Care, Maintenance and Troubleshooting This is a discussion on 05 Prius seems slow lately within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; Seems like the engine is working harder for normal acceleration. Merging on highway traffic or passing at speed seems noticeably ...
Old 12-24-2005, 12:11 AM   #1
chrism07924
Merging on highway traffic or passing at speed seems noticeably tougher than before. I'm tempted to say that it started happening roughly around the same time of the last oil change. It has 22K miles on it.
I thought it might be a sticky emergency brake, and tried pushing the brake all the way to the floor and releasing a few times, but the performance still seems degraded. The gas mileage doesn't seem any different. Could it be the gas? I'll take it in eventually, but I'm curious if anyone has had this issue. I only get it serviced by toyota, including all oil changes.
chrism07924 is offline
Old 12-24-2005, 09:21 AM   #2
tomdeimos
[snapback]178469[/snapback]
You sure it isn't just the cold weather. You get less power from winter fuel. And you get less acceleration power from the battery till it warms up, which can take about half an hour.
tomdeimos is offline
Old 12-24-2005, 12:53 PM   #3
chrism07924
[snapback]178547[/snapback]
I hope that's all it is. Sounds logical. The only thing is that it seemed to start becomming this way back when it wasn't so cold, like October, but maybe I am just not remembering. I drove it today, just now, and didn't notice the effect. It could be that the temp outside here in NJ is relatively mild today (low-mid 40s).
Old 12-24-2005, 01:44 PM   #4
djasonw
It definitely is the cold weather. I have the same issues. Once it is warmed up its fine. It can take upwards of a half hour for the battery to perform as it does in the summer. Last week when it was 17 degrees here, I decided to warm it up before I left for work. It was much better. Just look forward to spring!
djasonw is offline
Old 12-26-2005, 12:02 PM   #5
richard schumacher
nacreous lacquer
Check the oil to see whether it's overfilled. If so have the dealer fix his error.
Check your tires. Part of cold weather MPG loss is tires getting softer. That's easy to fix. (N.B.: tires should be checked "cold", which means the car has not been driven more than one mile in the last hour.)
richard schumacher is offline
How Slow IS the Prius? (Archive) Tideland Prius Prius Main Forum 6 09-10-2007 12:02 AM
slow heating berkley Prius Main Forum 18 01-08-2007 07:46 PM
slow dying? Don4221 Care, Maintenance and Troubleshooting 8 12-16-2005 12:01 PM
slow loading Tadashi PriusChat Website Questions 26 05-31-2005 05:25 PM
Wife called and said her Prius is so slow! Ray Moore Prius Main Forum 14 04-29-2005 10:35 PM
