| Care, Maintenance and Troubleshooting This is a discussion on Prius no start -- two dealers can't fix within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; whm, you mentioned a genisys scanner which I don't know if it provides access to the proprietary hybrid system codes. ... |
| | #11 |
My Car: 2001 Prius Package: Pioneer #1 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 7 | whm, you mentioned a genisys scanner which I don't know if it provides access to the proprietary hybrid system codes. My desire remains to get a Toyota shop with THHT to give you the nice long code-list. This running and dying thing could mean lots of things. I do not dismiss problems on the 12 volt side because they seem to express themselves most anywhere. BUT I want you to make sure that all the ignitor and injector connections are just as they should be. It does not take much connector unseating to create a problem situation that is very difficult to track down, without a THHT available.
| | #12 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(tochatihu @ Sep 6 2007, 05:41 AM) [snapback]507838[/snapback]</div> Quote:
There was a 12v issue -- my jump box was weak -- that was creating some of the screen flickering and other anomolies BUT I did go out the next morning with a freshly charged jump box and, again, the gas engine started up immediately. But now when trying to move the car in forward or reverse there is a loud pounding/rattling coming from the transaxle and no movement even thought the gas engine rpm's are increasing. The warning lights kicked on almost immediately and I only ran the car a short time as the noises coming from the front of the car sounded someone bouncing a bowling ball inside of the transaxle. I will double check the wiring connectors in the morning but I am probably waving the white flag at this point and will send the car back through the auction process to try and recoup some of the money/time invested in this sucker. My guess is that the transaxle has had it and, if time allowed, I would go ahead and spend the time and effort to pinpoint the issue and then continue to try and fix it. Unfortunately, I've got no time to "play" any longer and I'm really concerned that diagnosing this correctly represents more time than I've got available. I want to thank everyone for their inputs -- I do appreciate the time everyone took to try and help. thanx. | |
| | #13 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(whmracer99 @ Aug 31 2007, 07:17 AM) [snapback]504813[/snapback]</div> Quote:
You were told that the inverter and the transaxle has to be replaced at the same time. I was told that I had to change the inverter and electric water pump at the same tiime for my 2003 prius. The codes that showed up for me were P3125 and P3130 | |
| | #14 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Elaine @ Sep 11 2007, 07:58 AM) [snapback]510520[/snapback]</div> Quote:
Bottom line is that these are great cars when they work as advertised but the dealers/technical reps can be clueless if something out of the ordinairy goes wrong --- and that may be the way Toyota wants it. | |
| | #15 |
My Car: 2001 Prius Package: Pioneer #1 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 7 | Understood, you are planning to auction it as is without further exploration. There may be circumstances when inverter and the transaxle must become new together, but I don't know them. I wish your diagnosers could present something that would help us (all) to understand what's going on. If you would not mind, what is the odometer and month of manufacture (driver door frame) on this 2002 please? |
| Cold weather related? Car won't start unless we try to start about 5-10 times | JasonInNJ | Care, Maintenance and Troubleshooting | 10 | 11-30-2008 02:09 PM |
| Good Toyota/Prius Dealers | Bill Merchant | Dealers & Pricing | 213 | 10-09-2008 08:21 PM |
| Michigan Prius dealers | spaniola | Dealers & Pricing | 5 | 05-23-2007 04:06 PM |
| Do US dealers push the Prius? | molgrips | Prius Main Forum | 15 | 08-15-2006 07:07 PM |
| Prius Keeps Car Dealers -- but Not Repairmen -- Busy | jkash | Prius and Hybrid News | 6 | 06-01-2005 07:21 PM |
