Go Back   PriusChat > PriusChat Forums > Environmental Discussion
Environmental Discussion This is a discussion on Do grass lawns help global warming? within the Environmental Discussion forums, part of the PriusChat Forums category; Grass lawn?? Blahh... Multiunit housing in the city is the best way to go, then you don't have a lawn ...
Old 04-05-2007, 02:37 PM   #21
MarkMN
Grass lawn?? Blahh... Multiunit housing in the city is the best way to go, then you don't have a lawn whatsoever to worry about. You people and your energy guzzling housing styles. <_<
MarkMN is offline
Old 04-05-2007, 05:46 PM   #22
Darwood
Darwood's Avatar
Multi-unit housing...
No thanks.
Most are rentals, I own, which means I make money on my property instead of paying rent and getting nothing back.
Even townhomes and other "owned" multiunit housing are unappealing to me.
You have limited if any gardening space, Most have association fees and rules. Dogs are a pain in those where they are allowed, both for the owner and the neighbors. Your neighbors bed could literally be 8 inches away from yours.
Your neighbors could burn down/flood their (and hence your) house/possessions. They could just be an Ahole and make your life there miserable and resale goes down due to their own lack of caring or late night partying. Parking is always tougher.
Granted, some of these are true to a smaller degree with houseing, but you can better predict which homes will build value by the neighborhood than you can in a multihousing unit.
My first house, in an inner ring suburb, resold for 2.5 times what I payed for it (9 years, and a lot of remodeling later). Now I'm doing the same to a 2nd house that had been neglected.
_____________________________________
......My other car is a Prius too!......
Darwood is offline
Old 04-08-2007, 12:36 AM   #23
acdii
<div class='quotetop'>QUOTE(dbermanmd @ Apr 4 2007, 12:12 PM) [snapback]417676[/snapback]</div>
Obviously not - they indicate the presence of homosapians - the #1 cause of gw. So no lawns = no humans = no global warming.
DO you seriously believe that statement? Really? I suppose you grovel at al gores feet too! Really! Wow, that is mind boggling. Here, let me explain to you what causes global warming. THE SUN!!!!!!! I suppose you think we are also the cause of the ice caps shrinking on mars because we humans have a mars rover up there too! CO2, does not generate heat, it may help maintain heat, but it in NO WAY CAUSES HEAT! The sun has been brighter in the past few years than it has been in at least the past 100 years. We have contributed a small portion to CO2 output, that is a given, but so do Volcanoes, and forest fires, and guess what, those occure naturally. I am not denying that the earth may be a degree or two warmer than past records show, but then again, history has shown that warming and cooling of the planet in extreme degrees is natural, and has happened long before humans were here, and will happen long after we are gone.
BTW if global warming was such a big factor, then why the hell has it been so damn cold this week? THe daily temps havent even reached the normal lows! If you believe Gore, the biggest hypocrite of them all, then I have one thing to say to you. You are a FOOL. [/rant]
acdii is offline
Old 04-08-2007, 12:41 AM   #24
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Nominated 3 Times in 2 Posts
Friends: 6
And it ain't the fall that kills you.
It's the sudden stop.
There's a difference between weather and climate.
Godiva is offline
Old 04-08-2007, 09:46 AM   #25
SSimon
<div class='quotetop'>QUOTE(ACD @ Apr 8 2007, 12:36 AM) [snapback]419722[/snapback]</div>
Gore is the deliverer of the GW message, not the source. The majority of climate scientists concur that the planet is warming as a result of human contribution.
In your end statement you declare that you also base your views on your local temperature. GW is not based on the temperature trends in one area.
You also attacked the wrong person. Dbermanmd rejects the theory of GW. His sarcasm abounds.
So, you exhibit obvious error on multiple fronts.
SSimon is offline
Old 09-01-2007, 08:18 AM   #26
patsparks
Uneducated bird-brain Aussie
patsparks's Avatar
Friends: 17
Who would have guessed the depth of ignorance was so great?
patsparks is offline
Old 09-01-2007, 12:19 PM   #27
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Friends: 6
Well, So Cal is being forced into even more water conservation. We have to cut another 20%. Or I should say the "little people" will have to conserve probably about 80% to make up for those who will simply continue to overwater their huge lawns because "they can afford it".
I don't have lawn. I have brick with planter beds. I have a small patch of what I'm hoping will be dicondra in the front. The rest is trees and bushes. Roses, geraniums, a few ornamental grasses. I'm looking to put in three more trees but they will be dwarf fruit trees and on drippers. I'm going to espalier them up the garage wall. Except for the dicondra patch (about 10x14) everything else is on drippers. But my water consumption *is* going to go up. Because before I had dirt that I didn't water, now I have plants that I am going to water, even if I'm watering as conservatively as I can. Why should I have dirt and cactus for landscaping when I can go through every affluent neighborhood in the county and find huge lawns that use more water in a week than I use in a month? Why do those lower in the social order have to do without so those at the very top can have anything they want?
Call me spoiled or self-indulgent but I think I'm entitled to some trees and bushes. It also raises my property value to have trees and roses instead of dirt and rocks.
So....are roses and geraniums better than ornamental grass lawns?
"It's not just chocolate...it's a lifestyle."
Originally Posted by jbarnhart View Post
One side won't accept any information that currently exists. The other can't provide any data acceptable to the first.
Godiva is offline
Old 09-01-2007, 12:45 PM   #28
h2photo
Turning greener day byday
h2photo's Avatar
Package: G Touring
Send a message via AIM to h2photo
we just killed our grass lawn and put in Rocks. It was costing us a fortune to keep it pretty, green, & Weedless. It was great for us too, the city gave us $200 back for switching 50% of our lawn to an environmentally friendly yard.
h2photo is offline
Old 09-02-2007, 12:02 AM   #29
tripp
tripp's Avatar
<div class='quotetop'>QUOTE(h2photo @ Sep 1 2007, 10:45 AM) [snapback]505450[/snapback]</div>
Good on ya. Grass lawns in AZ make no sense. I used to live in Tucson and there's a neighborhood there (called Winterhaven) that has it's own water company. They REQUIRE you to have a green lawn. It's bizarre. I ran through there once and it was like I stepped through a portal to back east. Dumb asses. Such a waste of water. Do they still have those ridiculous fountains in Phoenix?
tripp is offline
Old 09-02-2007, 10:27 AM   #30
SSimon
<div class='quotetop'>QUOTE(Godiva @ Sep 1 2007, 11:19 AM) [snapback]505440[/snapback]</div>
There are some trees native to your area that probably have a deep tap root and rarely need will rarely need supplemental watering. Around here, the Shagbark Hickory has a tap root about 20 feet deep at maturity (from what I last read). You can have your cake and eat it to. Then you can at least appear to be keeping up with the jonses.
SSimon is offline
Global warming imntacrook Fred's House of Pancakes 12 04-12-2007 01:42 PM
"Why Americans are Skeptical of Their Role in Global Warming" (aka Global Climate Disruption) Mirza Fred's House of Pancakes 7 03-13-2007 08:14 PM
Global Warming Mary Snyder Environmental Discussion 1 01-02-2007 05:30 PM
High court to hear global warming case-Must Bush Change Course on Global Warming hb06 Environmental Discussion 17 12-21-2006 02:34 PM
Cause of Global Warming dragonfly Environmental Discussion 32 08-25-2006 11:10 AM
