| Care, Maintenance and Troubleshooting This is a discussion on 2002 Prius High-Pitched Howl Noise at speed within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; Between 28 and 38 miles per hour I hear a faint high-pitched noise that changes the frequency as I accelerate ... |
| Senior Member Join Date: Oct 2007 Location: Maryland
My Car: 2002 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Between 28 and 38 miles per hour I hear a faint high-pitched noise that changes the frequency as I accelerate or slow-down. Sounds like electric motor winding up or down but I am not sure. It is different from the noise the generator does when regenerating. Audible when in electric only or in combined mode. Not audible under even mmoderate acceleration as the engine noise then overshadows it. Any thoughts? 118K on the Prius, just bought it used and I did not seem to notice this noise before (drove it for about 400 miles so far. Perhaps I'm getting more sensitive to the noises it makes, but want to make sure. The gage shows me average of 54 to 55 mpg over the last 400 miles Washington Metro DC traffic so no complaints about the fuel economy... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Kocho @ Oct 18 2007, 09:49 AM) [snapback]527278[/snapback]</div> Quote:
What noise does the generator make when its regenerating? Never heard that noise before. I'm confused...your header states its a 2008 and your saying it has 118K on it? WOW!! Anyway I hope its not the dreaded humming of a failed M/G stator. Please search this. Its not good. Or maybe its just worn out brake pads up front and your hearing the scraper.You know the scraper that's there to alert clueless people that there pads are worn out and screeches when people go 10K more than they should on worn out pads and the pads/rivets are about to eat the rotors up. I'm sure our car has them. Never seen a car without them. Look at the rotors. There easy to see. Are they super deep worn out? Does the sound change when your coasting and then with the windows open listening apply the brakes. If the squeal goes away when you apply brake its brake time!!! Good luck! | |
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi Kocho, Have you ever had the transmission fluid changed ? That could be the bearings in the power sharing device in the transmission. The first generation cars used sleeve bearings, and the newer generation use needle bearings. Look around for Robert J Wilsons posts regarding the first generation transmission. Hi Again Kocho, You might also check the water pump, idler bearing (if the gen one has one) or A/C compressor bearing. Would be somewhat cheaper than the transmission work. Good Luck! |
My Car: 2002 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The more I listen to it, the more it seems to be electrical related. The pitch changes somewhat independently of the RPM, contrary to what I first wrote. The noise resembles the sound an electrical vehicle like a subway or airport train make when accelerating and decellerating. Tt is definitely linked to the load on the electric motor but I am not sure if it is the motor doing it or the transmission or something else. Again, not a loud noise at all and is most noticeable around 35-38 miles per hour with the gas engine off and trying to accelerate on electric power alone (try that downhill so that the gas engine does not kick-in too easily). To answer some of the questions in the posts here: - This is a 2002 Prius. I need to update my profile - I think I goofed when my first submission failed and forgot to change the vehicle back to '02. - The tranny oil I just changed last week, including dropping the pan and a new pan gasket. Some thickening on the pan bottom and magnet material but the oil had been changed some time before I bought the car and was in very good condition. Not sure what it was before that - probably very bad is my suspicion. - The generator noise that someone said they've never heard is in my opinion pretty quiet but clearly audible in my case. It is best heard when I coast down and apply the brakes lightly and brake thru regeneration. It is the noise a dynamo makes when rotating and generating current. This generator noise is a little lower pitched than the noise I am talking about but both seem to come from the sam area physically - in the cabin I hear it coming from the front right (note that the transmission is on the front left) but that may be misleading, given all the ways sound can travel... |
| Junior Member Join Date: May 2007 Location: Grand Isle, Vt
My Car: 2005 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | One of the front wheel bearings? My suggestion would be to get a mechanic to go for a ride with you - Most will do that for free... |
| | #6 | ||
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 7 | <div class='quotetop'>QUOTE(Kocho @ Oct 19 2007, 10:04 AM) [snapback]527740[/snapback]</div> Quote:
Can you find a fairly steep hill to descend at speed (aka., I-66 into Arlington or from MD-to-VA over the north side of the Potomac? Two tests I would be interested in: 1) Descend the hill starting at 38 mph in "D" and hopefully let gravity accelerate the car to +42 mph. We need to know if the sound goes away when the ICE begins spinning. MG1 rotation will approach maximum rpm as the ICE is off and the speed approaches 42 mph. This can help identify it as the source. 2) Descend the hill starting at 38 mph in "N" and hopefully let gravity accelerate the car to ~45 mph. We need to know if the sound goes away when the inverter is "out of the circuit." Try not to exceed 45 mph by using your brakes and slip back into "D" to see what happens. The MG1 max rpm is 6,500 and it would be interesting if the noise is in this speed range. There is a failure mode we are looking at that involves a coil on the MG overheating and becoming a 'disconnected' coil. This is bad because nothing the operator can do will have any effect on this progressive failure mode. We've seen it with MG2 but there is nothing that says MG1 couldn't have a problem. <div class='quotetop'>QUOTE(Kocho @ Oct 19 2007, 10:04 AM) [snapback]527740[/snapback]</div> Quote:
Wheel bearing go out but often they reveal themselves in turns. The sound will change if you turn left or right. Bob Wilson | ||
| | #7 | |||||
My Car: 2002 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(bwilson4web @ Oct 19 2007, 01:49 PM) [snapback]527816[/snapback]</div> Quote:
Thanks for the suggestions and I will try them again when I drive down hill next time. | |||||
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 7 | <div class='quotetop'>QUOTE(Kocho @ Oct 20 2007, 09:31 AM) [snapback]528145[/snapback]</div> Quote:
Have you tried a "forced charge?" This involves holding the brake with the left foot and flooring the accelerator. The car remains still while the engine revs up to put a charge on the battery. This might give a clue if the noise could be heard. However, this is something that might allow isolation of the noise using a stethoscope. It is not a trivial task and safety measures would be advised to make sure the vehicle can not move. Using "P", which engages a paw in the transaxle might also work along with the parking brake. Bob Wilson | |
| Junior Member Join Date: Oct 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I also have a 2002 Prius that i bought used last week. It makes the same noises you describe. I took it to a mechanic this weekend, and he said he never found anything wrong. But the more I think about it, the more it seems like the dreaded transaxle humming noise that's caused quite an uproar around here. Nothing is lit up on the dash, however. |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 7 | <div class='quotetop'>QUOTE(w4y @ Oct 21 2007, 11:42 PM) [snapback]528680[/snapback]</div> Quote:
Bob Wilson | |
| Engine Braking at High Speed | Marvinh | Fuel Economy | 14 | 03-03-2008 07:36 PM |
| fairly high pitched mechanized noise | econgrad | Care, Maintenance and Troubleshooting | 6 | 08-17-2007 04:38 PM |
| High-pitched noise after 5K service | aspectratio | Care, Maintenance and Troubleshooting | 10 | 03-12-2007 01:11 PM |
| Bundled High-Speed Package? | TonyPSchaefer | IL - Chicago, Illinois | 5 | 10-12-2005 11:31 AM |
| Prius shuts down at high speed | yoda | Prius Main Forum | 9 | 05-26-2005 09:36 AM |
