Go Back   PriusChat > PriusChat Forums > Environmental Discussion
Environmental Discussion This is a discussion on Global Warmest defector says, "No smoking hot spot" within the Environmental Discussion forums, part of the PriusChat Forums category; Originally Posted by TimBikes In regard to the EN uptick, think of it this way. In the top two charts, ...
defector, global, warmest
Old 07-27-2008, 01:31 PM   #31
dragonfly
dragonfly's Avatar
Default Re: Global Warmest defector says, "No smoking hot spot"
Originally Posted by TimBikes View Post
In regard to the EN uptick, think of it this way. In the top two charts, if you ran a trend line for 1979-1997, you would see it is nearly flat and at zero on the vertical axis. If you then ran a trend line from 1998 to 2007, you would also get (and I'm eyeballing this) a pretty flat line, but one that is centered around say 0.2 on the vertical axis. So to my eye - without running the actual regression here mathematically - it looks like the latter period is roughly 0.2 C higher in temp than the earlier period. A "step", if you will. Sorry if I'm not explaining myself well.
I see what you're saying. It seems like a matter of interpretation. I don't think we have enough data to conclude definitively one way or the other so I'm not going to say you're wrong. Ok? My bigger problem with these graphs is that they are not global. The long term temperature increase is more evident in the global plots.
dragonfly is offline
Old 07-28-2008, 12:06 AM   #32
TimBikes
Fair enough - a longer record would be better, but we have what we have, and 30 years is not bad.
As for it not being global, the graphs exclude primarily the Antarctic (stop at 70 degrees south latitude). As may know, on the surface at least the Antarctic has actually cooled over this timespan. So if anything, inclusion of that region might further reduce any temperature anomalies, rather than increase them. But I'd have to research it to say for sure.
TimBikes is offline
Asian "Brown Cloud" Accounts for much of Global Warming TimBikes Environmental Discussion 35 08-21-2007 04:36 PM
"Why Americans are Skeptical of Their Role in Global Warming" (aka Global Climate Disruption) Mirza Fred's House of Pancakes 7 03-13-2007 08:14 PM
Highway MPG - "sweet spot" for steady level driving tacomel Fuel Economy 9 12-06-2006 12:11 PM
Flatlander "sweet spot"? xbdude Prius Main Forum 2 09-05-2006 10:00 PM
Peter Doran- "I would like to remove my name from the list of scientists who dispute global warming." larkinmj Environmental Discussion 9 07-29-2006 09:37 AM
