| This is a discussion on Winter operation of GM Volt within the Chevrolet Volt forums, part of the Other Cars category; Originally Posted by usbseawolf2000 Hopefully, Volt uses A123 LiFePO4 battery. The issue with LiFePO4 is low energy density and high ... |
| | #31 | |
My Car: 2005 Prius Model: Package: #4 Thanks: 6
Friends: 4 | Quote:
Rob | |
| | #32 | |
However, as I said above, when the car was 500 lbs heavier (and I could use the K-a-W meter) the car went 3 miles on one kWh, so I presume it now goes the same or a tiny bit farther.
__________________ Daniel Primary car: 100% Electric 2003 Porsche 911 Carrera. Estimated range at 55 mph: 81 miles total or 64 miles to 80% discharge. Top speed 70 mph. Secondary car: Zap Xebra SD, also 100% electric. 1.9 cents per mile. Range: 40 miles total, or 32 miles to 80% discharge. Top speed 35 mph. Faster downhill. Both EVs use electrons generated from water power. Gas guzzler for when I have to travel farther than 60 miles: 2004 Prius. "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck | |
| defrost, heater, volt, winter |
| Non-operation | Lynne | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 06-05-2007 08:30 PM |
| Operation Imposing Law | Beryl Octet | Fred's House of Pancakes | 0 | 02-21-2007 09:00 AM |
| Operation in "real" winter environments | David Beale | Gen II Prius Technical Discussion | 27 | 09-15-2006 04:47 PM |
| A/C Operation | fchung76 | Gen II Prius Main Forum | 6 | 06-16-2006 08:06 PM |
| Radio Operation | berryman | Gen II Prius Main Forum | 2 | 10-28-2004 07:21 PM |
