Go Back   PriusChat > Local Clubs > Local Prius Club Main Forum > CA - San Diego
CA - San Diego This is a discussion on San Diego mileage? within the CA - San Diego forums, part of the Local Prius Club Main Forum category; I just got my 2007 package #6 prius last week and so far love it. However, I've been driving it ...
Old 07-17-2007, 12:23 AM   #1
lagreca
Send a message via ICQ to lagreca Send a message via AIM to lagreca Send a message via MSN to lagreca Send a message via Yahoo to lagreca
I just got my 2007 package #6 prius last week and so far love it. However, I've been driving it like an OLD man, and only getting 40.6 mpg (90% city, 10% freeway). I realize that it needs to break in, etc before it will improve, but I'm wondering what other drivers are getting with the San Diego terrain? Meaning all the hills and canyons, etc.
lagreca is offline
Old 07-17-2007, 01:46 AM   #2
nginoza
<div class='quotetop'>QUOTE(lagreca @ Jul 16 2007, 11:23 PM) [snapback]480057[/snapback]</div>
nginoza is offline
Old 07-17-2007, 03:08 AM   #3
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Nominated 3 Times in 2 Posts
Friends: 6
I average between 45 and 52.
Godiva is online now
Old 07-17-2007, 09:53 AM   #4
roopesh
I've had my '06 Prius for a year. When I first got it, it took a while to get to 40MPG. Now I'm doing about 44 through San Diego. I live up in Scripps Ranch, and all I do is go up & down hills back and forth from work.
roopesh is offline
Old 07-20-2007, 12:31 PM   #5
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
It depends, my commute is I-15 (from the SDSU area) and Pomerado Road (into Poway). It can be between 44 and 52, depending on weather, tire inflation, etc.
aaf709 is offline
Old 07-20-2007, 12:46 PM   #6
nginoza
Hi,
I have 3,000 mile, until the last tank of gas, I got 46 now I am getting 51. The only thing I can think of is I am driving the Prisu with my wife on vacation. Using a different gas (76) or the engine breaking in.
But I drive it very gingerly.
Nathan
nginoza is offline
Old 07-22-2007, 09:13 AM   #7
cwc526528
Congratulations on your new Prius! You're gonna love it!
My mileage ranges between 48 and 51 in the summer even with the A/C running full blast. When it's cold outside, the mileage drops to as low as 44.
These numbers would be better if I didn't have to navigate a steep two mile grade 3 or 4 times a week. The battery doesn't have the needed capacity for this grade, and it doesn't provide much help on the way up. On the way down, it maxes out, and the car goes into an engine braking mode to avoid overcharging the battery. For the rest of the way down, there's no more regeneration, and the engine continues to consume fuel. So this grade cuts into my mileage when I go up, and again when I come back down.
To get the best mileage, you have to stay focused, and you have to pay close attention to the Consumption and Battery screens on the LCD display. There's a button on the right side of the steering wheel that will let you toggle between the two screens. display, which you can access with a button on the right side of the steering wheel. You need to learn to access this button by feel, without looking down.
(BTW, Package #2 doesn't include this button. I don't know about Packages #3, #4, and #5. For me, this button alone is worth the upgrade!)
Be forewarned — you're going to incur the wrath of large pickups and SUVs. Let them by when you can, but don't let them intimidate you into driving faster and eroding your gas mileage. This is particularly true when you are approaching a traffic light that you know will still be red by the time you arrive.
The vertical bar on the right side of the Consumption display is your primary source of feecback. When it's topped out, it usually means that your running on the battery with the engine off or barely running. When you can, you want to keep it topped out, but always keep it as high as possible while keeping up with traffic.
The basic trick is to accelerate moderately as you start out, then when you reach a moderate speed, gently ease on the accelerator. The Consumption display should top out at least momentarily. You can then apply just enough pressure on the accelerator to maintain your speed while keeping the Consumption display topped out. You'll be running on the battery, and if you're on level ground, you may be able to go for two or three miles before the battery discharges enough to force the engine to start.
This only works if the drive battery isn't low to begin with. You can check the battery level by toggling to the battery display briefly, then toggling back again to the consumption display. You need to stay aware of the battery level via frequent checks of the battery display.
The drive battery is recharged in any of the following ways:
  • by going downhill
  • by slowing down
  • by applying the regenerative brakes
  • by running the engine
You want to maximize the first two and thereby minimize the need for the last two:
When you go downhill, you want to let up completely on the accelerator whenever possible, unless the battery is maxed out. Again, you can check this with the button on the steering wheel. This will give you the maximum recharge of the battery, and it helps you to limit your downhill speed without having to apply the brakes.
When you slow down, say for a traffic light, lift your foot off the accelerator. The electric drive motor becomes a generator and provides a long gentle deceleration. Begin slowing early and minimize the use of the brakes.
The regenerative braking system recovers about 50% of the energy that you would normally lose during braking. While this is much better than conventional braking systems, it still represents a significant energy loss. By anticipating your stops, you can minimize the use of the brakes.
Here are a few other tips, most of which apply to hybrids and non-hybrids alike:
  • Look ahead. Try to spot developing developing traffic situations early so you can avoid having to make a hard stop.
  • Put gravity to work for you. If you're heading uphill toward a stop, ease off early and let gravity slow you down instead of pressing harder on the accelerator to maintain your speed, then having to use your brakes.
  • When you go uphill, keep a close eye on the Consumption display. If traffic permits, let your speed drop until the display shows optimum mileage. If you need to accelerate, try to wait until you're over the crest.
  • Try to choose a route with the fewer hills. When you go uphill, your gas mileage plummets, even with a hybrid.
  • Try to choose a route with fewer stop signs and traffic lights. Stopping, then starting loses energy.
  • More generally, choose the route you would use if you were riding a bicycle instead of driving.
  • If you have a big SUV or pickup behind you, let him by. Once he's ahead of you, he'll provide a significant draft.
  • Keep your Prius tires inflated to 40 lbs. to reduce rolling resistance.
  • Watch your speed. Treat speed as an expensive resource to be used sparingly.
  • Try to ajust your speed to when you approach a traffic light to arrive when the light is green. Keep your eye on not only the one you are approaching, but the one beyond.
I hope this helps. Enjoy your Prius!
cwc526528 is offline
Old 08-18-2007, 04:47 AM   #8
ACORNBLUES
For the 30min RT commute from SR to Sorrento Valley via Mira Mesa, I get 50MPG. To from LA, I get 60MPG if I drive below 55mph. Otherwise I get about 55MPG around 65mph. My dream is to increase my efficiency to 55 or 60MPG on my regular commute. To that end I'm getting the EBH and starting to push my car out of the garage in the morning. We'll see what happens.
ACORNBLUES is offline
Old 08-18-2007, 11:42 AM   #9
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Friends: 6
My commute is 12 miles, the majority of which is freeway. I'm about a mile from the freeway. I'm installing an EBH to see if I can improve the mileage since I spend most of my commute warming up the car. I'm hoping to get at least a 5 mpg improvement regardless of time of year.
Old 08-23-2007, 10:48 PM   #10
LYLUVLY
Send a message via Yahoo to LYLUVLY
we visit our daughter in Poway.
We get good mileage from Huntington Beach to San Diego.
Our route is: 405 to 5 to the 78 to the 15. We get off the 15 at Marguerite Poway, and thats when the mileage gets bad. Its all up and down from the 15 to Pomerado Road. Our Prius uses more gas to go up than we make up by coasting down. Your 40mpg is just a bit low, but not bad. We average about 43 in that area over an extended period of time.
LYLUVLY is offline
City Mileage 10 MPG worse than Higheway Mileage karat Care, Maintenance and Troubleshooting 27 10-20-2006 04:24 PM
Two Prii in San Diego Godiva Dealers & Pricing 0 09-05-2006 10:16 PM
Silver, #3, 5/1/06, San Diego, CA EmptyG Order Tracking 3 05-09-2006 05:33 PM
San Diego Club Sev CA - San Diego 0 06-29-2004 03:48 PM
Anyone in San Diego have the SSC 40D done yet? mcbrunnhilde Prius Main Forum 5 06-14-2004 11:13 AM
