Go Back   PriusChat > PriusChat Forums > Environmental Discussion
Environmental Discussion This is a discussion on Do grass lawns help global warming? within the Environmental Discussion forums, part of the PriusChat Forums category; <div class='quotetop'>QUOTE(tripp @ Sep 1 2007, 09:02 PM) [snapback]505684[/snapback]</div> Good on ya. Grass lawns in AZ make no sense. I ...
Old 09-02-2007, 01:27 PM   #31
h2photo
Turning greener day byday
h2photo's Avatar
Package: G Touring
Send a message via AIM to h2photo
Good on ya. Grass lawns in AZ make no sense. I used to live in Tucson and there's a neighborhood there (called Winterhaven) that has it's own water company. They REQUIRE you to have a green lawn. It's bizarre. I ran through there once and it was like I stepped through a portal to back east. Dumb asses. Such a waste of water. Do they still have those ridiculous fountains in Phoenix?
Yep, there's still a ton of fountains in Phoenix, thankfully, most (if not all) use Greywater though, so at least that helps a bit. A lot of people who want a green yard now, also put in astroturf, which is funny! But there's still mostly rocks. We're happy with our yard, we just need to get some landscaping or something
h2photo is offline
Old 09-02-2007, 02:58 PM   #32
fshagan
<div class='quotetop'>QUOTE(h2photo @ Sep 2 2007, 10:27 AM) [snapback]505904[/snapback]</div>
California still takes more than half the Colorado water that you guys have a 50% claim to, don't they (er, "we"?) I seem to remember that Phoenix could have water running everywhere and not use their allotment.
While there are other environmental concerns, if GW trumps all others, then the greening of Phoenix can only be seen as a good thing. The water source isn't a concern, as it just flows to the gulf of Mexico anyway, and the extra carbon-sequestering plant material is a net positive.
That is, if GW trumps all other environmental concerns.
My Blog
PoliteTalk Debate Site:
fshagan is offline
Old 09-11-2007, 12:25 PM   #33
acdii
<div class='quotetop'>QUOTE(SSimon @ Apr 8 2007, 08:46 AM) [snapback]419786[/snapback]</div>
Gore is the deliverer of the GW message, not the source. The majority of climate scientists concur that the planet is warming as a result of human contribution.
In your end statement you declare that you also base your views on your local temperature. GW is not based on the temperature trends in one area.
You also attacked the wrong person. Dbermanmd rejects the theory of GW. His sarcasm abounds.
So, you exhibit obvious error on multiple fronts.
Actually I have done more research on this subject. There is further proof that what is occurring is a natural cycle of the planet. We as humans on this planet have little to do with how the planet is warming. CO2 occurs naturally from the oceans, when they warm they emit more CO2, what is warming the oceans is the earth. Nature emits 97% of the CO2, humans and animals contribute 3%. If we were to stop everything that produces CO2 save for breathing, it would make no difference in the climate. When the oceans warm, temperatures rise globally. Ice melts faster in water than air. More precipitation occurs more snow is produced, heat is reflected away and eventually an ice age begins. It has happened before and will happen again and no matter what WE do, it will happen. If you want to do something, reduce pollution! You will get no argument from me that we are spoiling the air we breath, but when someone brings up that we are causing GW, I get a bug up my butt. WE are not causing GW, WE are polluting though. In fact no matter how hard we try, Nature can out produce us. CFC's occur naturally, CO2 occurs naturally, other gases occur naturally. However, we do put out pollutants that we can control and by reducing those emissions, we can clean up the air, water and earth.
If you want to dispute this go ahead, but keep in mind, water heats faster when the flame is under the pot than when it is above it. Think about how the planet exists. What is it, A huge ball spinning around orbiting a star that puts out tremendous amounts of heat. What happens when you compress something? It heats up, heat rises. The core of the earth is under tremendous amounts of heat, and is fluid, constantly in motion. I think a lot of people forget that fact. At the bottom of most of the worlds oceans there are mini volcanoes constantly spewing hot gases, and lava. That heat has to go somewhere. Eventually that heat reaches the surface, and the water evaporates, more CO2 is released, ice melts faster, etc.
This is all backed by scientific proof. Another thing that gets overlooked is the fact that CO2 can only absorb so much radiation per meter, no matter how dense the gas. It is like a plastic sheet, no matter how thick or thin it is, the amount it absorbs is the same. What is failed to be mentioned is the amount of water vapor in the air. Water absorbs a far greater amount of heat than CO2 ever could. More water vapor=more heat=higher temps. Where does the water vapor come from? Warming oceans. What came first, the chicken or the egg? So did the air raise the water temps? I doubt it, a degree or two rise in surface temps would take a very very long time to warm the oceans enough to make any difference. The air temps have been shown to rise over a very short time, too short to have any effect on the oceans. BUT Ocean temps rising to the point where it could affect the air temps makes more sense.
Now, as this thread has started off with grass, lawns can be a contributer of water vapor being released, and for that you wont find an argument from me, it is a valid statement, lawns can contribute to GW, but not in the ways mentioned. In fact studies have shown that Phoenix temperatures are rising slightly and there is now measurable amounts of humidity mainly due to lawns and swimming pools. Now is all that enough to cause GW by itself? I doubt it, in fact the amount of water vapor released world wide by swimming pools, water fountains and lawns is minuscule compared to what the oceans can put out.
acdii is offline
Old 09-11-2007, 12:35 PM   #34
Rae Vynn
Resident Witch
Rae Vynn's Avatar
Friends: 52
Back when I was a kid in Southern California, I lived in Hemet.
The Art Linkletter Mobile Home Park was/is? close to our neighborhood.
Driving through there, I was always bemused by all the painted concrete "lawns"... yup. Cement. Painted green. Of course, that conserves water, even if it does contribute to run-off. And the heat island effect.
Where I live now, our "lawn" is becoming more and more clover. Clover is a deep-root plant, that digs down very deep, and conserves moisture, while putting nitrogen into the soil. Requires no fertilizer, no watering, and doesn't grow that tall (the variety we have, anyway).
The natural ground cover here is, I think, moss, but no one wants that in their lawn
Rae Vynn is online now
Old 09-11-2007, 12:45 PM   #35
SSimon
<div class='quotetop'>QUOTE(Rae Vynn @ Sep 11 2007, 11:35 AM) [snapback]510625[/snapback]</div>
ACK! That's the crap that's all over my native garden. I spend 2 full days pulling the crap in the Spring and then periodic pulls resume throughout the year. I think a prior owner actually planted this stuff around our house. My husband, who had resided at the house for 10 years prior to my arrival, never thought to pull any weeds. My ass hurt from falling down whilst pulling the 8 foot thistle from the backyard. There is an end in sight. I'm only pulling the clover until the garden becomes established as it seeds in. Once that hits a critical mass, the clover will hopefully perish of it's own accord.
On the other hand, moss can hang around anytime.
SSimon is offline
Global warming imntacrook Fred's House of Pancakes 12 04-12-2007 01:42 PM
"Why Americans are Skeptical of Their Role in Global Warming" (aka Global Climate Disruption) Mirza Fred's House of Pancakes 7 03-13-2007 08:14 PM
Global Warming Mary Snyder Environmental Discussion 1 01-02-2007 05:30 PM
High court to hear global warming case-Must Bush Change Course on Global Warming hb06 Environmental Discussion 17 12-21-2006 02:34 PM
Cause of Global Warming dragonfly Environmental Discussion 32 08-25-2006 11:10 AM
