| Care, Maintenance and Troubleshooting This is a discussion on 12 VDC Aux Battery (AB) within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; Can any of you technical hot shots tell me exactly how the HV feed the AB? What controls the charge, ... |
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Can any of you technical hot shots tell me exactly how the HV feed the AB? What controls the charge, how is it stepped or siphoned off, is there a controlling adjustment (for tweaking) is the actual charging event measurable, procedure for: etc what is the Max DC Voltage level at time of charge??? ty |
To answer your first question I believe (notice I'm hedging a little) there is a low Voltage output off of the HV battery inverter which is rectified, filtered, and regulated to charge the 12 Volt battery. So the ICE does not need to be running to charge the 12 Volt battery but I think the car does need to be on. It would almost certainly be a constant Voltage circuit with some current limiting for protection. That is the Voltage will remain constant unless the current demand goes to high at which time the Voltage will decrease to keep the current under some preset value. Experts please comment.
__________________ former Prius owner, waiting for a G III present car BMW 3 series | |
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | My scan gauge used to show about 14 to 14.2 volts when the car was charging the 12 volt battery. I assume this will vary some with temperature but now I use a Can View, with HV battery info but not the 12 volts. |
The reason it is refered to as an inverter is because it creates AC (actually simulated AC) by inverting (changing the polarity) of 1/2 of the DC. This actually produces a square wave which is rounded off with some reactive componants. The frequency of the inverter, which is controled by the computer, determines the speed of the synchronous motor(s). *Edit: Actually it is the sine wave that is simulated not the AC. | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | There is a completely *separate* inverter to charge the aux battery off the HV battery when the system is fully powered up. Remember, there are like 5 inverters in that block-o-stuff under the hood -- one for each MG, the buck/boost converter, the A/C pump, and the 12V charger. [The buck/boost sort of half-counts because it's a little different.] From what I and others can determine, the 12V system is actually brought up to right about 14V *at the battery*, using that very thin extra white wire that goes to the battery connection as a voltage sensor input back to the inverter [that otherwise carries no load]. . This voltage is actually a tiny bit higher than you really want to "float" a lead-acid battery with, so it will eventually bubble the battery dry. The ivory-tower conjecture is that Toyota decided to compromise between a faster recharge and a lower, more "correct" float voltage. But the point is that there's yet another inverter dedicated to this, no dropping-resistor kludges clipped into some other unrelated piece of the electronics. Physically, I believe it's in the bottom part of the under-hood block. . _H* |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Thanks Hobbit that helps quite a bit. Did you get that information from the maintenance manuals or did you have to reverse engineer someones car? I would like to learn more about this machine. But I've run out of resources short of buying the shop manuals, and I wasn't sure how much information was in them. |
| Why the small battery icon atop the hybrid main battery? | sparlin | Audio and Electronics | 3 | 02-07-2008 08:58 AM |
| battery | hybrid taxi | Prius Technical Discussion | 2 | 08-10-2007 12:58 PM |
| What's the 4-bar +/- battery symbol above the Hybrid battery meter on the MSD? | seakykr | Prius Technical Discussion | 6 | 10-20-2006 03:39 PM |
| Battery on the MFD Battery Meter | JShorr | Care, Maintenance and Troubleshooting | 11 | 01-05-2005 03:52 PM |
| 12 v battery | toolbox | Care, Maintenance and Troubleshooting | 21 | 10-17-2004 07:46 PM |
