| Care, Maintenance and Troubleshooting This is a discussion on Blown Taillight within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; Well, the Prius is following right on the heels of our last Camry. The left taillight has blown out. (just ... |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | Well, the Prius is following right on the heels of our last Camry. The left taillight has blown out. (just like it did on the Camry). However unlike the Camry, I'm pretty sure the centre "CHMSL" won't blow since they're LEDs and hopefully Toyota has used quality LED bulbs. |
My Car: Other Non-Hybrid Package: N/A Nominated 15 Times in 1 Post TOTM Awards: 1Friends: 0 | <div class='quotetop'>QUOTE(seasalsa @ Nov 22 2007, 11:50 AM) [snapback]542963[/snapback]</div> Quote:
AS ADVANCED AS THE PRIUS IS, I'M SURPRISED TOYOTA DID NOT INCLUDE A WARNING SYSTEM FOR A BURNT OUT BULB. <_< Don't most cars nowadays have that warning system? | |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Nov 22 2007, 11:59 AM) [snapback]542967[/snapback]</div> Quote:
Mine's at 67,000kms. The parts dept. guy told me there were 3 bulbs . I'm like.. there's only one red bulb.I'm gonna make a poll and poll PCers about this lol. | |
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 21 | funny, toyota is moving away from the blown-bulb reminder system. it sucks from the customer perspective until there's a problem with the reminder system... once DH spent 3 days rewiring a 3g camry that someone tried to rewire to bypass that system, it was a real mess. |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | <div class='quotetop'>QUOTE(galaxee @ Nov 22 2007, 09:33 PM) [snapback]543123[/snapback]</div> Quote:
| Junior Member Join Date: Aug 2008 Location: Massachusetts
My Car: 2004 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | My left brake light is out but my right one works. I checked the fuses and the three bulbs I could get out of the tail light assembly from the back side. They are all three regular filament bulbs. Since none of the three come on when the brakes are applied and since I know that the brake light is a LED bulb (comes on instantly as opposed to a filament bulb that needs to heat up - you can see the difference) and I could see two small wires coming out of the wiring harness and leading into the tail light assembly, I took the tail light assembly out of the car. Looks to me that I will need to replace the whole tail light assembly to replace the LED brake light and the Toyota parts guy just told me they sell for something like $225! Anyone have a less expensive fix? |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 28 | Quote:
If you can get to that point and have a digital multimeter available, you might be able to figure out why the light doesn't work. Maybe a current-limiting resistor is burnt out... If the above is too much, then you can buy a new combination light for $138 plus shipping (MSRP of $182): Champion ToyotaWorld Note that this link is for 2004-2005; if you have a newer model then look up the combination light for your model year.
My Car: 2004 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | [quote=Patrick Wong;687307]I haven't had this problem so I don't have personal experience with the issue. Now that you have the combination light assembly out, is it possible to remove the LED brake light subassembly? If so, can you take the subassembly apart so that you can see the circuitry within? Patrick - the LED bulb is not accessable but the curcuit board is removable. If you can get to that point and have a digital multimeter available, you might be able to figure out why the light doesn't work. Maybe a current-limiting resistor is burnt out... P. W. - I had to put the tail light assembly back in because I have to drive the car tomorrow. There are several resistors on the board which I will check with my multimeter tomorrow evening and report back. I would much rather spend a few bucks on resistors than to throw this beautiful piece of plastic in a landfill. |
| The taillight bulb poll | Tideland Prius | Care, Maintenance and Troubleshooting | 9 | 11-24-2007 02:46 AM |
| Taillight Bulb #'s | treehggr | Prius Main Forum | 6 | 08-18-2007 09:21 AM |
| Taillight removal? | UCFmechanic | Care, Maintenance and Troubleshooting | 7 | 03-10-2007 09:01 PM |
| WTB: right rear taillight | fuelsipper | Private Sales | 5 | 03-04-2006 10:35 PM |
| cracked taillight lens | Hatfield | Prius Main Forum | 10 | 07-23-2005 09:28 PM |
