Audio and Electronics This is a discussion on Intermittent Touch Screen Problem.... within the Audio and Electronics forums, part of the Toyota Prius Forums category; Hi everybody I have a 2004 pkg #9 and it has been no problem for 4 years and 55k miles. ...
intermittent, problem...., screen, touch
Old 08-30-2008, 05:14 PM   #1
duncan442
Default Intermittent Touch Screen Problem....
Hi everybody
I have a 2004 pkg #9 and it has been no problem for 4 years and 55k miles. However, in the last month I have been getting an intermittent problem with the screen display.
It seems to loose it's connection to everything else - the normal screen is displayed but it doesn't display the mpg's or temp, it states that the audio is off (when it's on) it states 'external system is not connected' when i press Menu or Map and most of the other buttons don't work. The A/C and stereo both work OK even though they can't be controlled from the display screen.
I have noticed that it is fine in the morning when the car has been standing overnight but is almost always bad when I come to drive home from work. It usually comes back on part way home (after ~20mins of driving).
I am OK with taking it to the dealer except that earlier this year I installed the coastal electronics ultimate lockpick and I am concerned that this may be the cause of the problem....
Does anyone have any advice or suggestions? Has anyone else had a similar problem either with or without a 'lockpick' fitted? Any help would be much appreciated.
Thanks!
Duncan
duncan442 is offline
Old 08-31-2008, 01:00 AM   #2
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 7
Default Re: Intermittent Touch Screen Problem....
Hi Duncan
This is a known issue, check out this writeup by Hobbit:
Prius MFD
dogfriend is online now
Old 08-31-2008, 04:25 AM   #3
patsparks
Uneducated bird-brain Aussie
patsparks's Avatar
Friends: 23
Another person who is about to find out just how clever our Mr Hobbit is!!
Cheap to fix thanks to Hobbit.
Welcome to Prius Chat (PC) Duncan442.
patsparks is offline
Old 08-31-2008, 12:35 PM   #4
duncan442
OK thanks - very helpful!
One final thought - is a dealer likely to refuse to repair under my extended warranty because of the coastal lockpick? I could take it out first of course but would like to avoid the remove and reinstall effort if I can....
Any advice on this?
Thanks
Duncan
Old 08-31-2008, 02:15 PM   #5
dogfriend
dogfriend's Avatar
Friends: 7
My opinion is that its very unlikely that the Lockpick contributed to your issue. But my opinion doesn't count - its the dealers opinion that is important. I think they might try to claim that the Lockpick caused the issue. Also, if the tech sees the Lockpick, they might assume that it is causing the issue and would stop looking for the actual problem.
Old 08-31-2008, 06:40 PM   #6
duncan442
I think you are probably right. I'll take it out and then take it to the dealer.
Thanks for the advice.
Duncan
Old 09-02-2008, 03:44 PM   #7
duncan442
Does anyone know how I can get a PDF of TSB EL002-05? The link I found on the main thread for this issue didn't work....
Thanks
Duncan
Old 09-02-2008, 03:59 PM   #8
dogfriend
dogfriend's Avatar
Friends: 7
Search is your friend:
TSB EL002-05 Multi-Display Functions are Inoperative
Also, if you want to read more about this issue, check out:
PriusChat Forums - Search Results
Old 09-02-2008, 04:29 PM   #9
duncan442
Thanks but that is the one I already found and the link doesn't work unfortunately.....I look thru some of the threads on the search resultss link you sent.
Old 09-02-2008, 06:02 PM   #10
dogfriend
dogfriend's Avatar
Friends: 7
Hi Duncan
Look at the second post in that thread:
I was able to download and read the TSB posted there.
Has anyone REPLACED the touch screen with a 7" pioneer/kenwood (etc) touch system? pics? fadetogloss Audio and Electronics 9 04-13-2008 01:18 AM
Intermittent starting problem reverest@mac.com Prius Technical Discussion 2 05-18-2007 10:16 AM
touch screen touch up? fugsco Audio and Electronics 0 01-09-2006 10:33 AM
Touch Screen Problem ab7ji Care, Maintenance and Troubleshooting 16 11-15-2005 12:47 AM
touch screen not working mielikki_eo Care, Maintenance and Troubleshooting 22 08-04-2004 04:57 PM
