Care, Maintenance and Troubleshooting This is a discussion on Prius Won't Start within the Care, Maintenance and Troubleshooting forums, part of the Toyota Prius Forums category; Just tried to start my new 2008 Prius, 16,000 miles, and got the Problem icon and the car stopped. Now, ...
prius, start, won't
Old 07-20-2008, 02:47 PM   #1
jsheldahl
Exclamation Prius Won't Start
Just tried to start my new 2008 Prius, 16,000 miles, and got the Problem icon and the car stopped. Now, the car won't start, but when I do attempt, the display shows this icon:
http://mahanon.net/photos/a38f22815ac3.jpg
I got the car used, and a manual is on the way, but I have no idea what this icon means. Can someone explain? I'll be calling Toyota on Monday.
Thanks!
Julian
jsheldahl is offline
Old 07-20-2008, 03:38 PM   #2
richard schumacher
ichorous liquor
Default Re: Prius Won't Start
That's the generic something-is-bad icon. Are there no other warnings or icons? What does the fuel gauge show?
Did you buy it from a Toyota dealer, or pay a Toyota dealer to thoroughly check it over before buying? [D'ohh!! Nevermind, I see now that you bought it new.]
richard schumacher is offline
Old 07-20-2008, 03:41 PM   #3
donee
Hi js...,
Assuming (dangerous) you are new to the car here are the things to check. Are all the doors fully closed? The rear hatch has a tendency when the support struts are new to not close all the way. Really push it down when you close it. And the most common newby "can't get the car to start" issue is pushing down on the brake pedal firmly (again with all the doors closed) when you press the start button.
Check those two things out, and see what happens.
donee is online now
Old 07-20-2008, 04:50 PM   #4
jsheldahl
I got the car from a different dealer, actually, and hadn't had it checked over yet, because it was so new and I figured I could get it all looked at with the warranty at my first oil change. Maybe this wasn't the best decision, but it's what I did decide and will have to live with.
The gas gauge has two pips left on it, and it's ready to go down to 1 pip any time. The current tank has about 450 miles on it, so I'm getting ready for a refill. I've only driven the car about 1500 miles.
Funny thing, I was just putting the plates on this afternoon and I had opened the hatchback for something, I don't remember what, and I thought that was surely the answer. Just tried it and made sure that the door was closed really well, but that didn't turn out to be it.
There aren't really any other warning lights on that I can tell. The brake light is on, the warning icon, ABS icon, and check engine light. In other words, the car is dying somewhere in the boot up process, but it almost looks like it hasn't diagnosed the problem yet.
Any other ideas? I really appreciate these! I'm planning to call my Toyota dealer on Monday and have the car towed there to be looked at, since I can't really move the thing. Still, it would be AWESOME if I could get out of that whole mess with a simple fix. Alas, life doesn't always work that way.
Thanks again!
Old 07-20-2008, 04:55 PM   #5
dbuchanan
Thanks!
Julian
You need to have the key inside of the car!!
This also stumpted me the first time I saw it.
dbuchanan is offline
Old 07-20-2008, 05:13 PM   #6
Sheepdog
C'Mere Sheepie!
Sheepdog's Avatar
Friends: 5
I have seen that icon when Im in my wifes car and she walks away with the key while I stay in the car. It's almost like it misses her! Maybe it just misses the key?!
Sheepdog is offline
Old 07-20-2008, 05:20 PM   #7
jsheldahl
Actually, I don't have the SKS (which I totally should have mentioned), so I have to insert the key into the ignition to start the car. Thanks for the idea, though!!!
Old 07-20-2008, 05:59 PM   #8
edthefox5
edthefox5's Avatar
Originally Posted by donee View Post
Hi js...,
The car will start and run fine with the hatch open it just puts up the standard door is ajar red nag and pushing down on the brake pedal firmly when you push the start button is exactly how you should start the car.
edthefox5 is offline
Old 07-20-2008, 06:07 PM   #9
edthefox5
edthefox5's Avatar
Thanks again!
Without turning the the car on just put the headlights on. Are they bright?
I bet not.
My guess is you left a vanity light on or a door ajar all night and it killed the boot battery in the trunk.
NOTE!!!!!!
If dead boot battery be extremely careful I repeat extremely careful if you jump start it. Use the front jump points under the hood and if you reverse the polarity on the jump leads you will severely damage the car.Look in the owners manual on the jump points. The positive is RED. If your not an ace at jump starting a car do not do it on this one.Good luck. I'm sure its something stupid. Don't make it worse.
Old 07-20-2008, 06:58 PM   #10
jsheldahl
I bet not.
NOTE!!!!!!
I'll definitely give that a try! It would make sense that this would be a simple, stupid thing. Since I'm not a pro at jump-starting, I'll call Toyota in the morning and suggest that this is the problem. Without a manual (I got it used, and it's been ordered), I probably shouldn't attempt it myself or get someone inexperienced with the Prius to try it, either. I really appreciate the suggestion, and I can't wait to check as soon as it gets dark out (I'm not at home anyway).
I'm definitely going to read up on how to jump start this baby, just in case this ever does happen again. I'll let everyone know if that's the case or not. Not because if it goes to the dealership they can't figure it out, but if you're anything like me, you'd want to know the end of the story.
Thanks again!
Julian
Help! Prius won't start without key Dipena Care, Maintenance and Troubleshooting 5 06-29-2008 04:37 PM
My Prius Won't Start afg1236 Care, Maintenance and Troubleshooting 9 06-17-2008 09:24 AM
just got my prius and cant get it to start donut132 Care, Maintenance and Troubleshooting 8 06-07-2008 08:59 AM
Prius won't start tommyrhoads Care, Maintenance and Troubleshooting 22 12-03-2007 02:22 PM
Cold weather related? Car won't start unless we try to start about 5-10 times JasonInNJ Care, Maintenance and Troubleshooting 7 11-26-2006 10:32 AM
