| Care, Maintenance and Troubleshooting This is a discussion on When checkingyour oil after the dealer changed it... within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; But the question is this. Are the oil lines in/out, leading to the filter, above or below the oil level ... |
| changed, checkingyour, dealer, it... |
| | #21 |
| Senior Member Join Date: May 2008 Location: Marietta, Ga
My Car: 2008 Prius Package: #3 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | But the question is this. Are the oil lines in/out, leading to the filter, above or below the oil level in the pan. I've always drained the oil pan before removing the oil filter. And made sure the new filter was on before refilling. This is the sequence in the owner's manual. But, as long as the point at which you attach the filter is above the level of the oil pan you should be O.K. If not, it could get messy. |
| | #22 |
| Getting Greener.... Join Date: Feb 2008 Location: Napolis, Merlin
My Car: 2008 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | The book says 3.9 quarts. I'd be surprised if you got that much out on a regular oil change. There are often tiny trapped pools of oil within an engine block or the lines. |
| | #23 |
| Fat Member Join Date: Jul 2007 Location: Sunny S. Florida
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | the oil pan is below the filter, so only what is in the filter will come out |
| | #25 |
My Car: 2004 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | There isn't that much oil in the filter, it just happens to be messy when you start to take it off. It is at an angle and after you have turned it some, the oil starts to leak down the side. Several 'lessen the mess' options have been suggested:
__________________ Bruce Mine: Driftwood '04 BC 24 Sept 2004 - added: mudflaps, door edge guards, side panel mouldings, Coastal Tech EV switch, Goodyear TripleTred tires WeatherTech window deflectors. Last tank - 14 July '08: 258.2 miles - computer MPG:52.3 Actuals Lifetime: 71197.5 miles, 48.40 MPG. Wife's: Barcelona '06 #7 May 2006 - added: front mudflaps, Coastal Tech EV switch. Last tank - 18 July '08: 444.7 miles - computer MPG: 51.0 Actuals Lifetime: 24,389.9 miles, 45.58 MPG. |
| | #26 |
| Member Join Date: Sep 2006 Location: NC
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I played around with putting a cut-off 1-liter coke bottle over it as I unscrewed it, as some have suggested, but it was so awkward that now I just unscrew it very slowly until it starts to dribble out, then go do something else for 5 minutes while the oil that's going to leak out does, then come back and carefully unscrew it the rest of the way. |
| | #27 |
| ichorous liquor Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | NaptownPrius, did you wipe the dipstick dry before inserting it, and then pull it out for the read? Three quarts even is plenty for an oil change. It prevents overfills, and if you buy the oil, avoids having a leftover partial bottle. Try it and see. |
| | #28 |
My Car: 2008 Prius Package: #3 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I like this approach! We just had the oil changed in the Avalon 5.0 quarts, @dealer, but took our own oil. Had picked up case on the way. One uopened quart left. Were does 3 quarts leave the oil on the dip stick? Still on wait list. Can't check t out. Thanks again! I like it. |
| | #29 |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | In seven out of seven oil changes in mine (I had not thought to try this on the first one, and by golly it was a bit overfilled) using three quarts leaves the oil level a little above the halfway point on the dipstick. In mine at least the level does not change noticeably during use. |
| What I'd had changed about the Prius | PoulStaugaard | Prius Main Forum | 4 | 12-17-2007 02:06 AM |
| I just changed the PSD fluid! | Floyd | Care, Maintenance and Troubleshooting | 15 | 10-30-2007 02:50 AM |
| Tire pressure changed by dealer | Bossman | Care, Maintenance and Troubleshooting | 17 | 10-21-2004 06:06 PM |
| I think I've changed my mind. | daniel | Prius Main Forum | 12 | 07-29-2004 02:01 AM |
| Changed Around a Few Things | Danny | PriusChat Website Questions | 2 | 03-29-2004 08:30 PM |
