| Audio and Electronics This is a discussion on Steering wheel buttons don't light up within the Audio and Electronics forums, part of the Toyota Prius Forums category; My lights on my steering wheel don't work anymore...not that they were actually bright enough to be seen anyway, but ... |
| Senior Member Join Date: Jul 2005 Location: Los Angeles, CA
My Car: Other Non-Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | My lights on my steering wheel don't work anymore...not that they were actually bright enough to be seen anyway, but I'd like them alive again. They are still perfectly functional so I'm guessing it may be just a fuse. Any pointers on which fuse to look out for? |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | Does the panel dimmer change the lighting on the wheel buttons? I can't remember without looking. Try rolling the dimmer wheel to a brighter setting and see if it helps. Tom |
My Car: Other Non-Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(qbee42 @ Nov 15 2006, 08:32 AM) [snapback]349431[/snapback]</div> Quote:
| Member Join Date: Sep 2006
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(silentak1 @ Nov 15 2006, 10:05 AM) [snapback]349530[/snapback]</div> Quote:
Speaking of the dimmer switch-- Is the dimmer switch supposed to light up? It seems everything on my dash dims or brightens, but the dimmer switch! <_< Joe | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(silentak1 @ Nov 15 2006, 12:53 AM) [snapback]349335[/snapback]</div> Quote:
Had the same problem. Dealer replaced the Reostat (sp??) and works fine now | |
My Car: Other Non-Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Serenity Now @ Nov 15 2006, 12:34 PM) [snapback]349594[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(silentak1 @ Nov 15 2006, 12:14 PM) [snapback]349633[/snapback]</div> Quote:
any luck i am having the same problem?? | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Ricky Zinter @ Jan 26 2007, 02:50 PM) [snapback]381352[/snapback]</div> Quote:
swapped out the fuse all good now | |
| steering wheel dark | psikot | Audio and Electronics | 11 | 01-09-2008 07:42 PM |
| Buzzing under steering wheel | tnymntna | Care, Maintenance and Troubleshooting | 2 | 06-13-2007 06:50 PM |
| Steering wheel buttons question | imported_josh_ | Prius Main Forum | 20 | 01-11-2007 01:27 PM |
| Steering Wheel misalignment | Mr. C | Prius Technical Discussion | 4 | 09-14-2006 12:30 PM |
| Secret Steering Wheel buttons? | naterprius | Audio and Electronics | 3 | 03-10-2005 08:18 PM |
