Go Back   PriusChat Forums > PriusChat Forums > Other Cars > Chevrolet Volt
This is a discussion on Lutz hints at Pure EV Volt within the Chevrolet Volt forums, part of the Other Cars category; Instead of going pure EV , they should put cheaper NMH batteries (no Li-Ion expensive, hot ones) in a Volt, ...
Old 06-15-2008, 12:18 AM   #21
TransferFunction
Default NMH now!... Li-Ion later.....Re: Lutz hints at Pure EV Volt
Instead of going pure EV, they should put cheaper NMH batteries (no Li-Ion expensive, hot ones) in a Volt, get 15-20 miles out of a 500 lb NMH battery pack, and use a small 1.0L 3-cylinder engine to just recharge the batteries. Overall, you'd get about 50 MPG easily and great range. But Noooooo, GM in all their wisdom has chosen to put Li-Ion batteries in that only Donald Trump can afford. And remember those Li-Ion batteries must be cooled like crazy so they don't explode/catch-fire. Maybe Li-Ion batteries will get cheap enough and they solve the melt-down problems in about ten years or so, but until then they could have a dependable, cheaper NMH-based product with a tiny gasoline engine operating in its sweet spot for max efficiency. No all-EV, and no crazy premature attempt at stuffing Li-Ion batteries in a series hybrid before that tech is ready. And the Volt fans out there know how great it would be to do away with the transmission, as series hybrids like this do.
TransferFunction is offline
Old 06-15-2008, 06:09 PM   #22
JSH
JSH's Avatar
Default Re: NMH now!... Li-Ion later.....Re: Lutz hints at Pure EV Volt
Originally Posted by TransferFunction View Post
Instead of going pure EV, they should put cheaper NMH batteries (no Li-Ion expensive, hot ones) in a Volt, get 15-20 miles out of a 500 lb NMH battery pack, and use a small 1.0L 3-cylinder engine to just recharge the batteries. Overall, you'd get about 50 MPG easily and great range. But Noooooo, GM in all their wisdom has chosen to put Li-Ion batteries in that only Donald Trump can afford........
GM can't use NiMH batteries unless Chevron lets them. Cobasys (a joint venture between Chevron and Ovonics) holds the patents for NiMH batteries until 2015. GM used to own part of these patents but sold their share to Chevron after the killed the EV1 program.
JSH is offline
Old 06-19-2008, 12:15 AM   #23
TransferFunction
Default The chemistry isn't patented...Re: Lutz hints at Pure EV Volt
Couldn't GM source the NMH batteries elsewhere? I personally know of one company, Nilar, that would be happy to produce their NMH batteries. Nilar currently supplies NMH to plug-in Prius conversions. Are you saying that Cobasys owns a patent covering the NMH basic chemistry? That can't be right; everybody seems to sell NMH batteries.
Old 06-23-2008, 08:11 AM   #24
daniel
Cat Lovers Against the Bomb
daniel's Avatar
Default Re: Lutz hints at Pure EV Volt
Lithium-Iron-Phosphate (LiFePO4) batteries do not experience thermal run-away and do not require cooling. So this is no longer an issue. Tesla Motors uses Li-Ion and a fancy liquid-cooling system because they designed the Roadster before the LiFePO4 were available, and because laptop batteries are readily available. But nowadays most people going to lithium are using safe LiFePO4. (Including me, in my Xebra.)
It's not a question of who produces the batteries. Cobysys owns the patent, so nobody can legally produce them without permission, and they are not giving permission for anything larger than the battery in the Prius.
Our idiotic patent laws allow a patent holder to keep a technology off the market for cynical reasons, even when that technology is critical for national security, as in the case of energy dependence.
Daniel
Primary car: 100% Electric 2003 Porsche 911 Carrera. Estimated range at 55 mph: 81 miles total or 64 miles to 80% discharge. Top speed 70 mph.
Secondary car: Zap Xebra SD, also 100% electric. 1.9 cents per mile. Range: 40 miles total, or 32 miles to 80% discharge. Top speed 35 mph. Faster downhill. Both EVs use electrons generated from water power.
Gas guzzler for when I have to travel farther than 60 miles: 2004 Prius.
-- Emma Goldman
-- Otto von Bismarck
daniel is offline
Old 06-30-2008, 05:55 PM   #25
tripp
tripp's Avatar
Friends: 6
Daniel's right. Panasonic got in trouble with Cobasys for the batteries that they produced for the RAV-4EV. The patent expires either in 2009 or 2015. I'm not sure which. Of course, NiMH is not the future of battery tech, but Daniel's point about the cynicism is quite valid. A patent should be be honoured if the holder is just sitting on it, making no attempt to manufacture or market the product. It's absurd.
tripp is offline
Old 09-04-2008, 08:18 PM   #26
TransferFunction
Thanks for the info, hybrid people. However, as long as NiMH batteries, such as those in the Prius, are durable, and much cheaper than Li-Ion batteries, they are a good choice for hybrid vehicles. Plug-in hybrids such as the Chevy Volt or the next Prius can still get good electric-only range using NiMH batteries. The Volt will 40 mile range with Li-Ions, and can get 20 miles with NiMH, still resulting in good overall performance at a reasonable cost with durable, proven tech.
Old 09-05-2008, 08:01 AM   #27
hill
High Fiber Member
hill's Avatar
If they DO make another EV? Will they call it EV1-enstein, or will they call it Franken1 ??
hill is offline
Old 09-08-2008, 06:14 PM   #28
TransferFunction
OK, if NiMH batteries are not a good idea (patent problems) then maybe the solution is to use only half as many Li-Ion batteries, getting a 20 mile EV-only range (instead of 40 miles), which would then enable them to shrink the gas engine down just a bit, and it would make the vehicle lighter overall. Most of all, it would reduce the price by $4,000, since the Li-Ion batteries are expensive. Also, acceleration and handling would be better. They could use the same Volt chassis and body, only having to lighten up the springs a bit. More people could afford it, and it would still easily get 50 MPG year around. Also, less strain on the electrical grid at the start of this EV revolution in society. Then, GM could gradually, over several years, increase the EV-only range of the vehicle, something to offer new buyers every year.
Old 09-08-2008, 08:26 PM   #29
miscrms
Plug Envious Member
I think you're on the right track. I've been arguing a similar point. 40 mile range is great until you have to pay for the batteries. Li-ion being 1/2 the weight of NimH is great, until you have to pay for the batteries. I think Toyota's presumed strategy of starting with a 10 mile range in either NimH or Lion at an added cost of $3-5k makes a lot more sense than GM going for 40 miles of Lion range at an added cost of ~$15-$20k
FWIW, GM is buying the NimH for their current "hybrids" from.... Cobasys. Chevron hadn't shown any real interest in selling NimH to anyone until GM came back on the scene. Of course, GM just had to recall all their hybrid batteries. And now they are thinking about trying to buy back part or all of Cobasys from Chevron, who they sold it to 10 years ago. These people are geniuses I tell you!
Rob
miscrms is offline
Old 09-08-2008, 10:16 PM   #30
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
The Cobasys patent issue is explained here:
EV World Blogs: Personal Perspectives on the Future In Motion
pretty well. I wish I knew the actual US patent # that is at the center of this issue. Ovonics has quite a few.
tochatihu is offline
"Volt Batteries Ready" Says GM's Lutz hill Prius and Hybrid News 8 03-22-2008 09:16 PM
Bob Lutz, the Chevy Volt and the Easter Bunny Fibb222 Prius and Hybrid News 8 11-22-2007 10:31 AM
Pure EV's Available in Los Angeles?! vgan Other Cars 3 12-13-2006 07:18 PM
Prius Hints Alnilam Gen II Prius Main Forum 3 06-08-2006 01:50 PM
hints from UPS to save gas DaveinOlyWA Gen II Prius Fuel Economy 2 08-14-2005 04:42 PM
