| Audio and Electronics This is a discussion on Question for an ADMIN in the Audio and Electronics section? within the Audio and Electronics forums, part of the Toyota Prius Forums category; Tony, each page is an image, which makes the type very difficult to read. I think the PDF was created ... |
| admin, audio, electronics, question, section? |
| | #11 |
My Car: 2007 Prius Package: #5 Nominated 6 Times in 1 Post TOTM Awards: 1Friends: 51 | Tony, each page is an image, which makes the type very difficult to read. I think the PDF was created through a bit-mapping process, capturing printer bits. Yours were the same questions I asked ualdriver. |
| | #12 | |
| Member Join Date: Mar 2008 Location: Durango, CO
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Quote:
I don't care to shrink the size of my final pdf product in particular. I just assumed I couldn't put it on the forum because it was too big as when I tried to upload it I got the error message in post #1. If you're an admin, I'll e-mail it to you if you want and perhaps you'll have more luck posting it. I created the original product in Broderbund PrintShop 20-something, but not the latest one. The Broderbund product allows you to create a 150dpi .pdf file from the Broderbund format. Since I assume few can read that type of file, I did a "save as" .pdf and it took my 1.7mb Broderbund file and turned it into a 15.7mb .pdf file. I also cut and pasted the pages into a Word 2003 document, but it was still just as big and loss some of the formatting. Anyway, that's where I am. Thanks | |
| | #13 |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Try printing to "Adobe PDF" instead of saving directly out of the application to PDF. It's unlikely your application is sophisticated enough to do a real export to PDF. It likely just created full-size images for each page, and created a simple PDF document whose pages each consist of a single image. By printing to PDF, you have a chance of preserving all of the vector line art and text, which would likely give you a much smaller file size. OTOH, if your document is all full-page images, there probably isn't much that can be done to really get the document size down.
__________________ 2009 Toyota Camry Hybrid Black (hers) JBL Audio, Bluetooth, Moonroof, Alloy Wheels, Pink Fuzzy Dice on rearview mirror 2005 Driftwood Pearl Pkg #6 (mine) Katzkin Leather Interior Diamond Audio D661s Component Speakers JL Audio 8W3 Subwoofer JL Audio CleanSweep CL441dsp MTX Thunder 564 Amp 4x100 watts MTX Thunder 421D Amp 1x300 watts OEM Sirius Tuner 2004 Super White Pkg #9 (hers) - sold |
| | #14 | |
Thanks | |
| | #15 | |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
This will only make a difference if the printing path of the application draws the graphics differently than the PDF export path (I somehow missed previous posts which confirmed my suspicions about this application). If it prints by sending a full-page image to the print driver, it won't make any difference. | |
| | #16 | |
I guess, though, I'm still wondering why I am getting the error message from Post#1 when I try to upload the file. It seems like finding the solution to that problem may be easier than trying to shrink/modify the file. | |
| | #17 |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Oh wait, unless you have Acrobat you won't be able to print to Distiller and create a PDF. The easiest thing might be to print to a PostScript file, and then ask someone with Acrobat to distill the file for you. In order to do that, you need to have at least one PostScript printer installed, and then check the "Print to file" option in the print dialog. There are also some free packages out there that utilize GhostScript to create a PDF for you, but they're not for the novice. |
| | #19 |
| Member Join Date: Oct 2006 Location: Escondido, CA
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | If the OP doesn't have Adobe Acrobat he can always download/install something like PrimoPDF (a free PDF maker). |
| Home audio question | brad34695 | Audio and Electronics | 24 | 01-22-2008 10:01 PM |
| moved to audio section, sorry. | BethlehemPrius | Prius Modifications | 0 | 07-19-2007 06:35 PM |
| If Toyota had picked Eclipse for the Audio section | SynergyGuy | Audio and Electronics | 4 | 11-17-2005 02:20 PM |
| newbie audio question | misterbig | Audio and Electronics | 2 | 04-27-2005 05:54 PM |
| Audio and Electronics | Chucka | PriusChat Website Questions | 0 | 04-01-2005 09:27 PM |
