Care, Maintenance and Troubleshooting This is a discussion on Good home air compressor / tire inflator? within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; I'm thinking of buying an air compressor / tire inflator so I can keep my tire pressure at optimal. Most ...
Old 08-27-2004, 02:49 PM   #1
pshady
Default Good home air compressor / tire inflator?
I'm thinking of buying an air compressor / tire inflator so I can keep my tire pressure at optimal. Most of the service stations around my house have either faulty air hoses, or don't work.
Does anyone have a good "at home" one?
I heard that the ones which you plug in to the cig adaptor can ruin your car battery. Is that true?
I would like a portable one which has a built-in gauge, and the ability to plug into both the car cig adaptor and a wall plug.
Thanks in advance!
pshady is offline
Old 08-27-2004, 03:39 PM   #2
jamarimutt
The compressors that plug into the wall inflate the tires much faster. I have seen both types, but I have not seen one that will run on Ac or DC.
jamarimutt is offline
Old 08-27-2004, 04:48 PM   #3
Bob Allen
Captainbaba
Bob Allen's Avatar
Send a message via AIM to Bob Allen
Unless you are running your car powered pump continuously, I can't see how you can "ruin" the battery. Juice is juice; the battery doesn't care where it's going as long as the amperage isn't extreme. I've had mine for several months and have only had to use it three or four times, and then only for about twenty minutes total if that. I got mine at Fred Meyer's in Seattle for ten bucks.....yup, ten bucks. It works fine, although it is slow and I doub't it would reach its stated 250 psi capacity. Takes about five minutes to bring a tire up from 30 to 38 psi. Easy to use and about the size of a portable CD player.
The advantage of the car power is that you can keep the pump in the car and use it while travelling. Fewer and fewer gas stations in Seattle, or anywhere, maintain air pumps and those that do, want 50 cents and some fast dancing on your part, in order to get your tires up to pressure.
:P Angel Flight Pilot
Bob Allen is offline
Old 08-29-2004, 05:52 PM   #4
bookrats
bookrats's Avatar
There was a good thread on compressors a [url=http://www.priuschat.com/forums/viewtopic.php?t=1246]few months ago -- you might want to check it out.
bookrats is offline
Old 08-29-2004, 06:06 PM   #5
GaryK
Wal-mart has a 2 Gallon 100 psi 110 volt model for about $69.00 that works great. Only takes about 3-4 minutes to get full. Works so well, I fill up my neighbor's portable tank when it's empty, only fair, as I borrowed it a few times before. Don't have to but those cans of air to clean out the computer dust now, so saves $ in the long run.
GaryK is offline
Old 08-31-2004, 01:47 PM   #6
pshady
I went to Pepboys near my house last night and bought a Coleman jumpstarter and compressor combo unit. This thing can charge in the wall or via cig adaptor, and can be cordless! It also has a built in worklight, and all of the cords / accessories can be stored inside the unit.
Very happy with it.
pshady is offline
Old 08-31-2004, 10:49 PM   #7
hdrygas
I bought a Craftsman from Sears that has worked for me very well. It has a small 12volt battery and can be used to power other stuff.
hdrygas is offline
Old 11-08-2004, 12:15 PM   #8
ryogajyc
Default Re: Good home air compressor / tire inflator?
I bought a tire inflator with a digital pressure gauge and auto shut-off from Sears. It was $29.99 and they had a $3 instant rebate when I bought it a couple days ago. I chose one with a digital gauge so I could get an accurate reading without worring about parallax and stuff reading an analog gauge. The auto shut-off is a nice feature, but since there is a 1-2 psi difference between actual pressure and the measured pressure when the compressor is on (due to backpressure was what the manual said), I just figured out the difference between the actual and measured pressure and handled the on/off switch manually. Just FYI if you are interested.
Craftsman 12v 250psi Tire Inflator with Digital Pressure Gauge
ryogajyc is offline
Old 11-08-2004, 02:23 PM   #9
jkash
jkash's Avatar
I bought one at target that can be plugged into a wall socket and charged as well as plugging into the power socket in the car. It works quite well. I am not at home now so I can't tell you what brand it is.
jkash is offline
Portable tire inflator? PriusRos Care, Maintenance and Troubleshooting 83 11-18-2008 05:18 PM
Replace spare tire with 12 volt compressor? smdobson Prius Modifications 14 10-04-2006 11:51 PM
Free to a good home - Grey Seat Covers pjconner Prius Main Forum 2 08-02-2006 12:10 PM
Looking for good portable cordless tire inflator jaguaraja Prius Main Forum 3 03-17-2005 01:35 PM
Tire Pressure - Portable compressor Charles Suitt Prius Main Forum 3 12-29-2004 02:10 PM
