Audio and Electronics This is a discussion on Hard wiring a ground loop isolator in '08 Touring within the Audio and Electronics forums, part of the Toyota Prius Forums category; Hello all, See as how I am putting off buying some sort of IPOD integration kit for a while. I'd ...
Old 04-16-2008, 01:35 PM   #1
david81
Default Hard wiring a ground loop isolator in '08 Touring
Hello all,
See as how I am putting off buying some sort of IPOD integration kit for a while. I'd like to eliminate the hiss from the IPOD while charging. I know that I need a ground loop isolator and have seen quite a few to choose from.
What I'd like to do though, it just integrate the ground loop isolator into the AUX jack to eliminate the clutter in the center console. Too many wires in there already from phone, bluetooth earpiece, gps and ipod.
Does anyone know of an easy way to get at the back side of the AUX plug so that I can wire in the isolator?
Any particular recommendations for an isolator that gives the best sound quality? I obviously would only want to do this once.
Such a shame that Toyota didn't include one in the system already.
David
david81 is offline
Old 04-16-2008, 02:05 PM   #2
zenMachine
Just another Onionhead
zenMachine's Avatar
Default Re: Hard wiring a ground loop isolator in '08 Touring
Hey, that's a great idea! I hate keeping the isolator in my console too. Such needless clutter.
It's pretty easy to remove the center console. There are two 10mm hex screws inside the console (toward the rear) and a few on both front sides (you need to first pop out the front piece to reveal the front screws).
If you do it, let me know how it goes. I'd like to do the same.
zenMachine is offline
Old 04-16-2008, 03:16 PM   #3
Friends: 6
When you do pull the center console, watch out for the wires. They connect to the Aux jack, the power jack, and the SKS antenna. There is a fair amount of play, so you can move the console around a bit, but don't get rammy and yank it out wires and all.
Old 04-16-2008, 03:34 PM   #4
david81
Sounds like it should be easy to get to the back of the jack. Was hoping I could just pop out the panel that the jack sits it, but it didn't seem to want to budge when I tried on lunch.
Now to just figure out which isolator to use. The PAC version that is sold by Crutchfield seems to get decent reviews. Any other suggestions?
David
david81 is offline
Old 04-16-2008, 04:10 PM   #5
zenMachine
zenMachine's Avatar
David
The PAC looks good. I probably will get one myself.
I currently have the Radio Shack model, which has dual RCA jacks. Although the unit works well, the cabling is a mess because it requires a 3.5mm-to-RCA Y-adapter on both ends. (I was traveling at the time and didn't have much choice).
Assuming you're using a device that has a 3.5mm jack with this, you could test it out as is before actually splicing the Aux input in your car. If it works then take the next step. Based on all the positive reviews, this should be a good buy.
Old 04-16-2008, 09:58 PM   #6
david81
From a picture I found it appears that there is a nice quick connect within the center console. Would be nice if I could get my hands on the appropriate connectors to just splice onto the isolator and not alter the existing wiring.
Anyone happen to have access to the TIS that would be willing to look up the appropriate part numbers needed?
david81 is offline
Old 04-16-2008, 11:05 PM   #7
jtrain73
I use the PAC one from Crutchfield, works great. Had one from Radio Shack that didn't eliminate the hum.
jtrain73 is offline
Old 04-17-2008, 02:03 AM   #8
SgtTurtle
SgtTurtle's Avatar
I also have the PAC one from Crutchfield and I am happy with it.
SgtTurtle is offline
Old 04-17-2008, 10:45 AM   #9
zenMachine
zenMachine's Avatar
Thanks! I will order mine today to replace the rat's nest in my console. Even without a hard-wiring mod, the 3.5mm connections on the PAC alone will be worth it. Can't believe I hadn't found this solution sooner...
Old 04-17-2008, 08:47 PM   #10
GeoGeek
GeoGeek's Avatar
Nominated 4,294,967,295 Times in 4,294,967,295 Posts
Nominated TOTM Awards: 1
Scosche used to make a really effective one..might want to look into it.
GeoGeek is offline
Hard-wiring power behind the dash laci.laplante Audio and Electronics 2 08-07-2007 06:23 PM
Touring with package 6 is hard to find - Any help out there? emtownsend Prius Main Forum 34 05-28-2007 09:32 PM
2007 AUX-in hiss and ground loop isolator solution klevitsky Audio and Electronics 1 12-21-2006 04:16 PM
Better Ground Loop Isolator than Radio Shack jonbeck Audio and Electronics 15 10-10-2006 10:00 PM
