| Audio and Electronics This is a discussion on Installing the antenna on a Sirius Satellite Radio/Audiovox within the Audio and Electronics forums, part of the Toyota Prius Forums category; I just got the car kit for a Audiovox Plug N Play Sirius Satellite Radio and according to the instructions, ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I just got the car kit for a Audiovox Plug N Play Sirius Satellite Radio and according to the instructions, you're supposed to run the cable from the antenna underneath the rubber molding of the trunk window. Only problem is there is no rubber molding on the window of a Prius. So has anyone successfully installed a similar (Sirius or XM) antenna setup and how did you accomplish it? |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Yes, I looked at this when considering ordering external Sirius or XM box. The other concern is how do you get the cable back there - if you have the curtain air bags, you can not run it above the doors because it would probably obstruct the air bags - how do you get the cable there then? Is it long enough to run it under the carpet? |
| Senior Member Join Date: Dec 2003 Location: Plantation, FL USA
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The installler I used mounted the antenna on the front of the roof. The antenna wire runs though the firewall at some point, I don't know where exactly as I didn't watch the install. See pictures of my install in my album here. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Interesting stuff, Peter. Am I right or did your installers put the antenna wire and slid it thru the windshield on the front? On my instructions for the Audiovox they have it sliding thru the back. Thus the trunk window reference. |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
http://www.siriusbackstage.com
__________________ Peter Miami, FL USA | |
| Installing satellite radio antenna externally | BethlehemPrius | Audio and Electronics | 4 | 04-28-2007 11:53 PM |
| Sirius Satellite Radio | Alkurth | Audio and Electronics | 8 | 02-06-2007 05:59 PM |
| 2006 Prius - Satellite Radio Antenna | dimmickjimmie | Audio and Electronics | 1 | 12-06-2005 09:56 PM |
| Sirius Satellite Radio Available - Metrotpn.com | toyotapartsnow | Sponsored Commercial Sales | 1 | 07-09-2005 12:15 PM |
| Sirius Satellite Radio | akurth | Fuel Economy | 0 | 12-31-1969 07:00 PM |
