Care, Maintenance and Troubleshooting This is a discussion on Tire Rotation within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; Why front to back only, when most vehicles cross the tires? I know many years ago, there was some thought ...
Old 03-09-2007, 10:51 PM   #1
lenjack
Why front to back only, when most vehicles cross the tires? I know many years ago, there was some thought that crossing would not be good with radials.
lenjack is offline
Old 03-10-2007, 12:33 AM   #2
mr_zorg
mr_zorg's Avatar
<div class='quotetop'>QUOTE(lenjack @ Mar 9 2007, 07:51 PM) [snapback]403167[/snapback]</div>
It has more to do with your tires having directional tread or not. If they do, you can only do a front-to-back rotation. If they don't, you can do a X rotation.
mr_zorg is offline
Old 03-10-2007, 03:23 AM   #3
John in LB
Life is good
John in LB's Avatar
Package: #8
<div class='quotetop'>QUOTE(Mr. Zorg @ Mar 9 2007, 09:33 PM) [snapback]403206[/snapback]</div>
Of course if a tire is directional - then it cannot be reversed. However, for most steel belted radials, the reason that X was originally not recommended was that each time direction was changed, the plies in the tire would flex and thereby loosen a bit.
Although this issue has not gone away, tire manufactures now recommend a compromise:
Straight front to back, and Cross the backs to the front.
This pattern does rotate every tire into all four positions, but switches directions half the original X pattern.
I confirmed this with Michellin several years back.
In addition, there is a nice article about tire rotation (as well as other tire information at www.tirerack.com
Here is the specific link for tire rotation: http://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=43
John in LB is offline
Old 03-10-2007, 09:02 AM   #4
lenjack
Thanks. I am aware of these issues. It appears to be non-critical. It seems the modified x would even out wear, but for the issue of ply "wiggling". Any other thoughts on this?
lenjack is offline
Old 03-10-2007, 02:52 PM   #5
Bear68
Nominated 3 Times in 1 Post
Friends: 5
<div class='quotetop'>QUOTE(lenjack @ Mar 10 2007, 09:02 AM) [snapback]403324[/snapback]</div>
Most Toyota owner's manuals recommend front to rear without crossing the tires. The main concern to watch out for when crossing tires is the issue of creating what is called a radial tire pull. If your tires are slightly cone shaped, (which most are) swapping sides can cause your car to pull one way or the other. this applies to any car. As a Toyota Tech, I solve a lot of pull issues simply by crossing the front tires.
Bear68 is offline
Prius Tire Rotation 2Touring Prius Main Forum 35 09-15-2008 03:00 PM
Tire rotation question gforeman Prius Main Forum 12 06-05-2008 10:05 PM
Tire rotation charge FishHawk Care, Maintenance and Troubleshooting 18 10-16-2007 04:17 PM
DIY Tire Rotation puppetmasta Care, Maintenance and Troubleshooting 5 09-18-2006 02:04 PM
Tire rotation nemmrack Care, Maintenance and Troubleshooting 6 01-02-2005 11:33 AM
