| Care, Maintenance and Troubleshooting This is a discussion on Abnormal Coolant Pump noise within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; I've noticed over the past few days that the coolant pump that pushes warm coolant from the vacum tank to ... |
| Senior Member Join Date: Dec 2003 Location: Surprise, AZ (Phoenix)
My Car: 2004 Prius Package: Pioneer #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I've noticed over the past few days that the coolant pump that pushes warm coolant from the vacum tank to the cylinder head intake ports (our engine pre-heater) has been making abormal "scraping" or lower pitched "squealing" sounds under operation. The sounds are akin to an old motorized toy, RC car motor, or cheap CPU fan with sleeve bearings that are on it's way out. This sound happens usually when the engine has been sitting for a few hours, but seems consistent for the last few days since I returned from AZ. I'm at about 17.8k miles, and I've had the car for nearly 11 months now. I have a few thoughts:[list]Am I the only one? If not - are we looking at another potential service campaign?[*]Should I be worried about the quality of the pump? Is it an item that can't handle extreme ambient temp changes?[list] Anyone else with a similar experience? I'm going to bring it up when I have my fuel TSB done and my center console lid replaced (the fabric is peeling away from the front of the "arm rest" a.k.a. center console lid sub-assembly). It's reproducable, and I imagine covered by the 8/100 hybrid/emissions warranty since it is part of what makes the car AT-PZEV.
__________________ Rick Johnson - Linux Geek, Private Pilot 2004 Prius - Tideland Green Pearl - Pioneer #3 (#9 pkg) - 101K miles - Factory EV Button, Homemade fog lamp grills, Goodyear Allegra tires 2002 Prius - Blue Moon Pearl - All options except NAV - 51.5k miles - Coastal Hitch Family Prius Score: 4 (2 mine, 1 parents, 1 aunt/uncle) |
| Senior Member Join Date: Feb 2004
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Rick, earlier this summer I went from San Francisco to Albuquerque via the Mojave desert, temps were in the hundreds, and I really pushed the car at 85-100 MPH through the desert. I did have to have a water valve replaced in Albuquerque, but my water pump has been fine since factory install so perhaps you are just "lucky" . It does concern me, however, that we are hearing of so many (minor) breakdowns on this chat board. I hope your dealer is close and convenient! |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I don't think 1-10 failures in 45,000 total production would warrant a TSB or a recall, as I'm sure that is probably the normal failure rate for such items. I'd be amased if Toyota would consider it a warranteed item under the HSD system. But it'll be covered under 3-36 warranty. |
My Car: 2004 Prius Package: Pioneer #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Frank, The coolant assembly is part of the system which helps the car qualify for the CA AT-PZEV rating. Therefore, it must be warranted for the longer period of time. -Rick |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Possibly the states that uses the Cal Emission warranty might, but I dont' think anywhere else. Just checked the warranty manual and under both the emmision and the Hybrid related components it isn't listed. The ICE water pump is for 5 years or 60,000 miles but no mention of the thermos pump. When you take it in for repair please ask the dealer what the warranty is on the pump. It as I understand has to have the ScanTool to purge the system after replacement so that'll take it out of the relm of DIY work. |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | So far so good just a gentle hum, but I am only at 2500. Do you have the extended warranty. I really am thinking of getting that. There is a lot new in this car and maybe this is a situation that warrants a bit of precaution. I am leaning that way. |
My Car: 2004 Prius Package: Pioneer #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Nope - no extended warranty - but I'm still covered under the 3/36, etc at almost 18k miles. I'll ask which warranty covers it when I take it in next week for the various work done. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | FWIW I'm on my 2nd '04 (about 12,000 miles between the two). The first car I got had a MUCH more quiet coolant pump than the one I have now. Mine doesn't squeal, and if I hadn't had the first car, I wouldn't know that this one was louder. Good luck, let us know! |
| Coolant pump gurggling | Cessna157 | Prius Technical Discussion | 4 | 11-10-2007 10:35 PM |
| Warm Coolant Pump | ncorman | Care, Maintenance and Troubleshooting | 3 | 10-04-2007 12:09 PM |
| 'Squeak' in coolant pump? | Zaxxon | Care, Maintenance and Troubleshooting | 1 | 07-03-2007 10:41 PM |
| Screaming coolant pump | ddd | Care, Maintenance and Troubleshooting | 31 | 02-17-2007 07:24 AM |
| Coolant Pump | BitShifter01 | Prius Main Forum | 1 | 12-13-2005 06:24 PM |
