Audio and Electronics This is a discussion on DICE for iPod kills MFD twice within the Audio and Electronics forums, part of the Toyota Prius Forums category; I'm on my third DICE iPod integrator. The first two would quit working properly after a few days. The second ...
Old 06-02-2007, 09:43 PM   #1
jpoel
I'm on my third DICE iPod integrator. The first two would quit working properly after a few days. The second one killed my Multifuntion display (MFD) and Toyota replaced it under warranty. They were kind enough to install the THIRD DICE unit and it killed the MFD after a week. 2005 Prius with Nav system. I pulled the dome fuse today and the MFD came back to life, but I'm sure it will fail again soon with the g-d defective DICE unit. Has anyone tried the VAIS Technology iPod integrator? I'm going to send the DICE back for a refund. Tired of f-ing with it and all the hassles.
jpoel is offline
Old 06-02-2007, 09:52 PM   #2
priusFTW
priusFTW's Avatar
<div class='quotetop'>QUOTE(jpoel @ Jun 2 2007, 09:43 PM) [snapback]454140[/snapback]</div>
I bought the Vais Tech and have no problems. I had Dice and returned it.
priusFTW is offline
Old 06-02-2007, 10:23 PM   #3
V-Jim
<div class='quotetop'>QUOTE(jpoel @ Jun 2 2007, 08:43 PM) [snapback]454140[/snapback]</div>
Interesting timing, I bought the Vais and have had it for about 6 months and it is now broken. It has always had a few quirks, namely with scrolling through playlists and using forward and reverse through songs in a playlist (works sometimes, never works the way it does on the iPod, and sometimes just doesn't work, you scroll but when you let go it returns back to the song you were playing). Anyway, now it doesn't work right at all. When I first turn it on it might play for a few minutes but then it starts skipping around to different songs and eventually stops playing altogether. I checked the connections and they seem fine.
So I was thinking about whether I should get this fixed or look at something else. Sounds like Dice is the wrong answer. Never was thrilled with Vais but MUCH better than running my iPod through the stereo connector and not being able to control it from the NAV. Anything else out there?
V-Jim is offline
Old 06-03-2007, 10:10 AM   #4
BobR
<div class='quotetop'>QUOTE(V-Jim @ Jun 2 2007, 10:23 PM) [snapback]454157[/snapback]</div>
What version of the Firmware does your SLI have? My guess is that a firmware update will resolve your problems.
I originally had an AIC-100i and now have an SLI and SLX and never had a serious problem with any of them.
A lot of the "problems" are simply limitations of the radio.
VAIS now makes a SoundLinQ2 which costs less.
Bob
BobR is offline
Old 06-03-2007, 06:02 PM   #5
priusFTW
priusFTW's Avatar
<div class='quotetop'>QUOTE(BobR @ Jun 3 2007, 10:10 AM) [snapback]454338[/snapback]</div>
Bob
Yes, I agree you may need a firmware upgrade. I have had zero problems with my Vais Tech SLI and I use it both for my iPod and Aux In for my Pioneer Inno XM.
priusFTW is offline
Old 06-03-2007, 07:15 PM   #6
V-Jim
<div class='quotetop'>QUOTE(priusFTW @ Jun 3 2007, 05:02 PM) [snapback]454580[/snapback]</div>
I am an idiot. There I feel better. <_<
Sp as it turns out the problem with the skipping and not playing is my iPod! I just assumed it was the Vais because of the other problems and I guess I thought the iPod just wouldn't break. My bad.
So I will look into the firmware upgrade to solve the other problems with forwarding and reversing through playlists. But again I have to say, even with that issue it's way better than the option of running through the AUX jack with no control.
I'm off to get another iPod. Sorry for the bad information.
V-Jim is offline
Old 06-23-2007, 06:11 PM   #7
jpoel
Well, I returned my 3rd DICE unit for a refund and installed the VAIS unit. Works like a charm! Had it in for two weeks and no MFD freezeups. It is superior to the DICE unit in several ways (not to mention that it actually works all the time), mainly that you can control the unit from the MFD and the steering wheel. My DICE never allowed the MFD controls to work. So from the MFD you can change playlists quickly. Works great!
jpoel is offline
Old 06-23-2007, 07:11 PM   #8
priusFTW
priusFTW's Avatar
<div class='quotetop'>QUOTE(jpoel @ Jun 23 2007, 06:11 PM) [snapback]466990[/snapback]</div>
Congratulations!
priusFTW is offline
Old 06-25-2007, 12:43 AM   #9
LYLUVLY
Send a message via Yahoo to LYLUVLY
<div class='quotetop'>QUOTE(V-Jim @ Jun 2 2007, 07:23 PM) [snapback]454157[/snapback]</div>
I am not sure if I am on the same page as you guys . . . are you guys using the iPod for anything
but music? I am sure you are not watching videos [?] and my solution is sure lot cheaper !!
I do not own an iPod, but playing music has been no hassle for me whatsoever:
I made a music CD, specifically an MP3 music CD. One cd holds about 450 tracks. Of course, the
higher compressed tracks are small, so one can make CDs with 100 tracks for better quality.
So, I have 6 CDs in the storage compartment. Those 6 MP3 cds will play music non stop for me
from here [calif] to Seattle and back and never hear the same track more than once.
LYLUVLY is offline
Old 06-25-2007, 04:34 PM   #10
Black2006
<div class='quotetop'>QUOTE(LYLUVLY @ Jun 24 2007, 09:43 PM) [snapback]467486[/snapback]</div>
...Those 6 MP3 cds will play music non stop for me
This is good, but... no podcasts (great way to catch up with Meet the Press:-), no easy navigation by artist, album, genre, etc.. The iPod rocks, and once you've tried it, it's hard going back.
Black2006 is offline
DICE iPod Integration - No Dice ToddWess Audio and Electronics 15 11-28-2007 03:10 PM
DICE's HD Radio and iPod Kit Vagabond Audio and Electronics 71 11-23-2007 04:24 PM
Review of HD DICE and iPod kit Arroyo Audio and Electronics 1 10-22-2007 03:44 PM
Can I have DICE HD + iPod + XM with '07 Pkg 6? emtownsend Audio and Electronics 8 07-12-2007 04:16 PM
iPod in CD Storage Box with DICE kit. WolffSV Audio and Electronics 9 03-02-2007 02:50 AM
