Audio and Electronics This is a discussion on DICE Prius iPod Integration Unit now works for the 2006! within the Audio and Electronics forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(noelty @ Jul 11 2007, 12:39 PM) [snapback]477045[/snapback]</div> I'll look for it...can you clarify the dip switch position I ...
Old 07-11-2007, 04:27 PM   #501
Vagabond
Vagabond's Avatar
Send a message via AIM to Vagabond Send a message via Yahoo to Vagabond
I'll look for it...can you clarify the dip switch position I should have on my DICE unit. 07 Prius with Nav, and XM...all four switches are currently in the up position.
No good, some things are not going to work - use MP3 mode or SAT mode. On the first set of DIP switches, MP3 mode is UP/DOWN and SAT mode is DOWN/DOWN. See what you like best.
Vagabond is offline
Old 07-11-2007, 04:57 PM   #502
noelty
noelty's Avatar
Send a message via AIM to noelty
Installed...need to tighten things up a bit, but it is working...except for the Artis, SOng and Album info is not displayed. I am using a playlist...I set the dip siwthces to MP3 mode...not sure what I need to do.
*EDIT* Figured it out...set the dip switches to SAT and now I have Artist and Title...yay!
noelty is offline
Old 07-11-2007, 05:51 PM   #503
Vagabond
Vagabond's Avatar
<div class='quotetop'>QUOTE(noelty @ Jul 11 2007, 01:57 PM) [snapback]477088[/snapback]</div>
If you're happy with SAT mode by all means use it. Check the PM I sent to you a little while ago about making sure text works on MP3 mode as well if you like.
Vagabond is offline
Old 07-12-2007, 12:24 PM   #504
noelty
noelty's Avatar
<div class='quotetop'>QUOTE(Vagabond @ Jul 11 2007, 02:51 PM) [snapback]477124[/snapback]</div>
Thanks for all your quick answers and support...I got it installed and everything seems to be working fine. The only issue I have, has to do with the little storage box just below the stereo...I wanted to keep my iPod there...I found directions, however my drill bits are not long enough and I don't know how to remove it. I bought grommets for the hole but no DICE (ha). For the time being the iPod is in the glove box. I also think I may have slightly stripped the bolt above the white box...no biggie...it is pretty tight with a little give but so far no issues...as for the number on the back of my DICE unit...54.
Here are some shots...
Temporary iPod location:
DICE unit firmly attached to white box via velcro:
Another shot:
Display:
ANother shot different screen:
I was really surprised how easy it was to install...at first I was afraid my hands were too big and that i might screw something up...but in hindsight, as usual, it was easier than i thought.
I just need to RTFM to figure out how to scroll through playlists...I have been a stickler for Smart Playlists since day one and have tons of them...because there is no support for playlist text I guess I will have to select directly from the Ipod at this time...hopefully there will be a fix sometime down the road.
2007 Metallic Silver Package 6 Touring Edition
Visit My Webpage nkpix
noelty is offline
Old 07-28-2007, 09:28 AM   #505
Nominated 1 Time in 1 Post
Friends: 26
For an Ipod novice I'm really pleased with my DICE so far. I think I broke the bottom pin on the white junction box as it now flops around loosely (probably need to secure it if it starts rattling...I'm a freak about rattles).
I do wish the playlists showed up on D2 though b/c I've got 50 or 60 of them so far and it'll be a pain trying to guess which one I'm on. Thanks to Nick/Vagabond for the quick call back when I thought I was having troubles.
efusco is online now
Old 07-28-2007, 01:10 PM   #506
mr_zorg
mr_zorg's Avatar
<div class='quotetop'>QUOTE(noelty @ Jul 12 2007, 09:24 AM) [snapback]477544[/snapback]</div>
<div class='quotetop'>QUOTE(efusco @ Jul 28 2007, 06:28 AM) [snapback]486632[/snapback]</div>
Yeah, it's a bit of a bummer. Read this thread for my solution to the "problem":
http://priuschat.com/index.php?showtopic=30514&hl=
mr_zorg is offline
Old 07-28-2007, 01:17 PM   #507
Friends: 26
<div class='quotetop'>QUOTE(Mr. Zorg @ Jul 28 2007, 12:10 PM) [snapback]486706[/snapback]</div>
I read that, I'm pretty new to the Ipod and it scared me a bit, wasn't sure what I was getting into with that. Maybe I'll take another look when I've got time to study it as it would be nice to have a solution for the playlist thing. Right now I'm in the K.I.S.S mode!
Old 08-03-2007, 04:55 AM   #508
growltiger
Send a message via AIM to growltiger Send a message via Yahoo to growltiger Send a message via Skype™ to growltiger
First of all, kudos to the PriusChat shop. I had my DICE in hand before a week had passed after my order. In fact, I was just about to enter the tracking label when the post man rang. Well done.
<div align="left">I went through the trouble of disassembling the dash and then drilling from behind the storage box. I do not own a 15/32 drill bit, so I used a 7/16 bit and then, at slow speed, rotated the drill to get the hole to a size that would accommodate the plug. Since I installed my XM Radio I was able to muster the patience and courage to do the tear down and reassembly.
In the past I had used one of those cup holder platforms to hold my nano iPod. But I am happier with this new arrangement. I can finally put that little storage box to good use. When I am in DICE mode, I can see the screen light up through the smoked front panel.
I should note that I still have one more task before I complete my installation. I have not secured the DICE unit yet. I wanted to try out the MP3 dip switch setting (if memory serves, down-up-down-down) before putting the unit out of sight and hand. My display is like noelty's above here. Although I have playlists, all I see is the artist's name repeated for the number of songs when I am in the list view (sic). I suppose I need to spend time with the manual, too.</div>
growltiger is offline
Old 08-03-2007, 09:40 AM   #509
Friends: 26
<div class='quotetop'>QUOTE(Growltiger @ Aug 3 2007, 03:55 AM) [snapback]489847[/snapback]</div>
<div align="left">I wanted to try out the MP3 dip switch setting (if memory serves, down-up-down-down) before putting the unit out of sight and hand.
[/b][/quote]
If I'm not mistaken the DIP settings for the '06 are the opposite of what you said...iow I think they're supposed to be up, down, up, up....but double check, don't take my word for it.
Old 08-04-2007, 03:29 PM   #510
growltiger
<div class='quotetop'>QUOTE(efusco @ Aug 3 2007, 06:40 AM) [snapback]489899[/snapback]</div>
<div align="left">Yes, sir, I had it exactly backwards in my post although not in fact. Which is a good all things considered. So my memory did not serve me well. Thank you for the correction.
I have a new question, but first the background. The DICE is working to my satisfaction so I took the next step tried to secure the unit next to the big box of wires to the left (as you gaze upon it) of the glove box. What I found is that there was not sufficient travel for the glove box. There was some interference. So much for that idea and the velcro strips that went with it.
I found that I could stash the unit in the compartment immediately above the bottom glove gox and behind the top glove compartment. That had been the resting place of my XM Radio cable, so I stuffed that cable above the DICE unit and that seems to keep both in place. That hidden tray is not flat; there are ridges and so I cannot get a clean velcro attachment in there. It feels snug and in place. The bottom glove box now travels without impediment.
Now I must ask if I am inviting trouble by doing this? I would rather have a firm attachment but I cannot find a good place to get it. For the time being this works. But I am open to suggestions on how to improve this. Thanks in advance for any clever ideas.</div>
ICE LINK PLUS IPOD INTEGRATION UNIT FOR SALE Syclone Private Sales 7 06-29-2007 08:38 PM
DICE iPod Integration Unit now for sale in the Shop! Danny Sponsored Commercial Sales 16 04-27-2007 02:51 PM
SOLD - FS DICE iPod Integration Unit for 2006-2007 Prius - SOLD pre-cbs Private Sales 1 02-22-2007 11:07 PM
iPod MFD Integration Unit Group Buy Danny Audio and Electronics 503 10-27-2006 03:54 PM
