Audio and Electronics This is a discussion on sirius wont stay plugged into headunit within the Audio and Electronics forums, part of the Toyota Prius Forums category; hey fellas i installed sirius in my 08 about 2 months ago. i have the stock headunit, and i cant ...
headunit, plugged, sirius, stay
Old 10-12-2008, 12:56 PM   #1
zeroeffect4
Default sirius wont stay plugged into headunit
hey fellas i installed sirius in my 08 about 2 months ago. i have the stock headunit, and i cant seem to keep it plugged in. i tried bending that little tab but no luck, last time i put a little piece of electrical tape, know it has come loose again. Is there any tricks to keeping plugged in?
zeroeffect4 is offline
Old 10-12-2008, 03:26 PM   #2
9G-man
Default Re: sirius wont stay plugged into headunit
After you get it plugged in, push up on the little locking tab and kinda tug on the wire at the same time. It should lock into place.
Took a little fiddling for me too, but I got it to lock.
9G-man is offline
Old 10-13-2008, 09:48 AM   #3
jelloslug
It buffed right out!
jelloslug's Avatar
On mine it took quiet a bit of force to get the plug to seat fully and lock in. Is the end of connector flush with the connector next to it?
jelloslug is offline
Old 10-13-2008, 05:29 PM   #4
zeroeffect4
i dont really know its so hard to see back there but what i do know is that the little tab is sticking and not contacting the headunit. i am just afraid to really push on it!
Old 10-13-2008, 06:15 PM   #5
tombellanca
tombellanca's Avatar
try more tape. if not electrical, then scotch so you can regulate the thickness a bit better.
mine wouldn't stay in, but after a night of trial and error, I finally got the right thickness of tape and haven't had a problem...knock on wood...
tombellanca is offline
Old 10-20-2008, 09:05 PM   #6
noahtwo
The plug needs to be seated very firmly to get it to "click" into place and lock. Difficult to do as it's hard to get leverage in that hard to reach space.
Try a long flat bladded screw driver to give the necessary leverage. Reach through the left side glove box opening and place the flat of the screw driver blade on top of the white plastic plug. Now reach in through the vent opening and pull the screw driver shaft towards you ...hard.. to seat the plug. Mine gave a satisfying "click" when locked!
Tip: I was able to work the white wire harness block into the glove box opening and then out the front of that opening. This took a little maneuvering (not force) to get it to fit coming out.....but makes it much easier to work in behing the radio unit!
noahtwo is offline
Randomly, Mine Wont Stay In "drive" oebur Prius Technical Discussion 5 08-01-2008 10:38 AM
Electric Car That Never Needs To Be Plugged In? JeffElectric Prius Technical Discussion 27 11-29-2007 01:27 AM
Can I install a headunit in map pocket? aolm Audio and Electronics 5 01-24-2007 08:16 PM
Has anyone plugged anything extra into the car darwin100 Prius Main Forum 15 12-03-2006 06:30 AM
People with aftermarket headunit, what does your.. akrca4 Audio and Electronics 7 02-20-2006 03:42 PM
