| Environmental Discussion This is a discussion on How are Hansen's Global Warming predictions panning out? within the Environmental Discussion forums, part of the PriusChat Forums category; Originally Posted by chogan2 His mid-level scenario predicted warming at an average of 0.24 degrees centigrade per decade. So, take ... |
| global, hansen's, predictions, warming |
| | #21 | |
My Car: 2001 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| | #22 | |
| Senior Member Join Date: Apr 2004 Location: Da Gorge OR
My Car: Other Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| | #23 |
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | I think she's referring to the American "Big 3", not the actual Big 3. |
| | #24 |
| Senior Member Join Date: Sep 2005 Location: WA
My Car: 2005 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Does he also want to sue anybody who has ever driven a car? That seems only fair. |
| | #25 | |
My Car: 2005 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
First, I ran the global average value regression and it shows a slope of 0.14 C / decade from 10/79 - 6/08. This is substantially below Hansen's projections and since it covers the entire 30 year satellite record, is hardly "weather" and is not cherry picking the data since it is the whole record. Second, when you plot the trendline you notice a very interesting step function in 1998, which just so happens to be a strong El Nino year. If you break the data set to pre/post 1998, you find the trend for pre-1998 to be 0.024 C per decade, 1/10th what you suggest is Hansen's value. For 1998 onward the trend is 0.06 C per decade, about 1/4 of the Hansen value. So either way, he is far from the mark. And unless one can explain how CO2 caused a step function in a single year that drove a sudden rise in global temperatures, I'm betting on mother nature (and El Nino) and against Hansen. But even if you ignore the step function, Hansen comes up something like 80% above reality. Last edited by TimBikes; 07-08-2008 at 03:45 AM. | |
| | #26 |
| Senior Member Join Date: Feb 2008 Location: Virginia
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Timbikes, if you think you can test this better than the pros, you need to start by looking at the right data. As I understand it, Hansen's prediction was 0.24 degrees centigrade per decade for the earth's average surface temperature. So you need to look at average surface temperature data. We all know that not all parts of the atmosphere and not all parts of the surface are expected to warm at the same rate. So, you need global surface temperature data, not some other data, such as the data your link pointed to, which was somebody's posting of data labeled as lower troposphere temperatures. And you need to look at the period Hansen was discussing, which was 1984 forward, not whatever number of decades happen to show up in the dataset, as you have done. So, whatever that data set is, it's not labeled as surface temperatures, and it doesn't match the NASA data on surface temperatures, which can be downloaded here. Data @ NASA GISS: GISS Surface Temperature Analysis (GISTEMP) I think that people who model climate for a living are smart enough to understand and account for things like El Nino events, or the current La Nina event. I don't have enough ego to think that a few minutes of my time doing some half-baked (ie, univariate) analysis will somehow provide a more definitive answer than theirs. Having said that, I downloaded the GISS mean global (land+water) surface temperature data and ran my own regression. Annual observations, linear OLS regression predicting surface temperature anomaly as a function of year. From 1984 (the start year for Hansen's original model (per the realclimate article I posted earlier) to the present (2007, because there is no annual 2008 number yet), I get a trend of 0.21 degrees centigrade per decade, with a standard deviation of 0.027 degrees centigrade. Hansen's 20 year old prediction is well within two standard deviations of the mean. (In case you wonder why I used annual data, I have to do that to get any reasonable estimate of the standard deviation in this simple analysis, as the monthly data are strongly serially correlated. The monthly data should give me roughly the same mean but (with OLS) would substantially overstate the true precision.) (Further, the exact start point does not much matter, plus or minus a few years. If I were to start in 1988 instead of 1984 (as Hansen's model did, per the realclimate discussion noted above), the estimated slope would drop from 0.21 to 0.20 degrees centigrade per decade, which I would characterize as a negligible difference.) For what it's worth -- and it isn't much -- I have attached the plot. Black line is the actual annual global (land and water) surface temperature anomaly (ie difference from baseline period), pink line is the linear regression fit, blue line is Hansen's predicted rate of change. (I've centered both of those straight lines on the midpoint of the data -- so I'm only testing the slopes of the straight lines, not their intercepts as well. I have to do that because the regression line will automatically be centered on the midpoint of the data unless I want to take the time to monkey around with it, which I do not.) So, a) you can't reject Hansen's 20-year-old prediction for average global surface temperature increase based on this half-baked (ie, univariate regression) analysis, at least not if you actually look at surface temperature data and look at the period Hansen was discussing, b) by eye, the prediction looks pretty good to me, but I'm an economist so my standards are pretty low in terms of predictive accuracy, and c) the world has moved on, and there is little reason to care whether a 20-year-old prediction using methods that are crude by modern standards has or has not stood the test of time. That said, I think Hansen's work has stood the test of time so far. Again, for what that's worth. You'd be far better off reading what the actual climatologists say about it, for example, on realclimate.org. Last edited by chogan2; 07-08-2008 at 09:40 AM. |
| | #27 |
| Senior Member Join Date: Jul 2006
My Car: 2007 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Even looking at data since only 1979 is cherry picking. But why break it into segments like you did? Your first graph with the most data points is the most valuable. ![]() Even if he is off like you say temperature is still going up. Good enough for me. Last edited by Alric; 07-08-2008 at 12:09 PM. |
| | #28 |
| Senior Member Join Date: May 2008 Location: SE PA
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | The country has been governed the past 8 years by a reactionary. Not a conservative. And before that, Clinton was hamstringed by a reactionary congress. The Republicans have gone beyond conservative in their move to the right. They have eroded the tax base, and continued uncontrolled spending with borrowed dollars. And ignored the scientific warnings about environmental abuse. If the Democrats take over in the fall--and they must--lots will change, because things have to change if we are to survive. It has really become that apocalyptic. It is a question of the rational Center taking over American politics again. Last edited by PriusSport; 07-08-2008 at 10:59 AM. |
| | #29 | |
| | #30 |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Just this week, realclimate.org posted a nice analysis of the recent surface temperature trend after filtering out the ENSO (El Nino) variation. RealClimate So you don't have to eyeball the data and toss out selected years, you can see what climate scientists actually make of it in detailed modeling. Their conclusion: "The basic picture over the long term doesn't change. The trends over the last 30 years remain though the interannual variability is slightly reduced (as you'd expect)." |
| GWB on Global Warming | efusco | Fred's House of Pancakes | 8 | 07-22-2008 01:41 PM |
| "Why Americans are Skeptical of Their Role in Global Warming" (aka Global Climate Disruption) | Mirza | Fred's House of Pancakes | 7 | 03-13-2007 08:14 PM |
| Global warming predictions | etyler88 | Environmental Discussion | 4 | 02-17-2007 02:13 AM |
| High court to hear global warming case-Must Bush Change Course on Global Warming | hb06 | Environmental Discussion | 17 | 12-21-2006 02:34 PM |
| Global Warming | DaveinOlyWA | Environmental Discussion | 2 | 10-26-2004 05:13 PM |
