Audio and Electronics This is a discussion on "Dial by name" within the Audio and Electronics forums, part of the Toyota Prius Forums category; I have a bluetooth phone and heve entered a "voice tag" for each of my phone book entries. However, I ...
Old 02-25-2007, 03:36 PM   #1
mjg216
I have a bluetooth phone and heve entered a "voice tag" for each of my phone book entries. However, I cannot get the system to recognize the "Dial by Name" command. It will only dial by number. It's probably something very simple, but I can't solve the problem. Can anyone gove me some help? Thanks.
mjg216 is offline
Old 02-25-2007, 08:00 PM   #2
Renocat
Renocat's Avatar
<div class='quotetop'>QUOTE(mjg216 @ Feb 25 2007, 03:36 PM) [snapback]396317[/snapback]</div>
Dial by name
In my 2006 package #7,this is what I do to use voice dial:
* Press the talk switch on the steering wheel and say "dial by name"
* Jill says "Dial by name has been chosen. After the screen has updated please press the talk switch"
* Jill says, "Please say the name"
* I say the name I have programmed to the number
* Jill says "Name chosen. Please briefly touch the talk switch or touch the off hook switch to dial"
* I press the off hook switch (telephone with receiver off the hook) and the call dials.
I hear the call dial, the person answers and I am good to go. I have dialed a name without touching the MFD, only the steering wheel.
The process is almost the same for dial by number, which I use to call a person that is not in my phonebook. There is one extra push of the talk switch, that seems like a glitch, but it still works.
When I have an incoming call, the radio cuts out, and I hear a generic ring through my car speakers, not my ring tone. Sometimes my phone will actually ring about a 1/2 a ring and then I hear the generic ring through the speakers. I haven't quite figured that one out yet.
You must have voice tags programmed to the numbers you have entered into the car's phonebook. If you have Verizon, you can't transfer your phone's phonebook, you will have to manually enter them one by one.
Renocat is offline
Old 02-25-2007, 11:55 PM   #3
Vagabond
Vagabond's Avatar
Send a message via AIM to Vagabond Send a message via Yahoo to Vagabond
Couple things; you have your voice tags in your phone, and when you press the voice command switch on the steering wheel, you're really talking to the car and the car only - you're not activating anything about the phone at all.
The post above is totally correct, except the car doesn't use voice tags - it can recognize the name you're speaking, no pre-recording needed.
Vagabond is offline
Old 02-26-2007, 03:19 PM   #4
Renocat
Renocat's Avatar
<div class='quotetop'>QUOTE(Vagabond @ Feb 25 2007, 11:55 PM) [snapback]396541[/snapback]</div>
I had to record a name for each entry in the car. When Jill says "Williams chosen" it is my pre recorded voice that says williams
Renocat is offline
Old 02-26-2007, 05:07 PM   #5
Vagabond
Vagabond's Avatar
<div class='quotetop'>QUOTE(Renocat @ Feb 26 2007, 12:19 PM) [snapback]396812[/snapback]</div>
Really? In the same voice the car uses and not the phone? Mine doesn't do that. But I have a 2005.
Vagabond is offline
Old 02-26-2007, 08:49 PM   #6
Renocat
Renocat's Avatar
<div class='quotetop'>QUOTE(Vagabond @ Feb 26 2007, 05:07 PM) [snapback]396874[/snapback]</div>
my (pre recorded on the voice tag) voice says "williams"
Jill(the car voice) says "chosen. Please briefly touch the talk switch or press the off hook switch to dial"
Renocat is offline
Old 02-28-2007, 10:16 PM   #7
Friends: 6
The 2006 allows voice tags in the car for each phone book entry. Works like a charm.
qbee42 is online now
Old 03-04-2007, 02:37 PM   #8
koa
Package: #8
I find if the car is parked the phone defaults to the say the number and you have to touch the screen to get dial by name. If I'm driving it seems to default to say the command and then I have the choice. A toggle would have been nice.
koa is offline
Old 03-04-2007, 03:12 PM   #9
Gadgetdad
Gadgetdad's Avatar
Package: #5 Touring
<div class='quotetop'>QUOTE(mjg216 @ Feb 25 2007, 12:36 PM) [snapback]396317[/snapback]</div>
You are not alone, this must be a bug in the 07. Mine doesn't respond to a mere press of the talk button, I must first push the off-hook dial button then the talk switch then Jill occasionally says, "please say a command" . Too often she skips to, "please say the number". Posters so far have either had the problem or don't but no real answers on how to fix it......
Does your's have navigation? Mine does not and I suspect the posters that have no issue with this also have the navigation unit.
007 Super White Touring#3 with: ScanGaugeII, BT Stiffening Plate, BT Strut Tower Brace, Sharkfin antenna, black mats, K&N air filter (winter only), EV switch and constant on power socket, window tint, Mobil 1 oil. Darrell's LED's custom lights, EBH, JBL component speakers in the front & Dynamated doors. Bazooka SubW, Mudflaps with extra screw, Cyron LED footwell lighting interlinked with dome light.
On the workbench: BT Skid Plate, Sound Dampening.
Gadgetdad is offline
Old 03-04-2007, 04:16 PM   #10
koa
Package: #8
<div class='quotetop'>QUOTE(Gadgetdad @ Mar 4 2007, 10:12 AM) [snapback]399974[/snapback]</div>
On my 06 I must press the off hook button first to get the voice button to work. No nav.
koa is offline
Can't use "Dial by Name" voice commands w/ BT and pkg 6? kashuba Prius Main Forum 5 07-17-2006 02:59 PM
Top 100 Toxic Polluters in U.S.<img alt="" src="chrome://easygestures/skin/xLink.png" style="border: 0px none ; margin: 0px; padding: 0px; display: in ghostofjk Environmental Discussion 0 05-12-2006 10:09 PM
