Care, Maintenance and Troubleshooting This is a discussion on 2007 Touring model within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; Need some info. I am thinking about buying a 07 prius touring model today. For starters the car had steel ...
Old 03-13-2007, 03:31 AM   #1
bradysplace
bradysplace's Avatar
Send a message via Yahoo to bradysplace
Need some info. I am thinking about buying a 07 prius touring model today. For starters the car had steel wheels with plastic cover (new car at dealer). I was under the impression they were suppose to be 16" alum. seven spoke wheels. Is there anything about the touring model, except for the stiffer suspension which does make it handle better that has caught the interest of this group? Example: does the extended spoiler have any effect on the overall operation or efficiency of the car? Do the larger tires increase resistance etc etc........... I have a 06 prius and the adjusting of this suspension on the touring model makes a good handling car even better. Need some feed back... Thanks
bradysplace is offline
Old 03-13-2007, 06:36 AM   #2
Warwind
Warwind's Avatar
Package: #5 Touring
I went for the Touring over the standard model because I thought the bigger wheels looked better on the car, the Bridgestone Turanza tires seem to be significantly better than the tires that come with the standard, the touring came with HID headlights, and the "sportier" suspension. The larger spoiler probably doesn't make any significant difference in how the car drives or even looks (it's not that much bigger), but it's part of the package.
The bigger wheels, better tires, and HIDs are worth the additional cost of the touring, in my opinion. I could have had either, and waited for a touring.
Let us know what you end up doing!
-Tom
2007 Barcelona Red/Dark Gray Touring, Package #2, 10/30/2006
OEM all-weather mats, OEM trunk mat, overpriced OEM rear bumper appliqué, Garmin nüvi 350 GPS w/4G SD card for playing mp3s, VentureShield paint protection
Warwind is offline
Old 03-13-2007, 07:21 AM   #3
cjhinpa
We just ordered a Magnetic Grey Pkg #3 Touring. Turns out, so we were told, that the Touring is only available in limited colors and we could not get the Touring in Seaside Pearl (the Blue) as we wanted.
We test drove both the standard and the Touring. Coming from a couple VW's and a BMW, we noticed the tighter body control of the Touring and found that preferable and worth the extra $ over the standard. The dealer found a Magnetic Grey, our second choice color, some 350 miles away. It is being moved to our dealer where we hope to pick it up on Saturday.
Chris
cjhinpa is offline
Old 03-13-2007, 12:52 PM   #4
Charles Suitt
Charles Suitt's Avatar
Send a message via Yahoo to Charles Suitt
Howdy bradysplace
QUOTE: "I was under the impression they were suppose to be 16" alum. seven spoke wheels."
They are. The wheels are finished metallic gray and use 7-spoke wheel covers. Some prefer to remove the wheel covers and use the bare wheel after adding hub covers {available for approx. $10 each}. Here are photos of both with and without the wheel covers. I preferred with WHEEL COVERS.
[attachmentid=6876]
[attachmentid=6873]
[attachmentid=6874]
[attachmentid=6875]
As for the longer spoiler, my opinion is that it makes no perceptable difference. Having driven a 2004 standard for over 2 years, in comparison I do prefer the Touring suspension, 16" wheels with Bridgestone Turanza tires. With only ~2,300 miles on the clock, it's too soon to evaluate MPG, but the larger tire footprint and lower tire pressures, I feel I will achieve about 10% lower MPG than I did on my 2004. I did not like the 'feel' of the Bridgestone tires at 40/38 psi {which I had run the GoodYears on my 2004}, so I reduced the pressures to 37/35 psi slightly above the Toyota-recommended pressures. The backup camera is 'interesting' - you can tell theres 'something back there' but judging distance is difficult due to the fisheye lens distortion. The HID headlights are great. We preferred the factory-installed leather and another consideration was getting the side airbags.
In the Package 6 + Option A, there was only $270 MSRP difference for the Touring which I thought was money well spent even if just for the batter tires.
For what it's worth - my 2¢.
2007-touring-model-priuslswithout.jpg  2007-touring-model-priusrf_with.jpg  2007-touring-model-priusrswith.jpg  2007-touring-model-priuslf_without.jpg
Charles Suitt
Dallas Texas
2007 Touring Edition
(Former Prius: 2004)
Charles Suitt is offline
Old 03-13-2007, 03:10 PM   #5
MacDude
MacDude's Avatar
Send a message via AIM to MacDude
<div class='quotetop'>QUOTE(Charles Suitt @ Mar 13 2007, 09:52 AM) [snapback]404915[/snapback]</div>
Howdy bradysplace
{snipped out the pictures}
Just to add, I think that the chrome grill may also be an indicator of the touring model.
I personally don't think that the larger wing makes much difference. The suspension and the HID lamps are nice. I compared the Touring and regular model by test driving in an empty parking lot near the dealer. zig-zagging and generally trying to 'rock' the car. The Touring model was more stable. This was important to me as I live in a rural mountain area (only 1500' but curvy two-lane roads with up to 10% grade).
MacDude
2007 Super White Touring Edition
MacDude is offline
Old 03-13-2007, 04:54 PM   #6
Texas911
Another Houston guy here that just got a Touring. I love it. Very controlled ride. But I would not charactarize it as harsh. I personally like competent handling cars so I opted for the Touring. Plus I wanted the HID lights and the bigger wheels make it look better. I think you'll be happy with the Touring. It goes around corners alarmingly fast, I guess because of the combined light weight and wider tires. Still has body roll but grip is ample. Turn in very crisp for a front wheel driver. Body motions in transition is rock solid, I would guess because of the stiffer suspension. I say go for it!
Texas911 is offline
Old 03-13-2007, 08:55 PM   #7
IsrAmeriPrius
Progressive Member
IsrAmeriPrius's Avatar
<div class='quotetop'>QUOTE(MacDude @ Mar 13 2007, 01:10 PM) [snapback]404997[/snapback]</div>
No, it is standard on all models beginning with the 2006 model year.
IsrAmeriPrius is offline
Old 03-14-2007, 02:10 AM   #8
Gadgetdad
Gadgetdad's Avatar
Package: #5 Touring
I have had my Touring edition since the last week of September, '06. I have taken my care over Tioga Pass in Yosemitee on the way to Death Valley CA. The car did wonderfully! I NEVER lacked for power and even passed other cars on the seep uphill portions. The handling was taut and responcive around the curves of the mountain pass. I just added the BT Stiffening Plate and that has improved further the ride and handling of the little wonder car! Go for the Touring... it is worth the few extra bucks. The fin is nonsense anyway, but the bigger wheels and tires give a nice feel and look to the car.
Lee
007 Super White Touring#3 with: ScanGaugeII, BT Stiffening Plate, BT Strut Tower Brace, Sharkfin antenna, black mats, K&N air filter (winter only), EV switch and constant on power socket, window tint, Mobil 1 oil. Darrell's LED's custom lights, EBH, JBL component speakers in the front & Dynamated doors. Bazooka SubW, Mudflaps with extra screw, Cyron LED footwell lighting interlinked with dome light.
On the workbench: BT Skid Plate, Sound Dampening.
Gadgetdad is offline
Old 03-14-2007, 06:47 PM   #9
douglas001001
smug doug
douglas001001's Avatar
What sold me on the touring model was exiting on a standard cloverleaf intersection going from low to high, the touring just nailed the 270 degree uphill circular turn at about 10mph higher than the speed I could hit it without squeeling the tires on my 99 civic.
Granted my civic has 120k on it with original shocks but I thought there would be no way that the prius would out handle a smaller car like that and I owned one two hours later.
douglas001001 is offline
Old 03-14-2007, 09:14 PM   #10
cireecnop1
cireecnop1's Avatar
I chose the Touring because it stood out from all the others. and it was the only one on the lot in my color. Other wise i would have bought the fully loaded base prius.
cireecnop1 is offline
looking for touring model in PA cschrading Dealers & Pricing 6 11-18-2007 08:22 AM
Base or Touring model...differences? sea-horsea Prius Main Forum 4 08-15-2007 11:39 PM
Is Touring model better in snow? Leigh Prius Main Forum 17 01-31-2007 04:14 AM
2007 Touring Model Alloy Wheels gplm2007 Fred's House of Pancakes 3 01-04-2007 12:47 AM
Will 2007 Touring model get better or worse MPG than 2006? lkhensley Fuel Economy 3 08-14-2006 04:26 PM
