Go Back   PriusChat > PriusChat Forums > Environmental Discussion
Environmental Discussion This is a discussion on Cause of Global Warming within the Environmental Discussion forums, part of the PriusChat Forums category; <div class='quotetop'>QUOTE(Dragonfly @ Aug 14 2006, 01:38 PM) [snapback]303066[/snapback]</div> Excellent work Marlin! I agree here, this is potentially a viable ...
Old 08-14-2006, 02:32 PM   #21
Marlin
Marlin's Avatar
Excellent work Marlin! I agree here, this is potentially a viable hypothesis that warrants further study. So let me ask you, do you personally believe that this overwhelmingly accounts for the temperature rise, in lieu of any significant anthropogenic contribution?
I'm not sure. There seem to be scientific opinions on both sides, with a few in the middle. The majority seem to be in the "all human caused" camp which would appear to lend weight to the "all human caused" argument. But then again, there was a time when the majority of scientists thought the world was flat and would sharply criticize anyone who suggested it was round. It turns out they were wrong, although you wouldn't have been able to convince them of it at the time.
So, do you have an open mind? Or do you reject any possibility that there could be a natural component to global warming? Should we abandon any research into other factors, such as cosmic rays and clouds, because we already "know" the answer?
Marlin is offline
Old 08-14-2006, 03:18 PM   #22
dragonfly
dragonfly's Avatar
<div class='quotetop'>QUOTE(Marlin @ Aug 14 2006, 01:32 PM) [snapback]303113[/snapback]</div>
I absolutely agree with you. I don't know if it is completely due to human factors, and I am open to the possibility that there are other contributors. With respect to clouds - we know surprisingly little about cloud formation, cloud-aerosol interactions, and cloud response. For example, while cloud albedo reflects radiation back to space, having a cooling effect, clouds also play a heavy role in insulating the Earth's warmth (the greenhouse effect). What are the factors that determine the net effect by clouds? Difficult to say. How much of cloud formation has to do with seeding from anthropogenic aerosols? We don't know. There is a great deal to learn here. But the connection between greenhouse gases and GW is pretty convincing, and holds through the climate record, before humans had anything to do with it. That's why I think that if we increase the GHGs, as we clearly are [I don't think there is any dispute there, right?], we will (at least to some extent) influence GW. And the longer we wait to do anything about it, the more influence we will have. And the rate at which we are doing it is alarming.
dragonfly is offline
Old 08-14-2006, 10:28 PM   #23
jimmyrose
jimmyrose's Avatar
It would be simplistic to point to just one cause of global warming, given the many variables involved. Yes, there is a natural global warming effect, cosmic effects, humanity's contributions, etc.. I'm not in the "humans only cause global warming" camp. I do believe, however, that we tend to severely disrupt the natural order and balance of things, and I'm frankly astounded when people state that what we do has NO negative impact on our environment. We should be custodians of this planet, not abusers.
jimmyrose is offline
Old 08-15-2006, 09:20 AM   #24
DaveinOlyWA
Opps !! I Did it Again!!
DaveinOlyWA's Avatar
Friends: 5
<div class='quotetop'>QUOTE(SSimon @ Aug 14 2006, 09:07 AM) [snapback]303011[/snapback]</div>
Daveinolywa I thought you may be interested in this link. It's a study regarding the use of native flora for sustainable fuels. I'm wondering if you have any knowledge about the benefit of planting natives for carbon sequestration??? I have restored my yard with all native species for wildlife, drought and biodiversity reasons but am wondering if carbon sequestration is also occuring on my lot. I'm going to google and see if I can come up with anything.
Here's the link regarding native flora and sustainable fuels.......
http://www1.umn.edu/umnnews/Feature_Storie...able_fuels.html [/b]
i wouldnt be surprised if this article was one of the ones cited by Michael Pollan in his book "The Omnivore's Dilemma, The History of Four Meals". because he states the exact same thing but for a completely different reason. have grasslands (which typically can have up to 150 different species) grazed by cattle, produce better meat quality, but at the same time, a well managed field can actually support more animals than corn if the growing cycle of the pasture is maximized. because grasses always tends to balance "roots to shoots" iow, the above ground mass equals the below ground mass, each time grass is cut or eaten, an equal part of the grasses' root system dies off and turns to humus which sequesters a relatively large amount of carbon into the ground.
in places devastated by fire or flood, grasslands are by far the best and quickest method to rebuild sod and topsoil that there is and this mechanism is the reason why.
here is a quote from the book mentioned above that nearly floored me. before this, i thought myself to be pretty well informed about global warming and its causes. this statement reveals something completely different.
This productivity means Joel's pastures will, like his woodlots, remove thousands of pounds of carbon from the atmosphere each year; instead of sequestering all that carbon in trees, however, grasslands store most of it underground, in the form of soil humus. In fact, grassing over that portion of the world's cropland now being used to grow grain to feed ruminants would offset fossil fuel emissions appreciably. For example, if the sixteen million acres now being used to grow corn to feed cows in the United States became well-managed pasture, that would remove fourteen billion pounds of carbon from the atmosphere each year, the equivalent of taking four million cars off the road. We seldom focus on farming's role in global warming, but as much as a third of of all the greenhouse gases that human activity has added to the atmosphere can be attributed to the saw and the plow
i have quoted this passage in a few other posts so forgive me if you have seen it before.
My 2006: Last tank 463.1 miles @49.2 pump (49.4 computer) 4.22 cpm
winter mpg 50.70 summer mpg 54.59
lifetime: 33,038.3 miles 52.79 mpg pump (54.04 mpg computer) 5.74 cpm
My 2007 Zenn Driven 5945 miles, 2.01 cpm/ 105 mpg (at $2.05/gal), 4.04 miles/ Kwh
Savings over my Prius $302.66 The Corolla...573.26
The REAL SAVINGS from not driving Corolla 657.39 +Prius= 958.18 (excludes maintenance costs...would be unfair to ICE vehicles)
DaveinOlyWA is offline
Old 08-15-2006, 11:54 AM   #25
SSimon
It's an interesting concept. I wonder if it's disputed at all.
I was reading about the nutritional content of our native flowers and grasses and each has it's own protein, carb etc component so I'm not surprised that the animals are benefited by this diversity instead of residing on a monoculture diet. That, coupled with the fact that native flowers and grasses do not require as much management (irrigation, pesticides etc) as our crops, has me wondering why not many farmers have paid mind to this theory. I would think that it would be very cost effective. All other wildlife would benefit from a conversion of our farms to this method as well.
The book that you reference sounds like a good read to connect one's diet with the environment on a lot of different levels. I don't eat animals so I'm slightly removed from this equation.
SSimon is offline
Old 08-15-2006, 12:12 PM   #26
DaveinOlyWA
Friends: 5
after you read the book, you will be GREATLY removed from eating meat. SuperSize Me reduced my trips to fast food joints about 90% (still go about twice a month...better than 4-5 times week).
reading this book will make me think twice about eating any kind of processed food. but what gets me is whole foods. chickens, beef, etc. foods i thought previously to be "ok" since they had not been processed. but in reality they have, and after finding out how they are processed, you WILL definitely lose some appetite.
Old 08-21-2006, 02:27 AM   #27
nerfer
A young senior member
nerfer's Avatar
Package: #1
<div class='quotetop'>QUOTE(DaveinOlyWA @ Aug 12 2006, 12:06 PM) [snapback]302155[/snapback]</div>
well lets pretend that us spewing CO2 into the air at a rate of over 100 million tons a day from coal fired power plants and gas guzzling cars isnt causing global warming although its been proved that CO2 is a greenhouse gas.
then lets look at the reduction of millions of acres of grasslands that have been plowed under to create industrial farms to grow things like corn.
grass is vital to the balance of nature simply because it is the best method we have for the sequestration of carbon. the most effective way of removing carbon from the air is to create grasslands and have ruminants (animals that eat grass) maintain it. a well maintained pasture (in certain parts of the country) will sequester more carbon than a forest will.
the reason is that grass tends to balance itself from roots to shoots. that means that grass if 12 inches below ground, will also be about the same above ground. if a cow should take 8 inches off the top, the first thing the grass will do is kill off a corresponding amount of root system turning the roots into humus which enriches the soil and returns carbon to the ground. as the grass recovers from the cows attack, it removes more carbon from the air as CO2 and then the root system grows to match the shoots.
Interesting hypothesis, but you're missing a couple points: 1) cows create methane, a more potent GWG than CO2, 2) I really doubt grass keeps killing and regrowing its roots - I think it's more likely it uses energy stored in the roots to send up new shoots or add growth to existing shoots (surely this depends in part on the species involved), 3) carbon in the soil will largely be returned to the air during decomposition, ingestion by worms, bugs, and microbes.
I have heard that tall-grass prairies sequester more carbon than forests do (more plant growth). I hadn't heard the same claim about cow pastures. And still somehow this carbon needs to be buried or permanently stored somehow, otherwise it all eventually returns to the atmosphere for another plant to (hopefully) take it in. Nature is great at recycling.
I'd be interested in reading the book where you gathered this information. What is its name? It's definitely true that farming has changed the face of our land, and in a big way, so it could be affecting it. Illinois for instance has lost over 99.5% of its original prairie. I'm also not a big fan of corn - that requires a lot of resources to grow, as far as tractor runs, fertilizers, herbicides and insecticides. Definitely pasture-fed beef is better than feed-lot beef. Fruit and vegetables are better yet.
<div class='quotetop'>QUOTE(Marlin @ Aug 14 2006, 12:00 PM)</div>
One theory that I think has merit is the increased solar activity. Solar activity is at a 1000 year high and has shown a sharp increase in the 20th century. (Quite a coincidence, don't you think?)
I've seen numbers (realclimate.org, for one) that give solar variance about 10-30% factor in the current rise in temperatures. Right now we're in the middle of the 11-year solar cycle, so it should be relatively cool for a year or two. A big volcano would also change things. But you can't deny that human activity has pushed up the CO2 levels way out of whack from what we've seen in the last 400,000 years, and that higher CO2 levels are associated with higher global temperatures.
"We must be the change we seek" - Gandhi
nerfer is offline
Old 08-21-2006, 09:46 PM   #28
DaveinOlyWA
Friends: 5
<div class='quotetop'>QUOTE(nerfer @ Aug 20 2006, 11:27 PM) [snapback]306591[/snapback]</div>
I've seen numbers (realclimate.org, for one) that give solar variance about 10-30% factor in the current rise in temperatures. Right now we're in the middle of the 11-year solar cycle, so it should be relatively cool for a year or two. A big volcano would also change things. But you can't deny that human activity has pushed up the CO2 levels way out of whack from what we've seen in the last 400,000 years, and that higher CO2 levels are associated with higher global temperatures. [/b]
the book be "The Omnivore's Dilemma: The History of Four Meals" by Michal Pollan.
very good read. gives huge insight to the foods we eat what it does to us.
Old 08-21-2006, 10:12 PM   #29
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Nominated 3 Times in 2 Posts
Friends: 6
<div class='quotetop'>QUOTE(nerfer @ Aug 21 2006, 01:27 AM) [snapback]306591[/snapback]</div>
I find it hard to believe that cows farting has more of a negative impact on Global Warming than human activity I.E. cars and factories. (Not counting agricultural fertilizers and corn vs. grass et al.)
How many cow farts = a year's worth of running an ICE car on average? Anyone?
Godiva is offline
Old 08-21-2006, 10:25 PM   #30
F8L
Collecting Data on Nature
F8L's Avatar
Nominated 1 Time in 1 Post
Friends: 15
<div class='quotetop'>QUOTE(Godiva @ Aug 21 2006, 07:12 PM) [snapback]307244[/snapback]</div>
It may be they are speaking of cows in a broader sense. The deforestation that goes hand in hand with cattle. The vast amount of grains that are gorwn to feed cattle to produce 1/3 or less energy than would be had if we just ate the grains. Then toss in the expulsion of gas and waste. There are A LOT of cows in this world. A LOT!
F8L is offline
GWB on Global Warming efusco Fred's House of Pancakes 8 07-22-2008 01:41 PM
Global warming imntacrook Fred's House of Pancakes 12 04-12-2007 01:42 PM
"Why Americans are Skeptical of Their Role in Global Warming" (aka Global Climate Disruption) Mirza Fred's House of Pancakes 7 03-13-2007 08:14 PM
What do you think about Global Warming? malorn Environmental Discussion 49 02-16-2007 02:53 PM
High court to hear global warming case-Must Bush Change Course on Global Warming hb06 Environmental Discussion 17 12-21-2006 02:34 PM
