This is a discussion on Solar Panels and PHEVs within the Environmental Discussion forums, part of the PriusChat Forums category; Originally Posted by icarus Look into a water medium heat pump for your a/c. The waste heat from the a/c ...
Old 11-02-2009, 06:04 PM   #51
jayman
Default Re: Solar Panels and PHEVs
Originally Posted by icarus View Post
Look into a water medium heat pump for your a/c. The waste heat from the a/c is captured into domestic hot water. This has two benefits. The first is "free" hot water, the second is the a/c compressor runs much more efficiently.
A geothermal exchange heatpump system is far more efficient for most on-grid folks, but realistically you'll still need a 240 volt, 30-40 amp breaker. The inrush current to start up a typical 5 ton heat pump is formidable
A desuperheater recovery system for the domestic hot water should be standard equipment on heat pumps. Really, a no-brainer, the savings on heating hot water are very significant during the cooling season
For an off-grid home, perhaps a better solution for cooling would be a natural gas or propane powered adsorption cooling system. Most large chillers for commercial office space, industrial, etc, use the adsorption system. The system is sealed, usually the charge is lithium bromide and water
Ok, just looked into it. they actually do make residential adsorption coolers
Gas Airconditioning and Cooling Equipment Home Page
The electricity demand would be minimal, you're just running a few pumps, not an actual compressor. I would expect such a system to easily cost 2-3 times what a conventional split-system would cost, and would approach the cost of a geothermal exchange heat pump system
But if you're constrained due to off-grid, it would be the way to go and maintain reasonable summer comfort
jayman is offline
Old 11-02-2009, 07:06 PM   #52
icarus
What a lot of off grid folks are doing is going with the newish mini-spit heat pump systems. The Sanyos for example will draw as little as 300 watts, and they have soft start compressors so that they do not require massive current to start. All in all a pretty good technology.
Icarus
icarus is offline
Old 11-02-2009, 08:01 PM   #53
jayman
Oh, you mean like the Mitsubishi Mr Slim series? They best ones have Inverter soft-start.
I'm looking into a Mr Slim inverter heat pump for my master bedroom, as I like to sleep in cooler temps but don't want to bring the entire house down that low in summer. According to their specs, on Lo it runs on about 160 watts
Mitsubishi Electric - Product Information for MSZ-A09NA
Yes, with PF correction too
jayman is offline
Old 11-02-2009, 08:03 PM   #54
Zythryn
Originally Posted by drees View Post
PA Prius - where do you live that the utility is willing to pay you so much for your system and is also willing to pay you for any excess electricity produced?
Most places I know of you are giving the energy away if you don't use it - though I've read that it will hopefully be changing in more places over the next couple years.
I am not sure about 'most places' but in MN the utility companies are paying about the same amount (within 5%) for excess electricity as they charge.
And while I didn't get as good a deal from our utility company, they still helped out with it a little bit
Zythryn is offline
Old 11-02-2009, 08:16 PM   #55
icarus
I was actually referring to the Sanyo which I am only marginally familiar with. My guess is the "Mr Slim" is similar technology.
Icarus
icarus is offline
Old 11-02-2009, 09:01 PM   #56
fuzzy1
Model: II
Fujitsu also has similar units, and some 9-12-15kbtu models qualify for the U.S. incentives this year and next.
fuzzy1 is offline
Old 11-02-2009, 10:39 PM   #57
hill
High Fiber Member
hill's Avatar
Originally Posted by radioprius1 View Post
This was my next question regarding costs. The solar installers show how you can get a $25,000 system for $5000, but I was curious if you had to lay out the whole $25,000 initially and then wait around for all the credits, etc. That makes these things a whole lot less attractive. It's a whole lot easier to part with 5,000 in cash than 25,000.
Do you (anyone) think that the solar installer companies would ever install it for the after rebate amount and wait for you to get the rebates to pay the rest?
Many established CA companies do this ... but startups don't necessarily have the dough to lay out $$ and wait. I'd bet many other state's installers work the same way. Our installer had to wait at least 4 months, because they were so lax in getting all the "I's" DOTTED & "T's" crossed with the state's requirements ... as though it was no big deal for them to get so close the the state's deadlines that they could loose the incentive they'd sponsered.
Originally Posted by PA Prius View Post
That explains our difference. Our utility company charges a flat rate.
PA P
That's what our MT home is under. Not much incentive for folks to easily conserve 400Kwh-500Kwh of their monthly usage if it costs the same as the 1st 100Kwh used each month.
I Click the image to open in full size. Prius Chat
hill is offline
panels, phevs, solar
Solar panels Up and running Tadashi Environmental Discussion 25 09-14-2007 07:44 PM
Solar Panels h2photo Gen II Prius Modifications 5 06-01-2007 08:12 AM
Solar Panels material_claw Gen II Prius Modifications 18 07-09-2006 10:04 PM
Solar Panels??? politically corrupt Gen II Prius Modifications 2 01-16-2006 10:06 AM
Solar Panels and PHEVs Boulder Bum Fred's House of Pancakes 0 12-31-1969 07:00 PM
