| Care, Maintenance and Troubleshooting This is a discussion on Tire Wear Info and Winter Tire questions within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; Repost, as my old thread went away... I finally managed to find a tire tread depth gage, and I checked ... |
| Member Join Date: Nov 2003 Location: eastern, MA, USA
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Repost, as my old thread went away... I finally managed to find a tire tread depth gage, and I checked my tires. I took my best estimate/closest whole number when measuring. I have about 23,000 miles on my 2001 Toyota Prius' OEM tires, I think that's about 2 years of service (I'd have to double-check my notebook in my car for the exact date). My usual pressure is about 41F/39R. OEM Bridgestone Potenza RE92 XL P175/65 R14 84S original tread depth is supposedly 10/32" Measuring the 4 main grooves, in x/32": left outside ---> inside; right inside ---> outside left front: 7, 8, 8, 7 ; right front: 5, 7, 6, 5 eft rear: 6, 7, 7, 7 ; right rear: 6, 6, 5, 4 My husband has about 24,000 miles on his 2004 Toyota Prius with OEM tires. That's just shy of 2 years. Usual pressure is around 40F/38R. OEM Goodyear Integrity P185/65 R15 86S original tread depth is supposedly 10/32" Measuring the 3 main grooves, in x/32": left outside ---> inside; right inside ---> outside left front: 6, 8, 7 ; right front: 6, 7, 5 left rear: 5, 7, 6 ; right rear: 5, 6, 5 Unfortunately, neither car has been in for an alignment yet. But the tires do get rotated (or so says my paid work orders) at every oil change (6 months or 7500/5000 miles). So, I have more tread wear on the edges, and it looks like about 2/32" of tread wear per year... Door jamb info for the US Prius, any model year, is 35psi front, 33 psi rear. Most Prius owners tend to report edge wear on their tires. It's especially bad on the 2001-2003 Prius with the Bridgestone Potenza RE92 XL tires. So, to combat this, and to increase MPG, many owners either religiously keep their pressures at the factory 35F/33R, or go up to anything that's within the max. cold pressure as on the sidewall. The tire recommendations from the Classic owners just got translated over to the 2004-? Prius when it came out... Max cold pressure for the US OEM Bridgestone Potenza RE92 XL tires on the 2001-2003 Prius is 50psi. Max cold pressure for the US OEM Goodyear Integrity tires on the 2004-? Prius is 44psi. Just some data points for those out there... Anyhow, the question I have is: is it time to dump these tires, or should I hold onto them for another season? (I know a number of Prius owners hate the OEM tires...) I know that I need to invest in some snow tires for this upcoming MA winter. Last winter I kept sliding backwards down my paved but icy driveway with my 2001, and my husband slid into a snowbank or two with his 2004 BC (and the front bumper still keeps popping off of some of its clips). I was thinking of just going straight to some Nokian WR A.W.P.2 tires (4-season tires with the Severe Service emblem) for full-time use, but... Should I/can I just put the Nokian WR onto the current aluminum rims for this winter, change back to the OEM tires for the upcoming spring/summer/fall 2006, and then remount the WRs for the following winter and keep them on (dump the OEMs next winter)? Or should I get some steel rims just for this winter for the WRs, and then move them back to the alloys when I dump the OEMs? Or should I just buy some steel rims and winter tires (Bridgestone Blizzak WS50 or Nokian RSI), and then have to look into buying another 3-season tire (Nokian NRHi or i3, LRR tires) in another year or so? (This seems much more expensive and more hassle than just going for the WRs above, but...) Just looking for any tire/wheel advice. Thanks in advance!
__________________ -mrv 2001 Aqua Ice Opalescent 2004 Black BC (Pioneer), now sold http://www.kluge.net/~felicity/prius.php |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | If you've been sliding around in the winter on the OEM tires, do you even need to ask if you should dump them in favor of something better??? If the roads are salted in the winter in your area, a separate set of plain steel rims is recommended to preserve the alloy rims.. Additionally, it allows you to choose sets of tires optimized for summer and winter conditions- if you have ever used a good set of modern winter tires, there's absolutely no comparison to "all season" tires.. I certainly would never ever go back to using all season tires in the winter.. Now you can certainly swap tires on/off the same set of rims, but that's a lot of wear on the tire bead, and plain steel rims are not that expensive; you can even find them in the junkyard for $5-10 a piece (just make sure the rims aren't bent).. Swapping tires is actually a fairly quick job. I used to do 4 wheels every year on my Corolla with the little crank jack and the tire iron in about 40 minutes. After I wore out the crank jack (the jack is really meant for emergency use only so the bearings went on it after 5 years), I got one of those small hydraulic floor jacks from Walmart and it cut the time down to about 25-30 minutes.. If I use the pneumatic impact wrench, it cuts the time down even further to about 15 minutes for all 4, including manual torquing at the end with a torque wrench.. |
| Junior Member Join Date: Dec 2003
I put Nokian WR's on my '04 Prius @ 700 miles onto the alloy wheels. I leave them on all year 60 miles north of Manhattan rotating every 3-5000 miles. I have 39k miles on them and expect at least 10k more. I have been extremely pleased in all conditions. I get 46-48 mi/gal mixed driving and 50 hwy a little more in warm weather, a little less in cold. Generally drive 60-70mph hwy.I do not know if OEM tires are better MPG as car was too new when I swapped, but these are rated LRR. When I bequeathed my Forester to my son it went with 9 wheels, 4 alloy summer, 4 steel winter (hakkepolitta) and the virgin spare, I like this system better.
__________________ Peace, Ammiel | |
(When the OEM tires were new, I did not have sliding problems...) The tires I'm looking at: Nokian WR A.W.P.2 (4-season friction winter/all-weather tire with severe service emblem, and made in a more environmentally friendly manner) http://www.nokiantyres.com/passengercars_p...&name=NOKIAN+WR http://www.nokiantires.com/newsite/tires_popup.cfm?id=6 or alternately: Nokian NRHi (3-season summer tires, LRR and made in a more environmentally friendly manner) http://www.nokiantyres.com/passengercars_p...ame=NOKIAN+NRHi http://www.nokiantires.com/newsite/t...opup.cfm?id=54 with: Nokian Hakkapelitta RSI (friction winter tires, and made in a more environmentally friendly manner) http://www.nokiantires.com/newsite/t....cfm?id=53&w=1 http://www.nokiantyres.com/passengercars_p...KKAPELIITTA+RSi My options look to be: 1. Take off OEMs and dispose of them. Put Nokian WRs on the alloy wheels until they wear out. 2. Take off the OEMs and hold onto them. Put Nokain WRs on the alloy wheels for the winter. Put the OEMs back onto the alloy wheels for spring/summer/fall (2006). Put the Nokian WRs back on the alloy wheels next winter (2006), and most likely dispose of the OEMs next winter. Keep the Nokian WRs on the alloys from then on. 3. Find some steel wheels, and mount the Nokian WRs on the steel wheels for the winter. store the alloys with the OEMs for next spring/summer/fall (2006). Maybe I'll get spring/summer/fall 2007 out of the OEMS, I don't know, but when they're ready to go just keep driving on the steel wheels with the Nokian WRs until they wear out. 3B. same as above but I move the Nokian WRs off of the steel wheels and back onto the alloy wheels, and sell the steel wheels. 4. Find some steel wheels, and mount the Nokian RSIs on the steel wheels for the winter. store the alloys with the OEMs for next spring/summer/fall (2006). Maybe I'll get spring/summer/fall 2007 out of the OEMS, I don't know, but when they're ready to go replace with the Nokian NRHi or whatever replaces it at that time. 5. Find some steel wheels, and mount the Nokian WRs on the steel wheels for the winter. store the alloys with the OEMs for next spring/summer/fall (2006). Maybe I'll get spring/summer/fall 2007 out of the OEMS, I don't know, but when they're ready to go replace with the Nokian NRHi or whatever replaces it at that time. The most expensive initial outlay (remember that I'm dealing with 2 Prius here) would seem to be options 3-5 above. Option #1 is fairly simple and obviously involves the least amount of work... I'm leaning towards option 2 above, but I'm not ruling anything out just yet. (Well, I'm not moving to southern CA, as was one suggestion I've had...) Tire swaps would require a trip to a professional (we don't have the tools or ambition to change them out ourselves). I do intend to do a full 4-wheel alignment before putting any new tires on. I suspect that I'll still see the edge wear, though. (It is far too easy to take a turn too fast in a Prius, and when riding with my husband in his 2004 he seems to suffer the same affliction, if not worse...) I'm still trying to get my hands on a copy of the current (November 2005) issue of Consumer Reports which rates both summer and winter tires and their care. My local libraries have not received their copy in the mail yet, and I've asked family and coworkers and no one subscribes... | |
I'll go back to the OEMs for spring/summer/fall of 2006, and re-evaluate them come winter of 2006 to decide if I'll keep them (have enough tread left), dump the OEM tires and transfer the WRs to the alloy wheels for full-time use, or dump the OEM tires and get some new summer tires (or even use the WRs for summer use and get more agressive winter tires to put on the steel rims). This week I took both of my Prius in for a 4-wheel alignment, as neither of them have had one yet (4.5 years/40+K miles on my 2001, 2 years/25K miles on the 2004). My 2001 went to a new-to-me dealer. Alignment cost $79.95 (but the 60,000/48 month service mile service I did at the same time (I'm late for that by time, but not by mileage) was the least expensive in the area.) I got a nice color printout of the before/after and the specs for my car. Both the Left and Right Front Toe was out of specifications, and were adjusted. I do not know why the SAI and Included Angle were not measured. Now my 2001 does handle much easier/lighter (point and it's easy holding onto turns, but on the highway it is a light touch and can "wander" as I'm used to a tight track/holding). My 2004 went to my usual dealer. Alignment cost $64.95. I had to ask for a copy of the printout, so they photocopied it from their records (so no pretty colors for me). Vehicle was in specifications, so they didn't adjust anything. (So, $64.95 to just get a photocopied printout.) 2001-2003 Prius, all figures in degrees * = This value is not whithin specification. Tire wear, handling and safety problems may result. Front (Left) Camber: Specs: -1.2 to 0.3, Actual: -0.6, Before: -0.7 Caster: Specs: 0.3 to 1.8, Actual: 1.4, Before: 1.4 Toe: Specs: -0.5 to 0.15, Actual: 0.06, Before: -0.21 * SAI: Specs: 9.1 to 10.6 Included Angle: Specs: 7.9 to 10.9 Turning Angle Diff.: Specs: .... Front (Right) Camber: Specs: -1.2 to 0.3, Actual: -0.6, Before: -0.6 Caster: Specs: 0.3 to 1.8, Actual: 1.0, Before: 1.0 Toe: Specs: -0.5 to 0.15, Actual: 0.08, Before: 0.28 * SAI: Specs: 9.1 to 10.6 Included Angle: Specs: 7.9 to 10.9 Turning Angle Diff.: Specs: .... Front Cross Camber: Specs: -0.8 to 0.8, Actual: 0.0, Before: -0.1 Cross Caster: Specs: -0.8 to 0.8, Actual: 0.4, Before: 0.4 Cross SAI: Specs: -0.8 to 0.8 Total Toe: -0.10 to 0.30, Actual: 0.14, Before: 0.07 Cross Turn Diff.: Specs: .... Rear (Left) Camber: Specs: -2.3 to -0.8, Actual: -1.4, Before: -1.5 Toe: Specs: -0.12 to 0.22, Actual: 0.00, Before: 0.00 Rear (Right) Camber: Specs: -2.3 to -0.8, Actual: -1.2, Before: -1.2 Toe: Specs: -0.12 to 0.22, Actual: 0.21, Before: 0.20 Rear Cross Camber: Specs: -0.8 to 0.8, Actual: -0.2, Before: -0.2 Total Toe: Specs: -0.23 to 0.43, Actual: 0.21, Before: 0.20 Thrust Angle: Specs: .... , Actual: 0.10, Before: 0.10 2004-2005 Prius, all figures in degrees Front (Left) Camber: Specs: -1.3 to 0.2, Actual: -0.6, Before: -0.6 Caster: Specs: 2.4 to 3.9, Actual: 3.4, Before: 3.4 Toe: Specs: -0.10 to 0.10, Actual: -0.06, Before: -0.06 [edit: fixed typo] SAI: Specs: 11.8 to 13.3, Actual: 13.0, Before: 13.0 Included Angle: Specs: 10.5 to 13.5, Actual: 12.4, Before: 12.4 Turning Angle Diff.: Specs: .... Front (Right) Camber: Specs: -1.3 to 0.2, Actual: -1.1, Before: -1.1 Caster: Specs: 2.4 to 3.9, Actual: 3.1, Before: 3.1 Toe: Specs: -0.10 to 0.10, Actual: -0.06, Before: -0.06 [edit: fixed typo] SAI: Specs: 10.8 to 13.3, Actual: 12.8, Before: 12.8 Included Angle: Specs: 10.5 to 13.5, Actual: 11.8, Before: 11.8 Turning Angle Diff.: Specs: .... Front Cross Camber: Specs: -0.8 to 0.8, Actual: 0.5, Before: 0.5 Cross Caster: Specs: -0.8 to 0.8, Actual: 0.4, Before: 0.4 Cross SAI: Specs: -0.8 to 0.8, Actual: 0.2, Before: 0.2 Total Toe: -0.20 to 0.20, Actual: -0.12, Before: -0.12 Cross Turn Diff.: Specs: .... Rear (Left) Camber: Specs: -2.0 to -1.0, Actual: -1.3, Before: -1.3 Toe: Specs: 0.03 to 0.28, Actual: 0.19, Before: 0.19 Rear (Right) Camber: Specs: -2.0 to -1.0, Actual: -1.6, Before: -1.6 Toe: Specs: 0.03 to 0.28, Actual: 0.17, Before: 0.17 Rear Cross Camber: Specs: -0.5 to 0.5, Actual: 0.3, Before: 0.3 Total Toe: Specs: 0.05 to 0.55, Actual: 0.37, Before: 0.36 Thrust Angle: Specs: .... , Actual: 0.01, Before: 0.01 | |
| geek Join Date: Oct 2005 Location: Carson City, NV
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | MRV,thank You for Posting the specs! As a new Prius owner I was wondering about tire pressures (not for mpg, but for wear) and I noticed that your tires were under- inflated by wear rate! I guess we'll try 4 4 14 2 and see if that wears evenly. Man this forum for, rocks! |
My Car: 2004 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | I must have missed this post the first time around. I went down to the condo storage area to check the wear on my Michelin Harmony 185/65 15 tires. The new spec is 11/32 tread depth. I have a NAPA tread depth gauge and checked the groove depth like you did. With approximately 16,000km of primarily Winnipeg city driving on the tires, at factory recommended 35F/33R pressure, the tires were fairly uniform at 9/32 to 10/32. There was no obvious cupping or feathering that I could see. As far as winter tires, I'm running Yokohama Ice Guard 10 this winter. They are better on snow and especially ice compared to the Dunlop Graspic DS-2 I ran last winter, much better than the Harmony on snow or ice. The highway tracking stability of the Ice Guard winter tires is poor, I need to make constant minor corrections. Since I spend most of the time driving around Winnipeg that's fine, I'll take the extra traction.
__________________ 2004 Toyota Prius "B", Tideland Pearl 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion |
| Tire Tread wear | flareak | Care, Maintenance and Troubleshooting | 21 | 10-14-2008 05:19 PM |
| Excessive Tire Wear | tmattern | Care, Maintenance and Troubleshooting | 37 | 04-16-2008 07:25 PM |
| tire wear | Dennis A. | Care, Maintenance and Troubleshooting | 6 | 07-27-2007 05:18 PM |
| Tire wear info and winter tire questions | mrv | Prius Main Forum | 1 | 10-09-2005 02:11 PM |
| Tire wear problem | jnail78 | Care, Maintenance and Troubleshooting | 1 | 06-28-2004 01:53 AM |
