| This is a discussion on CO2 savings via a PV solar system within the Environmental Discussion forums, part of the PriusChat Forums category; Hi all, We had a 3.7 kW system installed on our house last August and it has been working well ... |
| Senior Member Join Date: Oct 2007 Location: Pleasanton
My Car: Other Non-Hybrid Model: Package: N/A Thanks: 56
Friends: 0 | Hi all, We had a 3.7 kW system installed on our house last August and it has been working well (knock on wood). On our Sunnyboy 4000US inverter, it displays the amount of CO2 saved by running our system. I have to go back and revisit the inverter manual, but I believe it said it was the kilowatts generated multiplied by 1.7 (default value), this would mostly jive with what we've seen (5600 kilowatts generated * 1.7 = 9500 lbs of CO2....well except our display says 95000 lbs of CO2. I'm guessing an input error of 17 instead of 1.7). Anyhow, does anyone know how they came up with the value of kilowatts * 1.7 as a CO2 calculation? Does this assume an average of the entire US for kilowatt vs CO2 generated by our power plants? Last edited by Codyroo; 06-17-2008 at 11:09 AM. |
| _ . _ . / _ _ . _ Join Date: Mar 2008 Location: Los Angeles
My Car: 2008 Prius Model: Package: #5 Thanks: 151
Friends: 17 | As of yesterday, my year to date total value, since going on line Aug/04, with my 7.5 kW system I have generated 58,783 kWh of Solar Power! Iguess that means 999311 CO2 savings!!! GO SOLAR!!! PAT KK6PD |
| Senior Member Join Date: Feb 2005 Location: Fort Hood, TX
My Car: 2005 Prius Model: N/A Package: #6 Thanks: 0
Friends: 0 | It all depends on the source of your power and efficiency of the plant. If my calculations are correct you should multiply 0.698043165 by the number of kWh to get the total kg of carbon saved from coal power. That is an avg value as coal from different locations burned in different plants produce different amounts of power. This value comes pretty close to the SMA value my Solar system gives me. I am not sure what the conversion is for kW vs kWh. So I am not sure how they get 1.7. |
My Car: 2005 Prius Model: Package: #4 Thanks: 6
Friends: 4 | Quote:
http://aspenglobalwarming.com/pdf/01Elec&Notes.pdf So, as you said it does vary quite a bit depending on sources. You'd really want to at least get your state average, if not a number from your actual power company. Rob | |
| Senior Member Join Date: Feb 2006 Location: California
My Car: 2006 Prius Model: Package: #1 Thanks: 1
Friends: 14 | Ok you math wizards, anyone know how much energy is needed to manufacture a 100 watt solar panel?(in other words, the energy to dig up the silicon, to refine it to polysilicon, process the panel, etc...) |
Friends: 0 | oops did did not notice you were working in imperial measurements. So I guess the 1.7 is not too far off. Maybe they estimate the worse case scenario power plant. Also they are a German company so many that is the avg for power plants in Europe. Again, not all manufacturers are created equal. Each has a different process and uses different material. I do recall reading a study that came to the conclusion that over the 25-yr life span of a panel, it does create more energy than it takes to make the panel. For some reason the figure of $4.5 to $5 a watt come to mind for the cost to make the panels. My house system costs $6.75 a watt including installation. This is without any rebates. I am not sure if the gov't provides any subsidies prior to the sale.
__________________ Two Prii Family - '05 Salsa Red BC#6 (Mine) and '05 Driftwood BC#6 (Wife's) Best Tank: 89.4 MPG (372 mi) - all city Worst Tank: 29.5 MPG (131 mi) - one flat tire Current Year: 73 MPG Best Yr: 73 MPG (2009), Worst Yr: 51 MPG (2005) Lifetime Avg: 63 MPG (54500 mi) Last edited by Tadashi; 06-18-2008 at 05:15 AM. |
Carbon Footprint Calculator Assumptions seems Pacifc Gas and Electric generates 0.524 lbs of CO2 per kilowatthour (kwh). Thus, in our area, we've saved about 3000 lbs of CO2 vs the 96,000 lbs the inverter is reading. Hmmmm, only a factor of 32 off.... | |
My Car: 2007 Prius Model: Package: #7 Thanks: 133
Friends: 3 | Quote:
Amortized for over the live of the panel vs the life of a coal or gas fired plant,,,,way less. Silicon, while not cheap to refine is abundant. Panels have a life span warranted for ~20 have a life expectancy of 40+ years. Icarus PS I don't know the detailed answer to your question however. | |
My Car: 2005 Prius Model: Package: #3 Thanks: 3
Friends: 6 | It really depends on the the panel. The recent panels are using less and less silicon because of the supply constraints. So compared to older panels the EROI is probably considerably better. Also, mono vs polycrystalline vs amorphous/thin film way be important in the calculation. |
Friends: 6 | I remember hearing once that the EROI is around 2 years. I can't verify that or remember the source (mighta been darrel). Again, could be considerably less now given panel mfg methods. |
| installing hot water solar drainback system | syncmaster | Fred's House of Pancakes | 1 | 02-08-2009 09:29 AM |
| Happy days - new solar hot water system installed! | ScubaGypsy | Environmental Discussion | 15 | 06-05-2008 01:53 PM |
| passive solar apartment with solar hot water | galaxee | Environmental Discussion | 32 | 08-30-2007 10:30 PM |
| Interesting FREE Home Solar System | efusco | Environmental Discussion | 18 | 03-19-2007 10:01 AM |
| Thin Film Solar Panel (Rollable Solar Powered Battery Chargers) | JeffElectric | Gen II Prius Technical Discussion | 5 | 03-09-2007 05:15 PM |
