Care, Maintenance and Troubleshooting This is a discussion on Open Hatch vs. Open Garage Door = Hatch Loses within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; Hopefully I can prevent someone from doing what I did. My Prius was in the garage and I put a ...
Old 10-18-2005, 04:46 PM   #1
itstwowords
Hopefully I can prevent someone from doing what I did. My Prius was in the garage and I put a load of cardboard into the back to take to the recycling center. One of the boxes was too long to fit completely in the car so I left the hatch up. I kinda closed the hatch on the protruding box, and then decided to open it back all the way up so the box wouldn't scratch my hatch.
So I hit the power switch and back out…
CRUNCH! @&#^$@!
It never even occurred to me that the open hatch was taller than a fully open standard 7’ x 16’ garage door. I have a creased tailgate to prove it, and to top it off, I had to pay someone to put my garage door back on the tracks. It broke the socket part of both ball-and-socket hatch-holder-uppers too, so if I lift the hatch too far, they pop off.
itstwowords is offline
Old 10-18-2005, 05:29 PM   #2
bobkat21
bobkat21's Avatar
Send a message via AIM to bobkat21 Send a message via Yahoo to bobkat21
CRUNCH!  @&#^$@!
[snapback]142648[/snapback]
All man sorry to here that but it happens. not much comfort in that. but It could have been even more damage then that.
bobkat21 is offline
Old 10-18-2005, 09:02 PM   #3
bigdaddy
bigdaddy's Avatar
CRUNCH!  @&#^$@!
Been there, done that. Do a search on the keyword "Hydrocodone"
bigdaddy is offline
Old 10-19-2005, 01:40 PM   #4
DanMan32
Been there, done that myself. I was blessed to not damage anything but the spoiler, and bent the mounting holes. Had the spoiler replaced and painted, with some adjustment to the mountings. I'm not satisfied with the adjustments, but even after a year, the body shop is willing to adjust it at no charge. If anyone is in the Tampa Bay area and in need of body work, I highly recommend Mikes Body Shop on county line road in Spring Hill. They also do mechanical work also, but probably not on hybrids. Mine was the only one they have seen up close.
DanMan32 is offline
Old 10-22-2005, 05:47 PM   #5
Graz
Graz's Avatar
Send a message via MSN to Graz
Hey Everyone,
I pulled a similar stunt recently. Except that I park on the left side of my garage, and my wife uses the right. (as you look into the garage from the driveway. I back in so that both of our drivers side doors open to the middle of the garage. It seems like a smaller garage than others. But I can fit a LOT of stuff in there and two cars.
Any way. I put something in the hatch and forgot to close it as I rolled out of my garage, I heard a bump. I stopped and found what I had done. The only damage was some small scratches and paint transfer from the door to the car. After returning home from work that day, I used a minimum amount of rubbing compound to remove all evidence of my mistake.
I was fortunate! And I have leaned a lesson.
Graz '05 - Tideland Pearl - Package 6
$3.13/G (02/22/2008)
43343 miles of smiles
Lifetime: 47.00 MPG
Highest Tank: 57.9 MPG
Highest Miles/Tank: 559
P185/65R15 Continental Pro Contact Tires
LRR: .00825 47.0/45.0 psi
Limit your funding of international terrorism!
Graz is offline
Old 10-26-2005, 01:27 PM   #6
DanMan32
Well, they couldn't line up the spoiler completely, however it is much better than before. Now that I saw how to manipulate it without breaking glass, I might try a few things sometime.
DanMan32 is offline
Fuel Door Won't Open Atwork Care, Maintenance and Troubleshooting 10 10-23-2007 07:32 PM
Unable to open the door. Alexland Care, Maintenance and Troubleshooting 4 11-07-2006 11:50 AM
Door open, car in Drive TonyPSchaefer Prius Main Forum 18 07-08-2005 12:27 PM
Is there a way to open the hatch from the inside of the car? Cathy K Prius Modifications 4 09-30-2004 06:25 PM
open door beeping jamarimutt Prius Main Forum 0 05-31-2004 10:35 AM
