| Audio and Electronics This is a discussion on Radio problem within the Audio and Electronics forums, part of the Toyota Prius Forums category; I was wondering if anyone else had this problem. Lately, whenever I listen to the radio, the radio keeps shifting ... |
| Member Join Date: Jul 2004 Location: Newtown, Ct
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I was wondering if anyone else had this problem. Lately, whenever I listen to the radio, the radio keeps shifting it's freq's on me. I'll have it tuned to 1190AM and it will intermittently either: 1) change the freq to 1180, and then, after a couple of secs, go back to 1190. 2) change the freq to 1200, and then it might shift back down to 1190 but usually stays at 1200 until I set it again to 1190. This problem also occures in FM. I was just wondering if I was the only one with this problem. |
| Senior Member Join Date: Feb 2005 Location: Circleville, Ohio
My Car: Other Non-Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Hmm,never heard of that here, . Maybe something you are doing? Maybe check that the tuning dial is not stuck in the detent postion? |
| Ruler of Omicron Persei 8 Join Date: May 2004 Location: Far-North Chicagoland
My Car: 2004 Prius Package: #9 Nominated 4 Times in 2 Posts TOTM Awards: 0 Friends: 14 | That's really odd. I agree with Rick except that if a button depression were causing the change, there would be a beep. Most likely. Because the car wouldn't know if the button were depressed intentinoally or not. But since it happen on AM and FM, you should really have it looked at. |
| Prius OG Join Date: Mar 2004 Location: Los Angeles, CA
My Car: 2004 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Porky Pine\";p=\"87682)</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I had that happen to me as well. Drove me nuts for a couple of days. Finally figured out that the channel knob as causing it. I turned it to a new position and have not had the problem since. |
| Radio Reception Problem | ovni | Prius Technical Discussion | 4 | 08-03-2007 04:44 PM |
| Problem with XM Radio | mjms2b | Prius Modifications | 3 | 06-16-2007 04:41 AM |
| radio problem with an 02 | captain archer | Care, Maintenance and Troubleshooting | 0 | 09-11-2006 01:54 AM |
| Radio Problem | AlphaTeam | Audio and Electronics | 12 | 04-13-2006 07:33 PM |
| Problem with radio | adrien32 | Audio and Electronics | 1 | 01-09-2006 11:10 AM |
