7, but was now unable to sync my calendar with the iPod. Since that meant giving up something I used for something I might never use, it was best for me to drop back.
Pity, I really liked itunes7. They've added movies and games to the iPods store, which requires itunes7.
aaf709 is offline
Old 09-15-2006, 05:29 PM   #8
konakahuna
konakahuna's Avatar
what calendar are you having problems syncing your ipod to?
just curious.
d
Old 09-15-2006, 05:38 PM   #9
aaf709
aaf709's Avatar
<div class='quotetop'>QUOTE(konakahuna @ Sep 15 2006, 02:29 PM) [snapback]320258[/snapback]</div>
just curious.
d
Microsoft Outlook 2000 (and it won't work with Thunderbird). If you have the 2003 version, it works, but not an earlier version. I could either spend $100 and get that version, remove all of the announcements (and just use it as a calendar) or go back to itunes6.
It's a minor thing, but I can now sync the calendar with both my iPod and my e815, and it's nice to be able to check if the weekend is free.
"Blue Belle" Seaside Pearl
Purchased April 16, 2005
MODS:
Wheelskin Steering Wheel Cover, GT Seat Covers, DashTopper Dash Cover, MFD Sun Hood, Pioneer AirWare XM radio, DICE Silverline iPod Integration, BT Override, Goodyear ComforTreds, Coastal Tech's Auto-Lock kit, NAV Enhancement kit & EV mod
aaf709 is offline
Old 09-16-2006, 11:57 AM   #10
BobR
WOOHOO!
d
This is a great find, thanks for pointing it out! I've been using Toast to make discs with CD-Text. It will be much easier to use iTunes. What took them so long to add this?
BobR is offline
Great and Easy Installation! XM on 2007 Prius bobiii Audio and Electronics 2 07-31-2007 11:29 PM
Great News for Canadians! dzoutzidis Prius Main Forum 25 04-25-2007 12:53 PM
What would be more offensive? To burn the American Flag or to burn the bible? burritos Fred's House of Pancakes 96 10-25-2006 02:36 AM
CD changer won't display song titles jpoel Audio and Electronics 11 07-07-2006 10:46 AM
Great Environmental Song! eyeguy13 Environmental Discussion 0 05-01-2006 12:02 AM
