| Audio and Electronics This is a discussion on Sirius antenna under shark fin antenna within the Audio and Electronics forums, part of the Toyota Prius Forums category; Originally Posted by Rokeby Skwyre7, Two quick questions about the OEM antenna base: Did you happen to notice how long ... |
| | #11 | |
| What's the catch? Join Date: Apr 2006 Location: Richmond, VA
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Quote:
| | #12 |
| Member Join Date: Mar 2008 Location: SoCal
My Car: 2005 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | fyi, i have been installing sirius this weekend and getting that wire to go through the antenna base has been the biggest pita of the whole job. i finally got everything done, but then sirius did not work as the wire was pinched. in my opinion, it is necessary to notch out the sheet metal at the rear of the mounting point so that the sirius wire does not need to bend at such an extreme angle and get pinched. I used my dremel tool to do this then covered it with touchup paint. a total pita, but it will be nice to have sirius and the shark fin should look nice. |
| | #13 | |
| Junior Member Join Date: Oct 2007 Location: Jefferson City, MO
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Quote:
I did the same install last weekend and like to never thought I would get it done. I pinched the Sirius wire pretty good to, but lucked out, as it still works. I ended up cutting out the plastic from the center of the antenna nut and threading the Sirius wire thru the nut instead of using the guide for the whip antenna wire. It seemed to give everything a bit more room. But, for the life of me I couldn't thread the nut back on. The antenna pushed up just enough to not let me catch the threads, and I had nobody that could help. That is, until I found some painters tape to hold it down topside and finally it threaded. I put a tiny amount of black sealant around where the Sirius antenna comes out from the base of whip. Hopefully, it will keep any water out, as the shark fin won't be in for a few weeks. But, it should look great when finished!
__________________ Dale Silver Pine Mica, Bisque leather, Black Weathertech FloorLiners, Sirius Connect SCC1 and Toy-SC1 | |
| | #14 | |
My Car: 2005 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
I finally pulled all the tape back off and put a thinner wrap on it and finally got it back on. i must have fought with it for at least 2 hours and came really close to damaging the headliner. totally frustrating as i expected the antenna to be the easiest part of the job! My back is still sore today form messing with it for so long... I also had to rip nearly the entire dash out to get the previous owner's shoddy xm add-on installation, but that 3x easier than the stupid antenna! I sure hope the shark fin looks good and doesn't cut out the sirius reception. if i have problems, I could easily see myself getting a sledgehammer out and beating the crap out of the whole mess.... | |
| Shark Fin Antenna | TheForce | Prius Modifications | 32 | 02-12-2008 03:17 PM |
| Shark Fin antenna prices going up $10 on 11/1 | Danny | Prius Modifications | 2 | 10-29-2007 12:57 PM |
| Shark Antenna | Alkurth | Audio and Electronics | 5 | 02-06-2007 05:56 PM |
| Shark Fin Antenna installed | Doxtream | Prius Modifications | 4 | 04-13-2006 04:04 PM |
| Shark Fin Antenna | ilovemyprius | Prius Main Forum | 1 | 03-15-2006 05:52 PM |
